where is the VIN number located on a B18B engine Block?
Old 03-08-2004, 10:40 AM
pattonxbody's Avatar
Default where is the VIN number located on a B18B engine Block?
i just bought car that has a b18b swap and i want to check the number on the block and make sure it is legit but i can't find it. anyone know where it is located
Old 03-08-2004, 10:49 AM
2000blackgsr's Avatar
Default Re: where is the VIN number located on a B18B engine Block? (pattonxbody)
Why wouldn't you check that before you bought the car. I don't think the VIN is on the engine, just a block number.
Old 03-08-2004, 10:55 AM
Nextelbuddy's Avatar
if its a 96 and up motor the VIN will be right above the oil pan on the block behind the header.. its riveted on a plate just like on the dash and tranny.... if this is a 95 and below motor you arent going to find one on those motors..
Old 03-08-2004, 10:56 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: where is the VIN number located on a B18B engine Block? (nextelbuddy)
94 and 95 integra motors don't come with VIN numbers. just the block number.
tollickj
04-12-2013 11:37 AM
junior_tm
03-30-2009 06:07 PM
lostsonta
10-02-2006 02:15 PM
pattonxbody
04-22-2004 11:09 AM
civicgsr91
04-17-2003 10:07 PM
Quick Reply: where is the VIN number located on a B18B engine Block?
