how many miles does your accord have on it?
#30
Re: how many miles does your accord have on it? (BlueFang08)
i got a good 178,xxx on my 94 ex. i don't worry too much about it because there's still plenty of time. i just want it to last until i can get a swap in.
#33
Re: how many miles does your accord have on it? (profroopchan)
My first accord had 198k by the time my brother blew it up running it out of oil. Had he not done that it would probably be at 240k by now easy....
My current Accord has 195k and just needs minor adjustments. Luckily I got a hook up on clutch which went out after sitting for 2 years...
#35
Re: how many miles does your accord have on it? (John Gordon)
94 Ex w/ 147k miles
silent idle, burning no oil, had to do the clutch @ ~120k. FWIW the car has never had a valve adjustment....
Probably your clutch will be the next "big" thing.
#36
I've had 3 accords, and the only reason I dont have them anymore is because of either me running into something or someone running into me.
87 lx-i auto 157k until drunk driver totaled it for me
89 lx-i 5 spd 130k needed shocks & brakes until I wrapped it around the side of a mountain the day I got it on the road
91 ex auto 175k until some ******* on cell phone rear ended me
I will have at leat 1 honda in my garage for the rest of my life!!!
#40
Re: how many miles does your accord have on it? (1994AccordSiR)
i have had 3 accords as well
91 had 136k when i sold it
94 had 68k when it got totaled last october
03 has 3800
03 has 3800
#43
my 91 wagon had 302K before the swap, my 92 4dr had 230K on it before the swap, and my 95 had 240K before its swap. all still running strong at time of transplant.
#44
Re: how many miles does your accord have on it? (JDMHatch101)
My accords odometer busted but I got it fixed, easy enough. It stopped at 159999 and I estimate about 20K has been put on it since then. So right not about 181K and no problems that aren't normal.
#49
Re: how many miles does your accord have on it? (89_LXi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89_LXi »</TD></TR><TR><TD CLASS="quote">I'm at 337,326.4 miles on my LX-i as of right now, and counting fast (just turned 336k friday before last [12th], and turned 337k this last friday [19th]). All original motor, tranny, etc (original clutch finally broke @ 321k, but disc was still within service limit).... still runs and drives like brand new, idles perfectly smooth and quiet even with a/c on, and never once broken down on me or failed to start right up. Doesn't burn or leak a drop of oil. A/C even blows 34 degrees! I still trust my car enough to get in right now and drive it anywhere without a worry.
With only 103k dude, you got nothing to worry about. It's still a baby! My moms '94 Accord EX (5spd) is at 185k something and still running perfect. It's a Honda, not a domestic.... you don't have to worry about it falling apart at 100k miles, LOL. Just do the regular maintence (regular oil changes, timing belt/water pump, belts, etc) and your car will last you virtually forever, or until somebody crashes into it
Check out the high mileage stories at http://www.hondabeat.com
Gotta love Hondas! </TD></TR></TABLE>
Wow...what kind of oil do you use? The original owner used Valvoline dino oil in my accord and changed it every 3k....needless to say, I'm using the exact same oil...if it ain't broke, dont' fix it.
C'mon guys, post up some numbers!!!!
#50
Re: (itr 00 0108)
i have a 91 accord lx 147000 on her just a week ago i had a module go bad and thats it before this car i had 2 others i wrecked the one i had 500 bucks saaved up and my uncle had a ford probe he was the only owner i bought it with a 287000 and i sold it with 300000 plus how the hell that happend dont no the only problem i had was whole in the header from rust and some weird thing with the clutch it did not go out but it was wierd and the gas gauge didnt work hahaha
