Old 03-15-2004, 06:36 PM   #1
hodsintegra23
hodsintegra23's Avatar
Send a message via AIM to hodsintegra23
Default Help!!!! Brake piston won't go back in!!!
I can't get the front brake piston to go back in at all.
I opened the Master cylinder and pushed on it but that didn't work and i tried to turn the valve but it wouldn't move. I toke the rubber cap off and that didn't work.
What do I need to do to get the piston to go back in?
DUB DUECE
hodsintegra23 is offline   Reply With Quote
Old 03-15-2004, 06:44 PM   #2
morepoop4u
morepoop4u's Avatar
iTrader Rating: (1)
Default Re: Help!!!! Brake piston won't go back in!!! (hodsintegra23)
what did you use to push the piston back in? did you use a c clamp?
!!!GARAGE SALE!!!
http://www.hondamarketplace.com/show....php?t=2817799
morepoop4u is offline   Reply With Quote
Old 03-15-2004, 06:49 PM   #3
hodsintegra23
Default Re: Help!!!! Brake piston won't go back in!!! (morepoop4u)
no i was just using some pliers.
DUB DUECE
Old 03-15-2004, 06:50 PM   #4
blackdude
blackdude's Avatar
you have to use a brake piston compressor
03 berlina black s2k turbo soon But will be slow
93 sc300 turbo soon also But will be very fast
blackdude is offline   Reply With Quote
Old 03-15-2004, 07:01 PM   #5
JakT
JakT's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (blackdude)
Just go buy a cheap *** c clamp, then put the old brake pad on the piston flat. And screw down the clamp on the brake pad and the caliper backside, this will push the piston back in with out any damage.
u dont need any special gay *** tools
JakT is offline   Reply With Quote
Old 03-15-2004, 07:05 PM   #6
Riceburner247
Riceburner247's Avatar
iTrader Rating: (1)
Default Re: Help!!!! Brake piston won't go back in!!! (JakT)
That's how I've always done my brakes. Should work fine.
XBL - Riceburner247
Originally Posted by Confuc1ous
oh, that loser riceburner got our daytime thread locked...i wish people like him would die horrible deaths
Riceburner247 is offline   Reply With Quote
Old 03-15-2004, 07:22 PM   #7
Train
Train's Avatar
Send a message via AIM to Train
Default Re: Help!!!! Brake piston won't go back in!!! (riceburner247)
i haven't changed my front pads yet, but i did my rears, and the piston doesn't "push" in, it "turns" in. i took a pair of needle nose pliers and opened them up in the groove of the piston, and turned (clockwise, i think. that would make sense), and it went in. i tried using a c clamp and it didn't work. i would assume the fronts are the same way.
WTB: driver's side window switch for my DC4 w/ tan interior. PM or email t_trainxl@yahoo.com. thanks! http://images.honda-tech.com/set1/smile/emthup.gif
Train is offline   Reply With Quote
Old 03-15-2004, 07:42 PM   #8
tC_Dragon
tC_Dragon's Avatar
Send a message via AIM to tC_Dragon
Default Re: Help!!!! Brake piston won't go back in!!! (Train)
U are right about doing the rears, that way, but totally wrong for the fronts... teh front does not have any cross in the piston and does not screw in like the rears do. The fronts just need to be compressed in... i did my pads last week and i always use simple c clamps to recompress the piston, but not on top of the pads. I compress without the pad, then put the pad on... so i won't damage the surface of the pad.
<FONT COLOR="blue"> - -My WebSite - - Pics, how to's, & more...
FS: 94-97 headlamp Assemblies
FS: 94-01 Milano Red hood
R.I.P. 9-2-04 '94Acura Integra LS Milano Red
</FONT>
tC_Dragon is offline   Reply With Quote
Old 03-15-2004, 07:46 PM   #9
Muckman
Moderator
Muckman's Avatar
iTrader Rating: (2)
ccmuckman
Send a message via ICQ to Muckman Send a message via AIM to Muckman
Default Re: Help!!!! Brake piston won't go back in!!! (pdcdragon)
Brake Pad Spreader
Big *** C clamp also works. Could also bleed the piston too Click the image to open in full size.
Integra GSR 13.5:1 GT30R 597hp build
Evo9 MR SE
Muckman is offline   Reply With Quote
Old 03-15-2004, 07:50 PM   #10
dannylDAsport
dannylDAsport's Avatar
thats how i did my front brake, works fine
dannylDAsport is offline   Reply With Quote
Old 03-16-2004, 05:22 AM   #11
JimBlake
JimBlake's Avatar
If you wedged the piston crooked, you may have already damaged the cylinder wall. If so, you need a new caliper... The C-clamp or piston compressor pushes into the bottom of the hollow piston so it goes in straight.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
Old 03-16-2004, 05:58 AM   #12
Solracer
Solracer's Avatar
Send a message via AIM to Solracer
Default Re: Help!!!! Brake piston won't go back in!!! (JimBlake)
Just open the brake bleeder screw, you can then practially push it in by hand.
Moved to http://rr-ax.com
Solracer is offline   Reply With Quote
Old 03-16-2004, 06:55 AM   #13
shardul
shardul's Avatar
Send a message via AIM to shardul
Default Re: Help!!!! Brake piston won't go back in!!! (Solracer)
u can rent a brake piston compressor at your local autozone for a few bucks ....
shardul is offline   Reply With Quote
Old 03-16-2004, 08:42 AM   #14
SecretAznMan4u
SecretAznMan4u's Avatar
Send a message via AIM to SecretAznMan4u
a c clamp, or just start the engine up, it will release the pressure in the cals. are you sure your cal. isnt locked up?
Just because you are stupid, doesn't mean you have to act stupid.
Later,
Eric
[i] 18" Hp Design EVO wheels for sale. Pm me!!![/i]
SecretAznMan4u is offline   Reply With Quote
Old 03-16-2004, 11:21 AM   #15
ThePro
ThePro's Avatar
Click the image to open in full size. on this!
I bought one from Harbor Freight Tools for 3.75 and it works like a champ.
Car Show Tips Thread
ThePro is offline   Reply With Quote
Old 03-16-2004, 11:49 AM   #16
dip-set
dip-set's Avatar
Default Re: Help!!!! Brake piston won't go back in!!! (ThePro)
u do have the brake fluid resevoir open dont you? meaning the cap is off?
dip-set is offline   Reply With Quote
2004, 97, acura, back, brake, clamp, integra, maxima, pad, piston, pistonwont, push, spreader, tl, wont
