Old 04-13-2004, 07:19 PM   #1
jerm001
jerm001's Avatar
Default What does a bad cv joint sound like
I have this weird noise coming from somewhere in front of my car, can't tell where, I'm sort of leaning towards the right side though. Anyways, it only occurs at a certain rpm (no tach) when accelerating fast it isn't there, and when driving not accelerating at all it isn't there either. Doesn't occur when the clutch is in, or when it is in nuetruel only when driving.
if any one has any clue what this sound may be please let me Know
P.S I bought that belt dressing stuff and sprayed it on the alternater belt and the noise is still there
Thanks again
[url="http://www.outdoorperceptions.com"]http://www.outdoorperceptions.com[/url]
jerm001 is offline   Reply With Quote
Old 04-13-2004, 07:20 PM   #2
Convoy
Convoy's Avatar
Default Re: What does a bad cv joint sound like (jerm001)
does it make noes when u turn??
Convoy is offline   Reply With Quote
Old 04-13-2004, 07:27 PM   #3
jerm001
jerm001's Avatar
no, no noise when you turn
Old 04-14-2004, 09:21 AM   #4
jerm001
jerm001's Avatar
Could it possible be a heat sheild rattle?
Old 04-14-2004, 09:30 AM   #5
96hb
96hb's Avatar
Default Re: (jerm001)
*click* *click* *click* *click* *click* *click* *click* *click* when you go around turns. Get under there and see if you have a ripped boot. If you do, you might as well change the axles because dirt and other debris has already gotten in there. Click the image to open in full size.
midori
96hb is offline   Reply With Quote
Old 04-14-2004, 09:49 AM   #6
Phatch99
Phatch99's Avatar
Default Re: (96hb)
Don't mean to jack your thread but what if click,click,click,click after new axles installed??
Phatch99 is offline   Reply With Quote
Old 04-14-2004, 09:53 AM   #7
Filliam H. Muffman
Filliam H. Muffman's Avatar
Send a message via AIM to Filliam H. Muffman
Default Re: (Phatch99)
then you got bad axles Click the image to open in full size.
its either that or the guy holding you up for your new axles has no bullets in his gun
Originally Posted by .Eddie
Reminds me of how i told my wife I wanted a divorce. It had been so long since i got laid that I jacked off on to my wife's face while she slept. then i stuck the divorce papers to her face.
-Derek
Filliam H. Muffman is offline   Reply With Quote
Old 04-14-2004, 10:30 AM   #8
ABK
ABK's Avatar
Send a message via AIM to ABK
Default Re: (JUN EK9)
maybe your other axle is messed up too
and you need to replace it
Swaps, engine work, street tunes cheap in Chicago area, pm me.
ABK is offline   Reply With Quote
Old 04-14-2004, 10:47 AM   #9
GSR-Civic
take the heat shield off and see what happends
1997 Honda Civic EX
d16y8
AEM Cold Air Intake [img]http://images.honda-tech.com/set1/smile/emdgust.gif[/img]
GSR-Civic is offline   Reply With Quote
Old 04-14-2004, 11:09 AM   #10
assman_91
assman_91's Avatar
Default Re: (GSR-Civic)
check if your cv boot is torn...is there grease all inside your wheel?
a bad cv usually clicks
assman_91 is offline   Reply With Quote
Old 04-14-2004, 12:18 PM   #11
jerm001
jerm001's Avatar
ok, Its definitly not the cv joint then, the sound is a sort of rattle, (sounds are so hard to describe)
Old 04-14-2004, 12:21 PM   #12
96hb
96hb's Avatar
It could be the heatshield near your cat. That thing rattled like a **** on my last car.
midori
Old 04-14-2004, 12:24 PM   #13
lohatch
lohatch's Avatar
perhaps it is something in your tranny clicking since it is coming from the front of your car. if your were in the drivers seat it would appear to be coming from the right side, and it is only occuring when in gear and doesnt happen when turning corners ruling out the CV joint. maybe a body panel in the front right is causing some vibration, or anything up there could be lose making noise. get in there and check it out
RDR 12.009@113, 11.53@121 ....all motor streetcars
Modern Automotive Performance
(763)545-3800
lohatch is offline   Reply With Quote
Old 04-14-2004, 12:31 PM   #14
jerm001
jerm001's Avatar
when in the drivers seat I think its coming from the left
accord, axle, bad, boot, click, cv, doea, front, honda, joint, like, rattle, shaft, sould, sound, whar
