Head gasket for turbo B18C?????
Old 11-04-2001, 06:38 AM
01-0338R's Avatar
Default Head gasket for turbo B18C?????
Can anyone recomend a head gasket other than oem for a turbo B18C for 20 lbs of boost or more? Thanks
Old 11-04-2001, 06:44 AM
b18bturbo's Avatar
Default Re: Head gasket for turbo B18C????? (JDMkoupe)
OEM is the way togo. But if you looking for a little bit better than oem go with either HKS or full copper with oring on the block.
Old 11-04-2001, 04:39 PM
Jared's Avatar
Default Re: Head gasket for turbo B18C????? (dc2jdmhonda)
Inline pro gaskets are simply stock gaskets with a thick copper center piece. sealing properties still same as a stock gasket.
Old 11-04-2001, 05:26 PM
What is this crap?
falcongsr's Avatar
Default Re: Head gasket for turbo B18C????? (Jared)
check out cometic gaskets. they were at SEMA...looked like some good stuff...cheap too...
Old 11-04-2001, 06:34 PM
earl's Avatar
Default Re: Head gasket for turbo B18C????? (falconGSR)
Cometic is the only way to go. 800-752-9850 Pick your thickness and pick your bore size...
Old 11-04-2001, 10:17 PM
type autox's Avatar
has anyone stacked two stock headgaskets? I have heard of it being done, I just wonder if anyone has actually run this setup for an extended period of time.
Old 11-07-2001, 01:32 PM
01-0338R's Avatar
Default Re: Head gasket for turbo B18C????? (type autox)
Thanks for the input
Old 11-07-2001, 08:52 PM
ekb18c's Avatar
stock is fine.. we use a stock gasket on our 9 sec race car.
Old 11-08-2001, 12:19 AM
Better than steak
Arturbo's Avatar
Default Re: Head gasket for turbo B18C????? (ekb18c)
After seeing the price of cometic, I cant believe how much Inline pro charges. $200 is pathetic. cometic was very helpfull and looks very good. Im gonna try them out to see how they work out, but I do prefer stock OEM.
art
Old 11-08-2001, 12:23 AM
paulzy's Avatar
Default Re: Head gasket for turbo B18C????? (Arturbo)
how much are the cometic compared to the inlinepro or fmax gaskets? Are the copper or same metal at stock?
Old 11-08-2001, 12:26 AM
Better than steak
Arturbo's Avatar
Default Re: Head gasket for turbo B18C????? (Slow_ass_4dr)
The cometic retails for about $80.
art
racerguy
Engine Machining & Assembly
01-12-2019 09:38 PM
Muckman
04-06-2018 11:25 AM
chasmataz
07-25-2010 08:35 AM
Lmgrcivic
02-06-2005 04:55 PM
u_tal
10-12-2004 05:00 PM
Quick Reply: Head gasket for turbo B18C?????
