How to Identify your ECU
#27
Re: (zcsol93)
ok, i have an ecu, I KNOW its from 96+ the whole code is 37820-p2e-l31
is it an auto or a manual? by what you say...(2nd digit) its an auto, but it dosnt work right on my auto.
#28
Re: (murmur9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 »</TD></TR><TR><TD CLASS="quote">ok, i have an ecu, I KNOW its from 96+ the whole code is 37820-p2e-l31
is it an auto or a manual? by what you say...(2nd digit) its an auto, but it dosnt work right on my auto. </TD></TR></TABLE>
the ecu is California emissions, but it sound like a 5spd ecu. I have never seen a denotation of 3 unless it was 010 or 020 or 030 variants which were all 5spd but with special programming.
#30
Re: (h23eg)
are you serious, so is this for a civic DX or not? (d16y7) I got it off ebay from so guy who sai dit would fit my y7 engine, but dosnt work. ( i think its a manual)
who knows what i have, anyone wanna buy it. lol is there any way i can get it forking for an auto d16y7?
#32
Re: "How to indentify your ECU" (ki3t)
I'm sure there is alot of you who know about and participate on
http://WWW.pgmfi.org
But it is great and has alot of this on it it is tottaly dedicated to honda's and chipping honda ecus
#37
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki3t »</TD></TR><TR><TD CLASS="quote">
PW0: 89-91 JDM B16A EF8/9 DA6-XSi
Just a small correction.
PW0 is the EDM 89-91 B16A EE8/9
At least i never saw a JDM EF8/9 with a PW0
#38
Re: (zcsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcsol93 »</TD></TR><TR><TD CLASS="quote">you missed the p29... obd1 zc (jdm) was p29-900 or p29-000... i have the 000 which i dohc zc obd1 out of 92-95 civic 5sp </TD></TR></TABLE>
damn u beat me to it.. thats what i have
#40
question, on 6th gen civics, 96-00, wounldn't the 99-00 ECUs have a different name than the 96-98's due to them being OBD2b? or did they just make the version number different?
#42
Re: (_RedRiceR_)
Remove the SMD resistors from RP17 and RP18, then jumper RP18 with a wire or 0 Ohm SMD resistor. That will convert it to manual.
The fuel and timing will be way off for the Y8 though.
#43
Re: (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">Remove the SMD resistors from RP17 and RP18, then jumper RP18 with a wire or 0 Ohm SMD resistor. That will convert it to manual.
The fuel and timing will be way off for the Y8 though.</TD></TR></TABLE>
the what and the what?? where are the PR17 and PR18, and what is a SMD resistors???
#44
Re: (Jim Truett)
how about the fuel and timing for a d15b8 with a d16y8 head???
#45
Re: (_RedRiceR_)
^^^^ You need to go to http://www.pgmfi.org and read up some on the ecu chipping and theory.
Lemme ask this... I have an ecu from a JDM EG Vi model, but the sticker is scratched off at the important part... Is there anywhere else I could look on the ecu to see exactly which model it is ?
