How to Identify your ECU
Old 06-26-2007, 07:13 AM
  #51
MOVE OVER's Avatar
Default Re: (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 901, A60, C50, C51, X30, A80, L50, L51
92-5 ECUs (P28, P30, P61, P72, P91, P08)
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02, G00, G01
Auto = J50, J51, 901, 902, C50, C51, C52, A50, A51, A52, L50, L51, G51
96-00 ECUs (P2E, P2P, P2J, P72)
5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
from the patterns we can learn the following:
first letter = country of orgin
J = Japan
C= Canada
A=USA
G=Europe
second digit, if 5, 7, 9 then ecu is auto usually
third digit denotes the version/variation
I don't see how the 003 is identified though. The first digit is not a letter, so how can you identify the country of origin? I have this: 37820-p73-003 that I am trying to figure out what it is. It is an ITR ecu, but I don't know if it is USDM or JDM
Old 07-25-2007, 06:15 PM
  #52
rockysmainman's Avatar
Default Re: "How to indentify your ECU" (ki3t)
Are all OBD-1 ECU's compatible with one another?
Old 02-22-2008, 07:40 PM
  #53
96axionhatch's Avatar
Default Re: "How to indentify your ECU" (rockysmainman)
I have 2 ecu's I need help with .
1. P75 - AO2 would this be :
96-00 Integra LS/GS , US , OBD2 , 5speed . Is that right ?
2. P75 - AO4 would this be :
96-00 Integra LS/GS , US , OBD2b , 5speed . Is this right ?
Just want to make sure I am using the right one for my application .
Old 02-22-2008, 08:54 PM
  #54
JediKnight4life's Avatar
very nice, found out what i needed to know in a flash
Old 03-31-2008, 10:31 AM
  #55
Ej Girl's Avatar
Default Re: "How to indentify your ECU" (JediKnight4life)
P30-930 auto or manual?
Old 03-31-2008, 12:10 PM
  #56
Jsarv's Avatar
Default Re: "How to indentify your ECU" (Ej Girl)
little help here. i have a p13-N01??? whats the n stand for
Old 03-31-2008, 07:32 PM
  #57
RS2 FAB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockysmainman &raquo;</TD></TR><TR><TD CLASS="quote">Are all OBD-1 ECU's compatible with one another?</TD></TR></TABLE>
no, obd1 ecu's differ from make (ford ecu wont work on honda and vice versa)
and as long as you change the map to w/e motor you are running (bin file) the civic and intergra ecu's will be swapable, and with some harness work they will run on accords (the turbo accord 94-97)
Old 03-31-2008, 07:47 PM
  #58
dadsvtechonda's Avatar
bump
Old 04-23-2008, 06:20 AM
  #59
Lim Ling Yang's Avatar
Default Re: "How to indentify your ECU" (dadsvtechonda)
Hmm.
Questions:
Does eg6/SIR2 manual and auto have different ecu?
Does eg6 with tcs and eg6 without tcs have different ecu?
How to tell them apart?
Does tcs has a stand alone ecu?
Old 04-24-2008, 11:13 PM
  #60
Default Re: "How to indentify your ECU" (Lim Ling Yang)
Anyone?
Old 04-24-2008, 11:35 PM
  #61
RS-2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lim Ling Yang &raquo;</TD></TR><TR><TD CLASS="quote">Hmm.
Questions:
Does tcs has a stand alone ecu?</TD></TR></TABLE>
no iirc. they are the same except resistors in diffrent spots, a japanese ecu auto to manual swap the resistors are in diffrent spots. so it is up to outo move the resitor to the right spot.
the tcs is built in on these cars, minus integra/accord. on icivics tho the tcs is on board
auto and manual? easiest way see if the resitors are in the right spot, there is also a way to tell by the lettering.
the tcs is only remote on integras, accords, preludes. and automatics. manuals do not have tcs units Obviously
Old 04-25-2008, 12:39 AM
  #62
Default Re: "How to indentify your ECU" (RS-2)
You sure manual eg6 no tcs?
Cause I saw one manual with tcs before.
I even saw a meter cluster manual tcs around here before....
Another thing.
Can anyone provide me with the ecu codes for Manual EG6 SIR2 with TCS year 1992?
I found a 2ndhand parts shop but I need the ecu codes.
Old 04-25-2008, 12:44 AM
  #63
RS-2's Avatar
yes. you do the job of a tcs in a manual car.
Old 04-25-2008, 06:19 AM
  #64
Just checked with spare parts dealer....
They got several p30.
But I dunno which one do I need.
Mine is a 5 speed manual eg6 with tcs and abs.
Which code would I need to find?
Old 04-26-2008, 07:54 AM
  #65
Another thing.
Old 05-22-2008, 10:26 PM
  #66
Reynolds68's Avatar
Default Re: (MOVE OVER)
This is a great topic thanks!
I have just one question tho...
In my 93 CX the ECM code is P09-A00.
I think it's possibly bad and am looking for a replacement.
Suggestions?
Thanks,
Rey
Old 11-08-2008, 09:15 AM
  #67
byjl's Avatar
Default APZ ecu????a little help plzzz
HEy guys, i cant seem to find an ecu that says APZ on the side,
do u guys know if it is for a 5sp sohc vtec
Old 01-09-2009, 08:31 AM
  #68
stiffinEK's Avatar
Default Re: "How to indentify you ECU"
i have a "37820-p08-900-461-128665" and big codes: ARJ
is that an Auto ECU or Manuel ECU?
Old 01-11-2009, 11:52 AM
  #69
nello a.'s Avatar
p2p -a34
this is five speed correct?
96-98 civic ex?
can anyone verify that this is a rectangular(not square ecu) that uses plugs a,c,and d?
please help. i have 2 other p2p ecus that are not right.
i need a 96-98 5 speed civic ex computer.
Old 03-12-2009, 02:39 AM
  #70
zenon8890's Avatar
i have a PCV ecu, i dont know from what car it came out, and i'd like to know please
Old 03-12-2009, 02:48 AM
  #71
zenon8890's Avatar
and yeah its obd2a
Old 03-22-2009, 02:12 PM
  #72
jtornado's Avatar
I have a P2E-337 and I am assuming this ECU is 5sp, i've checked really hard inside the ECU and I cannot find the RP17 jumper but I did find the RP18 jumper and that is not even jumped across. So that tells me the RP18 is not for identifying if it is a Auto or Manual like the OBD1 ECU's do. Wow OBD2 ECU's are so bare inside, nothing like the OBD1 ECU's.
Old 05-20-2009, 03:37 PM
  #73
2001B18C1GS-R's Avatar
can any one tell me what ecu this goes is it obd2 a or b
Old 06-20-2009, 04:19 PM
  #74
kaleb10's Avatar
i got a manual 88 crx si , ecu reads pm7-0330 , standard ecu or not?? i know car has had a new engine but not sure bout the rest
Old 09-07-2009, 02:30 PM
  #75
FREAKBOY's Avatar
Icon3 Re: "How to indentify you ECU"
I need help identifying my ECU. The ECU code is 37820-P1K-E63 it is an EDM MC1 car with a D16B2 AUTO
Any help would be much appreciated, Just need to know if it's OBD1 or 2
Quick Reply: How to Identify your ECU
