Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 04-06-2004, 09:50 PM   #1
DC 2
DC 2's Avatar
Send a message via AIM to DC 2
Default Worn Valve Guides??
I just picked up a first Gen B16 from HMO and I swaped it into my Crx Si. I thought It was pinging so I retarded the timing all the way and added 93 Octane. I noticed Today it still made the noise with out the throttle so I think It could either be a valve adjustment or worn valve Guides.
It Starts at 2500 and continues, sounds exactly like detanotion. I say valve Guides cause when I had the header off I notice #2 valves had a small indention on the valves at the bottom of the guides and were shiny siler unilke all the others being dark black. I planning to do an adjustment asap
-01 BB6 SH
DC 2 is offline   Reply With Quote
Old 04-07-2004, 06:55 PM   #2
DC 2
DC 2's Avatar
Default Re: Worn Valve Guides?? (EH3B18B)
TTT for night crew
-01 BB6 SH
Old 04-07-2004, 08:00 PM   #3
Cory man
Cory man's Avatar
I highly doubt that the valve guides will cause a detonation sound. I also have a 1g B16 and from what I have seen they have issues with the LMA's(lost motion assemblies). They make a tapping sound that sounds similar to the valves needing adjusting. Sometimes the fuel injectors will also make a similar sound. I plan to upgrade to some GSR(Same as ITR) lma's. HTH
ASE Certified Honda Dealer Tech since 03
Cory man is offline   Reply With Quote
Old 04-07-2004, 08:29 PM   #4
krazie1
BANNED
Default Re: Worn Valve Guides?? (Cory man)
so true in the same boat about to change mine and add some bonus stuff while it is out
valve guides usually smoke
that is the way I tell if they are bad
krazie1 is offline   Reply With Quote
Old 04-07-2004, 08:31 PM   #5
onePOINTsix
onePOINTsix's Avatar
Send a message via AIM to onePOINTsix
Default Re: Worn Valve Guides?? (krazie1)
i think you mean valve guide seals, worn guides themselfs will not cause smoking (oil leaking into the runners). Do a valve adjustment and see if that sloves your problems
1986 Mazda RX7 Luxuary Pkg...
1990 Honda CRX HF...Sold 5/06
1995 Honda Civic EX sedan... B18C5+Turbo=Fun
1996 Subaru Legacy Wagon L
2002 Volkswagen GTI 1.8T
"I don't drift... I strafe." -JDM97CX
onePOINTsix is offline   Reply With Quote
Old 04-07-2004, 09:43 PM   #6
DC 2
DC 2's Avatar
Default Re: Worn Valve Guides?? (Sideout)
I say valve Guides cause the valves looked suspicious when i eyed them before install
-01 BB6 SH
Old 04-08-2004, 01:47 AM   #7
importboi22
importboi22's Avatar
Send a message via AIM to importboi22
my valves are bent and they tick =\
50% Filipino 50% Dutch 100% American!
importboi22 is offline   Reply With Quote
Old 11-09-2012, 03:39 PM   #8
britnscrn
my honda crx si i just had it rebuilt i think the rings had time to seat. but it still smokes when you crank it up just running sitting still it dont smoke rev it up blue smoke comes out the back check a compression check 120. compression didnt stay up whent down real quick. some tell me its the valve guides some tell me its the rings. it has a lot of blow bye. i dont know mabey i can get some help threw this web site. i put 300 miles on it.
britnscrn is offline   Reply With Quote
Old 11-09-2012, 04:09 PM   #9
zrickety
1991 Honda CRX
zrickety's Avatar
iTrader Rating: (1)
zrickety zrickety
Send a message via AIM to zrickety
I would say it's LMAs or something else. Personally never saw worn guides on my high mileage B16. If it smokes, probably valve stem seals and piston rings. Knock sensor should be doing it's job unless you got a tune.
91 Crx Si (B16 SiR)
http://crxcommunity.com/viewtopic.php?f=26&t=32702
zrickety is offline   Reply With Quote
Old 11-09-2012, 11:15 PM   #10
DCRB
DCRB's Avatar
Send a message via AIM to DCRB
my z6 head does this untill its warmed up, and i know atleast of my lma's is stupid stiff
Build Thread - My 88 ED6 Daily - 97 Vr6 Passat Wagon
Originally Posted by BETOSCOUPE View Post
Plus my boss gets mad at me because she can't hear me 1/2 the time while I am on the phone with her lol "WHAT IS ALL THAT NOISE" - Bitch..... Its my Type R foo lol
DCRB is offline   Reply With Quote
Old 11-10-2012, 04:09 PM   #11
RanCRX
RanCRX's Avatar
From what i heard. Blue smoke indicates bad piston rings
RanCRX is offline   Reply With Quote
Old 11-10-2012, 11:17 PM   #12
DCRB
DCRB's Avatar
no blue smoke indicates that engine oil is either being burnt or vaporized. it does not mean rings. a compression test and leak down test will show you what's going on.
I just did the stem seals on my buddies 90 turbo laser that was billowing like a train at 300k miles (yes stock block) cylinders 2 and 3 would pour oil out the exhaust ports from how bad the stem seals were. now it maybe burns a drop or two at high rpms but is billow free.
proof, oem on the left, super tech on the right:
back on topic.
o/p blindly retarding your engine and adding higher octane gas wont just solve the issue. re time it to where it should be, and ONLY run premium regardless, since it's a high compression motor.
that being said what ecu are you running?
18t, b16, b16a, bad, crx, ebay, guides, honda, install, noise, si, subaru, symptom, valve, vw, worn
