| Welcome to Honda-Tech! | ||
#1 |
I had to fix my timing today because my belt jumped a few teeth while I was goin down the road the other day and the car stopped running.
Here is what I did: 1)broke loose the crank pulley bolt. 2)turned the crank until the pulley key was on the top. 3)removed the timing belt 4)turned both cam gears until the nothches on them were parallel with the top of the head and the arrows that say up were poointing up. I had a problem in step 4: The intake cam wouldn't turn after a certain point so I was forced to turn it in the opposite direction of the exhaust cam. Would that effect anything? THey both ended up where they should be. What did I do wrong? My car is still not running. It makes a sound like the battery is dead, while I try to crank it. All help is greatly appreciated Modified by B16CRXT at 5:47 PM 4/15/2004
My CRX build |
#2 | |
A valve in your motor is sitting against a piston and wonly allow it to turn.. Unsure how you got to that point.. Make sure the "UP" is pointing up and the crank is aligned to TDC.. That should be all you need.. Not sure where your timing is now..
Anytime you do a timing belt or adjust cam timing you should always turn the motor over a complete revolution with a ratched before trying to start it..
(new) 94' Honda Civic VX - Work in progress (old) 89' Honda Crx DX -- 1/4 - 12.75 @ 108 mph on 12 psi AEM EMS Tuner....PM me for tuning in the Baltimore, MD area.. WTB: Tow Dolly somewhere around Maryland.. FS: B16 jdm sir2 shortblock, about 2K on it since I rebuilt it.. FS: 2001 Honda Prelude Type-SH, Red, Make offer.. Vouch Thread Quote:
#3 |
a valve is on my piston? how would fix that? Tear down the head?
Also, when the pully key is on top isnt that TDC? I dont feel like taking the pulley off and I have heard on this forum that the key was also a TDC mark. Modified by B16CRXT at 5:53 PM 4/15/2004
My CRX build |
#4 |
| Garage is empty, add now |
look for the white and red marking for the crank pulley.
#5 | |
OK... First, if you didn't force the camshaft hard when it didn't turn, you can hope that you didn't bend a valve. Then you can do this:
1) Turn your crank about 90 degrees away from TDC. This way NONE of the pistons are at the top of their stroke. 2) Turn the camshafts whichever way you need to line them up like they belong. 3) NOW you can turn the crank directly back to TDC because none of the valves for #1 & #4 are open. 4) Put the belt back on. Now that the belt's on you should only turn the engine forwards. The key is not the TDC mark, but mine has a TDC mark on the crank sprocket for the belt. There's a mark on the oil pump. The real kicker is the timing can't really be 180 degrees off. The crank turns 2 revolutions for every 1 of the cams. So you simply had to turn the crank around once, then your cams would have been almost there.
JimBlake '03 Accord & '07 Civic '01 Saab 9³ & '05 9²x TECHNICAL(?) quote... Quote:
#6 |
so, if my timing is still off, it is possible that the crank is simply out of time still with the cams by 1 rotation?
I have a feeling my vavles are bent. this is my thread on my problem. http://www.honda-tech.com/zerothread?id=832198 I saw JDMShit.com had some pretty cheap prices. Do they sell quality parts? Can I get a head cheaper from somewhere else. Also, they sell trannies and ECU's. faily cheap as well. Complete head and tranny both starting at $395. I thought that was a good price (is it?). Thanks for your help guys +
My CRX build |
#7 | ||
#8 | ||
Do this and you should be fine..
#9 | |
#10 | |
Chris "Mighty Mouse" Capowski Acura Tech <U>The new Honda-Tech</U> Informative posts will now cost $1.00/ea. Don't worry, you will still be entitled to my opinion for free... THIS SPACE FOR SALE |
#11 | |
#12 | |
With the crank at the pointer, and the cam arrow pointing down, you are NOT at #1 TDC, you are at #4 TDC.
#13 | ||
#14 | |
#15 | ||
You could also set the crank at TDC and align the cam gears where the "UP" pointer is pointed down and it would work, You would be aligning to #4 TDC.. Its eaiser to do #1 though..
#16 | |
#17 | |||
Turn the crank so it's all lined up to the TDC pointer & the camshaft(s) lined up just like they should be. Now turn the crank ONE revolution. The camshaft will have turned 1/2 revolution, so now the cam is "180 degrees out". Turn the crank one more revolution, the cams are back to being "correct". Didn't you guys learn this in 8th grade when you took your dad's lawnmower apart?? Better yet, you go thru this same process every time you adjust your valve lash. Quote:
#18 | |
Yeah, I gotcha. I've installed a few timing belts since then with no issues. I'm sure you are right, there was probably some other reason, I guess I'll never know though. I didn't get much of a chance to tinker with that engine before I sent to to the junkyard. |
#19 |
1996 Honda Civic |
first of all, maybe yoru right with that pulley key. but the way i always get my crank to tdc is by looking at the crank gear not the pulley, it has a little ridge on it to show where tdc is, and then on the block there is alittle mark, just gotta line those up, then line up your cam gears. done. im just thinking the way you got to tdc on yoru crank isnt putting your crank to tdc, i could be wrong, ive never tried it with the pulley itself.
ive done 5 honda timing belts and all the motors are still working |
#20 |
this is a good thread..
i never would have thought that, until I had the problem w/ my motor..
My '08 Spring Cleaning Sale - Hondata etc. http://www.honda-tech.com/zerothread?id=2259271 My Official Vouch Thread: http://www.honda-tech.com/zerothread?id=951563 |
| Tags |
| 180, 2001, b16, belt, camshafts, car, civic, degrees, h22a, honda, jump, make, motor, timed, timing, turned |
