Old 03-25-2004, 10:52 PM   #1
=GAME=
=GAME='s Avatar
Default Integra Rear Disc Conversion on an EG hatch. (lots of pics)
===REPLACING DRUM TO DISC===
^this is my car before the rear disc conversion^
^first off remove this two philips screw holding down the armrest (i just have those 2 holding it in place while OEM armrest has those 2 and 2 more in the rear)
^then roll back the rear carpet until you can see the 2 ebrake cables. unscrew the adjuster nut so you can get some slack to remove those hammer head thingy. after both cables are loose, push the 2 rubber garment things down so that after you remove the two 12mm bolts from underneath, slide under the car and pull the cables free.
^after the cable is out remove the 14mm toe bolt and the two 17mm bolts holding the arm up.^
^then remove the lca bolt (thats the wrong bolt. i meant to remove the bolt to the right of it)
^finally unscrew the 10mm for the brake line. after you unscrew the line get some pliers and remove the clip thats holding it in place. little drops of brake fluid will be dripping so get something to catch it. then remove the two 14mm camber bolts and the whole trailing arm should start to drop. ( in this case, as i was removing the bolts, i brace the trailing arm on my thighs.^
^should look like this after removal. (sorry for the crooked pic. i was tired)^
^finished. one side that is . as for installing, just follow the steps in reverse.^
===REPLACING ROTORS===
^thats what happens when its been in the junkyard for a whiles^
^first remove the two 10mm bolts holding the sheild thing up top. then remove the two 12mm bolts holding the caliper. ^
^then remove the two 14mm bolts holding that thingy? (the thing the pads seat on)^
^should look like this after^
^those two rotor screws didnt have a chance to strip. (thats my hoodrich mini) ^
^brembo blanks from nopionline $47(great place. fast shipping )
after you mount the new rotors on, reverse the steps. i know i missed some steps, as in bleeding, pumping, installing pads, refilling fluids, but you get the idea. this post too some time so you guys enjoy
finished both sides.
^while im posting pics, here's my car a few months back^
^and heres it is 2 years ago when i had the b18b, silverstone metallic that i enjoyed for 2 months before someone reversed into my driver fender and door^
^now it been thru a major makeover. dont mind the valvecover and mounts. they're black now.^
If I can't do it, it can't be done.
=GAME= is offline Report Post   Reply With Quote
Old 03-25-2004, 11:00 PM   #2
diearzte2
Guest
Posts: n/a
Awesome. These are the DIYs I dont mind seeing. None of that ricey bs
Old 03-25-2004, 11:01 PM   #3
=GAME=
=GAME='s Avatar
Default Re: (diearzte2)
Im going have another one sometime this week on upgrading your MC/Booster. I didn have enough time because i had to go to work today. Im probably going to do it this weekend when im free.
Old 03-25-2004, 11:07 PM   #4
AmginE
AmginE's Avatar
Send a message via AIM to AmginE
Default Re: (=GAMEOVA=)
hey good post.
your car is too bright for my taste though.
DA SQUAD member #201
Originally Posted by JoelG
hint to newbies:
dont use the transmission to slow the car, use the brakes. Thats what they are there for. And brakes are a lot cheaper and easier to replace than transmissions.
This applies just the same to cars with manual gearboxes.
AmginE is offline Report Post   Reply With Quote
Old 03-25-2004, 11:15 PM   #5
JDMlyfestyle
JDMlyfestyle's Avatar
Send a message via AIM to JDMlyfestyle
dont you have to get a different proportioning valve when doing a rear brake conversion? and what MC/booster is an upgrade from an EG
JDMlyfestyle is offline Report Post   Reply With Quote
Old 03-25-2004, 11:20 PM   #6
G U E C O
G U E C O's Avatar
Send a message via AIM to G U E C O
nice wirte up. i liked the color before, but thats my opinion so who cares right.
***GETTING RID OF EVERYTHING***
http://www.hondamarketplace.co...07302
<U>*Vouch List*</U>
http://honda-tech.com/zerouser...44908
G U E C O is offline Report Post   Reply With Quote
Old 03-25-2004, 11:37 PM   #7
Hondas are us
Hondas are us's Avatar
Send a message via AIM to Hondas are us
Default Re: Integra Rear Disc Conversion on an EG hatch. (=GAMEOVA=)
IMO- back to silver....
good write up, nice to see some that are actualy usefull upgrades every now and then
AIM= Hondas are us
92 Civic Vx - 424k miles, RIP (on July 1st 2005, some lady blacked out, side swipped the passenger side of the car in front of me and hit me head on. I am glad to be alive but sad to see my civic completely destroyed) http://images.honda-tech.com/set1/smile/emsad.gif
Current: 92 Civic Vx - Here we go again with a Vx car... this one is Tahitian Green Pearl.
Hondas are us is offline Report Post   Reply With Quote
Old 03-25-2004, 11:43 PM   #8
stripes777
stripes777's Avatar
Send a message via AIM to stripes777
how much were all the parts and how long did it take u? im going to do this, but imma save up for new springs and shocks first. did u change ya prop. valve?
~~~I NEED A STOCKWHITE FRONT BUMPER FOR A 2 DOOR 2000 ACCORD~~~
futangklan@hotmail.com
For Gold H4/9003 headlight bulbs, check them out at:
http://www.angelfire.com/sd/ftk2/gold/main.htm
stripes777 is offline Report Post   Reply With Quote
Old 03-26-2004, 12:22 AM   #9
=GAME=
=GAME='s Avatar
Default Re: (JDMlifestyle)
you dont have to but itll help. right now im running the stock mc/booster and pv. its stops pretty good right now. im going to install either the nonabs mc/booster or the R mc/booster that i got from a friend sometime this week.
thanks. and yup thats your opinion
nah never sport the same paint twice. IMO i rather custom paint over OEM. next color will be some more kandy. its cheaper.
$150 for the whole trailing arm from the junk yard. $46 for the rotors. type R mc/booster, RS mc/booster, and 4040 freebie from some friends around the way. im not sure whic mc/booster i will install yet. as for how long, about 4 hrs by myself maybe 3½ if i didnt take pics. but i had my brother come out after and pump the brakes
Old 03-26-2004, 12:43 AM   #10
Emong3
Nice Post and car!
I have some questions:
1. To convert it to disk brakes, do you have to replace the whole trailing arm assy?
2. How about cable sor the e-brake, did you replace it too or did the old cable bolt on?
Thanks!
Emong3 is offline Report Post   Reply With Quote
Old 03-26-2004, 03:45 AM   #11
mycivicstoo(s)low
mycivicstoo(s)low's Avatar
Send a message via AIM to mycivicstoo(s)low
Default Re: (Emong3)
Wow! That's really green!
Nice car
Nice howto
mycivicstoo(s)low is offline Report Post   Reply With Quote
Old 03-26-2004, 06:04 AM   #12
EGlovr
EGlovr's Avatar
Send a message via AIM to EGlovr
good write up mang. props to a good lookin car too
الرجل التقويم
F430 Club
Originally Posted by god.loves.ugly
well Ill be damned if it isnt the drug dealing version of danny glover himself
EGlovr is offline Report Post   Reply With Quote
Old 03-26-2004, 06:26 AM   #13
Fuster_Cluck
Fuster_Cluck's Avatar
Send a message via AIM to Fuster_Cluck
Now I have no excuse not to install the GSR discs sitting in the garage
Great write-up!! Nice hatch. Kind of exotic for me. I really loved the silver look you had 2 years ago.
Pelican 1624 containing: 2 Gripped Canon 50D's, XT, XTi & XSi ♥ 10-22mm ♥ (2) - 18-55mm ♥ (2) - 50mm f/1.8 ♥ 24-105mm f/4L IS ♥ 70-200mm f/2.8L IS
Fuster_Cluck is offline Report Post   Reply With Quote
Old 03-26-2004, 07:49 AM   #14
Lscivichatch92
Lscivichatch92's Avatar
Send a message via AIM to Lscivichatch92
Default Re: (Hybrid93Hatch)
dude change that color to make it a little more low profile cuz them cops gonna get you everytime with ur car like that
92 Civic Hatch w/ Ls swap, Gsr tranny, Password CF intake, DC header, Skunk exhaust, Exedy 3 puck, ACT prolite, NGK wires, Nitto 195/55R15s, custom paint job from the sun himself!!! 14.8 street tires with a raging hard on brought on by too many redbulls
Lscivichatch92 is offline Report Post   Reply With Quote
Old 03-26-2004, 07:53 AM   #15
Ricey McRicerton
Moderator
Ricey McRicerton's Avatar
Default Re: (Lscivichatch92)
Good writeup. A little more thorough than mine to say the least. to you for taking all those pictures.
As far as the MC/BB and prop valve goes. With the 4040 prop valve you just undo the lines you have and rehook the lines into the new prop valve. No flaring required.
Same with the new MC. It's 2 bolts to hold it to the BB and then a couple of nuts to get the hard lines out.
I don't know how to get the BB out.
09 SI Sedan
Ricey McRicerton is offline Report Post   Reply With Quote
Old 03-26-2004, 08:03 AM   #16
Evs-One
Gearing Owns Me
Evs-One's Avatar
Send a message via ICQ to Evs-One Send a message via AIM to Evs-One
Default Re: (Ricey McRicerton)
4 nuts behind firewall, and a clip and pin that holds the BB onto the brake arm
Independent Honda and Acura.... (360)574-8880
95 Civic Si J32A2 91 Civic ITA/H4
MFactoryOEM Honda
Evs-One is offline Report Post   Reply With Quote
Old 03-26-2004, 09:10 AM   #17
SIowner
SIowner's Avatar
Send a message via AIM to SIowner
nice right up
99 si coupe
Love the car, but needs work on acceleration
slowly but surly my car is getting faster!
SIowner is offline Report Post   Reply With Quote
Old 03-26-2004, 11:45 AM   #18
EGhatched
EGhatched's Avatar
Send a message via AIM to EGhatched
Default Re: Integra Rear Disc Conversion on an EG hatch. (SIowner)
do you have to change out the rear brake lines when doing this swap. I"m about to do a swap from a 00 si.
EGhatched is offline Report Post   Reply With Quote
Old 03-26-2004, 12:54 PM   #19
pdiggitydogg
pdiggitydogg's Avatar
gloves?? Sissy
good write-up.......I forgot to do mine
If you PM me for help, please use correct punctuation, capital letters, real words, and decent spelling. I do not want to wade through a mess...
pdiggitydogg is offline Report Post   Reply With Quote
Old 03-26-2004, 01:05 PM   #20
wisjdmhonda
wisjdmhonda's Avatar
Send a message via AIM to wisjdmhonda
Default Re: (pdiggitydogg)
I wanna do this to my hatch. Thanks for the info. p.s. i see you have some Heineken beer bottle caps on your shift boot.
wisjdmhonda is offline Report Post   Reply With Quote
Old 03-26-2004, 02:57 PM   #21
Street Ghost
Street Ghost's Avatar
Nice write-up
Which ebrake cables did you use?
Street Ghost is offline Report Post   Reply With Quote
Old 03-26-2004, 06:50 PM   #22
dohc notec
dohc notec's Avatar
Default Re: Integra Rear Disc Conversion on an EG hatch. (JDM Ninja)
good write up i have done this to my friends EK. also good chioce on the color. my car is a samba green del sol which is similar in color
to being different
My Luck Sucks
dohc notec is offline Report Post   Reply With Quote
Old 03-26-2004, 06:55 PM   #23
lsvtec hatch05
lsvtec hatch05's Avatar
Send a message via AIM to lsvtec hatch05
good write up. i have rear discs for mine but work takes up too much time for me to actually take the time to do it
lsvtec hatch05 is offline Report Post   Reply With Quote
Old 03-26-2004, 07:05 PM   #24
Ricey McRicerton
Moderator
Default Re: Integra Rear Disc Conversion on an EG hatch. (EGhatched)
Yes. You will need the rear brake lines. I used some ITR E-brake cables and can't get them to release all the way....I think...I dunno. I'm still in the middle of it and am kinda stuck.
09 SI Sedan
Old 03-26-2004, 07:16 PM   #25
toEknEEg
toEknEEg's Avatar
Send a message via AIM to toEknEEg
i JUST finished my FULL brake swap on my car including MC/booster and prop valve. ill be posting up tomorrow morning. im tired as hell right now
nice write up though look for mine tomorrow afternoon
2005 Honda CBR 600RR silver
1992 Honda Civic Cx Vogue Silver Metallic SOLD
2001 Honda S2000 Silverstone Metallic http://images.honda-tech.com/set1/smile/emthup.gif
I guess I like silver Hondas http://images.honda-tech.com/set1/smile/emsmile.gif
toEknEEg is offline Report Post   Reply With Quote
Bookmarks
92, brake, cable, clip, conversion, da, disc, disk, hatch, honda, integra, pics, rear, write, writeup
