Old 04-16-2004, 12:14 AM   #1
Joetxstate
Joetxstate's Avatar
Default No brake lights, and car is stuck in park???????
I have a 97 accord SE auto.. and i got in the car today and it would not come out of park, and my brake lights do not work. I checked all the fuses, both under hood and by the drivers feet, and all fuses including the brake light fuse is okay. I am able to move my car by using the shift lock, but how can i fix this.... the car has 120k.
97 honda accord SE, bone stock, my daily driver
99 Camaro SS, best 11.40 @ 122- heads, cam, 12 bolt, full suspension. Going back to stock
Joetxstate is offline   Reply With Quote
Old 04-16-2004, 03:03 AM   #2
Chiovnidca
Chiovnidca's Avatar
Default Re: No brake lights, and car is stuck in park??????? (Joetxstate)
Bad brake switch maybe? Does the horn work?
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 04-16-2004, 08:27 AM   #3
nuc79
nuc79's Avatar
Send a message via AIM to nuc79
I'm about 100% convinced it's the brake pedal switch or the switch's wiring There's is a Brake/Park Safety interlock that will not let your shifter move from Park unless your foot is on the brake. The switch that feeds into this interlock circuit is the same switch that makes your brake lights come on when you depress the pedal.
You can check the switch by getting under the dash and unplugging the 2-wire connector from the switch. Short the connector with a paperclip. The brake lights should come on. It's the same concept as your fridge/freezer light. Door opens-> light turns on. Only in this case, it's: pedal goes down -> lights come on.
If there's still no lights by shorting the circuit, it's not the switch. Trace the wiring and do some electrical trouble-shooting.
Let us know if the problem gets resolved.
Modified by nuc79 at 12:43 PM 4/16/2004
nuc79 is offline   Reply With Quote
Old 04-16-2004, 08:31 AM   #4
alb_accord
alb_accord's Avatar
Send a message via ICQ to alb_accord Send a message via AIM to alb_accord
swich or fuse
alb_accord is offline   Reply With Quote
Old 04-16-2004, 09:43 AM   #5
.bagged
.bagged's Avatar
Default Re: (alb_accord)
Will it come out of park if you use the shift lock release?
<FONT COLOR="purple"> Official Laker Fan #001 </FONT>
00-S4(stock http://images.honda-tech.com/set1/smile/emwink.gif) 05 - Touareg
<FONT COLOR="dark blue">Official One and Only San Diego Padres/Chargers Fan</FONT>
.bagged is offline   Reply With Quote
Old 04-16-2004, 12:08 PM   #6
crafty
crafty's Avatar
Default Re: (baGged93aCcord)
did you chaeck your lights? (especially the 3rd brake light)
this happened to mine after the bulb burned out
crafty is offline   Reply With Quote
Old 04-16-2004, 12:44 PM   #7
nuc79
nuc79's Avatar
bagGed93, I think he can get it out of park if he uses the key to release the shift lock. So it has to be electrical. I'd be less worried about the shift lock problem(you can still drive it this way), and more concerned with not having brake lights(will earn you a ticket).
Also, if the center brake light burns out, it WON'T take the other brake lights with it, unless the car's wiring has been monkey'd with somehow...
Old 04-16-2004, 04:35 PM   #8
Run Hatch
Run Hatch's Avatar
Send a message via AIM to Run Hatch
Default Re: No brake lights, and car is stuck in park??????? (nuc79)
brake pedal switch that what happen to me and becareful because when u stop the rear light dont work so the person behind u does not know u are stopping.
Good luck.
http://images.honda-tech.com/set1/smile/emsmilep.gif http://honda-tech.com/zerothread?id=803829 My Vouch thread.
Vouches
ninjaMONKEy, WCI, Slammed SI, CRITTERMATT, egjoe, D50boy, phiberoptik, sakums20, PY01ITR42, TrYtoEz, rex03, Kicklow, Spiketrunks,Ejay Six, Kp_VtekNiks, monicle, 92integra_gs, belugosi, 2wickedtoyz, B2FiNiTY, Khaa, EL Vap133, ek4 copue, JDM B16 EK, igyloo, sohczchf, Tukap1, tealjdmcrx , Humlae
http://images.honda-tech.com/set1/smile/emthup.gif
Run Hatch is offline   Reply With Quote
Old 04-16-2004, 04:40 PM   #9
.bagged
.bagged's Avatar
Damn it .. where is the hammer head...someone give it to me..god im glad its friday
Old 04-16-2004, 06:36 PM   #10
nuc79
nuc79's Avatar
Default Re: No brake lights, and car is stuck in park??????? (baGged93aCcord)
haha, you don't need a hammer, where's the beer icon? it's friday, celebrate....
Old 04-18-2004, 06:08 PM   #11
Chief Brody
Asst to Mod in Training
Chief Brody's Avatar
Thats weird, the same **** just happend on my 90 like a month ago.
I looked at the fuses in the engine bay, the tail lights are connected to the horn i believe? I put a fuse in there ( there wasnt even one in there???) and that got them working.
Then for the car being stuck in park ( shift selector switch.... 30 dollars on hondaautomotiveparts.com) I just left the car in neutral and put on the parking brake. The thing fixed itself though.... it just started working again one day.
Originally Posted by BauleyCivic View Post
I did the same thing with the Miata...got into a serious relationship, moved, and the car didn't make sense anymore.
Originally Posted by 90hatch94dsm View Post
Because the relationship was with a woman?
Chief Brody is offline   Reply With Quote
2002, 2004, accord, brake, burns, car, constantly, fuse, honda, horn, lights, park, shift, shifter, stuck
