F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
Old 04-12-2011, 05:24 AM
  #2001
boostedluda's Avatar
Default Re: F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
Funny i came acrossed this...bought my prelude 8 years ago and it had a f22b block in it with the h23 head on it...i bought the h22 head thinkin it would fit no problem..i was 16 and new nothing..lol..went through all of these problems and after some time i drove that setup for almost 2 years..went quite well for what it was..i now have built and boosted h22a..17psi and lovin it...
Old 05-20-2011, 08:05 PM
  #2002
vtec'n cb7 f22's Avatar
Prelittlelude just wanted to give Props on being the original Vtec G series !!!!! And Chris Bolis is an a*s bag he straight up took from You, Pirate Sam i am , flyrod ,and others that contributed to the G series
Old 06-30-2011, 03:15 PM
  #2003
vtexas936's Avatar
in need of some major help
this is my first g-series type motor so any stupid questions give me a break
its a f22b2 block with a h23 head
not sure exactly on the head thats what the previous owner told me
but my problem is the head gasket is blown or leaking around timing belt area
i have read thats a tricky spot
i wanna know what i need to do to get the leak stopped? new head gasket? if so which one?
reply or pm whichever
thanks
Old 07-02-2011, 09:21 PM
  #2004
accordmikchael's Avatar
I love the thread its helped a lot with my G23.i give u guys mad props. i plan on putting the hybrid G23 in the car tomorrow.ill keep u posted on how it goes
Old 09-20-2011, 08:01 PM
  #2005
KurtPierce024's Avatar
Ok. I tried to read the whole thread and did not make it very far... This thing is huge. 81 pages... wow.
I have some questions that I am sure have already been answered but I can spend days reading through all of this in my spare time. I need my car this weekend.. lol. I have the money to get the job done but I need some info... I have a 95 accord EX and I have no engine in it right now. I have the original F22b1 block but the head is gone. Now I have a 2001 prelude head and I am trying to get this to work.
Can the h22 head be bolted to the f22 block with f22 pistons with no internal work or machining?
And! will it run fine with the stock 95 accord f22 ECM and wiring harness?
Old 09-21-2011, 07:35 AM
  #2006
GhostAccord's Avatar
You don't want to take the time to read but you expect someone to take their time and spoon feed the information for you.....
I'll answer your two questions
1. yes it will bolt on without doing internal work. However, your compression will be lower than the stock F22B1's 8.8:1. IIRC it is around 8.4:1 = loss of power. You need to plug an oil port and you will also have timing issues. That is unless you match up all of your drive gears or match your belt tooth count to your gear center to center measurement. I'm not sold on the fact that you need to swap the water pump gear though. IIRC the timing belt issue was covered in this thread.....
2. Run fine...what do you consider fine? It will probably run but it will be far from optimum. P0A VTEC cam crossover with H22 VTEC cams..... Think about it!
IMO, the people who get this hybrid build running efficiently spend the time and money to do it properly. It's not a swap that you can just drop on the head and go. Hence why there are 50+ pages to this thread.
Old 01-05-2012, 10:35 AM
  #2007
ark love's Avatar
Default Re: (biglew)what kind of clay do you use becouse i just did a g22 f22 block h22 head
Originally Posted by prelittlelude
nope, this is with a f22b2 block out of an 1996 accord i found in the junkyard, i got a nasty good deal on it, with on 60k miles on it.
my AEBS head studs came today which is nice, now im just waiting for the head gasket and time to re assemble.
the f22 has the same crank and rods as the h23, just a smaller bore of 85, the cyclinders are also cast iron. if all goes well i wouldn't see any reason why you couldn't over bore to 86mm, or even just change the pistons to reach you desired compresion ratio. i went with the 50 dollar route to get me to 9:1 , because i didn't want to mess with the bottom end,
i guess also you could put h22 crank and rods in a f22 block, and run your choice of forged pistons and put the h22 head on...
this is all speculation of course, but i have clayed and assembled/disassembled the motor to be several times, so this isn't just theory, its fact, ive been playing with it for a month or 2 now,
Old 01-05-2012, 10:44 AM
  #2008
ark love's Avatar
i have an 91 accord Canadian car had the f23 in it ran good and fast won alot of races
Old 01-05-2012, 10:49 AM
  #2009
ark love's Avatar
the car is light and i put the g22 togather run good idles at 1000 but i have the oil comeing out of the head
Old 01-05-2012, 10:51 AM
  #2010
ark love's Avatar
i plan on doing the f23 to g23 will i have too clay the block
Old 01-05-2012, 10:57 AM
  #2011
ark love's Avatar
i am going too put photos of the f23 in my car and the g22. i put the g22 in my brothers car if i don't like it he can have it boost and all
Old 01-05-2012, 11:03 AM
  #2012
ark love's Avatar
If someone can send some photos on how too clay the block or what it looks like that would good
Old 01-15-2012, 01:24 PM
  #2013
mudpuppy4life's Avatar
is it just my computer or this website i cant view the pics...all im getting is the little white square
Old 01-16-2012, 07:11 PM
  #2014
carnage210's Avatar
dam crasy build
Old 01-21-2012, 03:38 PM
  #2015
jusabill's Avatar
new guys....like ghost said u need to read the whole thread....all of ur questions probably have already been answered......this thread has been up since 04!!!
Old 03-17-2013, 02:58 PM
  #2016
surrounder123's Avatar
Hello,i am new here.I have lude f20a4 sohc non vtec and scraped accord h22a vtec no compression pistons rings faulty.And i'm thinking to put h22a head on my f20a4 block.
Is it possible?
Old 03-21-2013, 06:32 PM
  #2017
donkeykongvtec's Avatar
Reading owns people on this thread!
Old 04-02-2013, 02:18 PM
  #2018
g22 swap civic's Avatar
ok got a question we recently did the g22 swap and cant get my vtec to engadge any body have any answers wef wired vtec up correctly so someone please help
Old 04-03-2013, 09:31 AM
  #2019
can anyone help with my problem we got my g 22 running and wired up vtec but its not working
Old 05-08-2013, 05:22 AM
  #2020
ludelover86's Avatar
Default Re: The cats out of the bag: F22b2 block+H22a1 head
Hi, I want to do a swap like you've done with yours, I've got an F22B DOCH motor but want to put the vtec head onto it, will any of the vtec heads match up with the F22B block or is it a specific head that will match up?
Cheers
Old 02-23-2014, 05:23 PM
  #2021
Jsuydam's Avatar
10 years later to the day, i am getting the info here for it. thank you.
Old 02-26-2014, 07:54 AM
  #2022
prelittlelude's Avatar
I really don't remember when the last time i was on here, but its been a long time,
About 3 years ago I was running my turbo setup at the track (not hooking up but trapping 110mph) and one run i money shifted 3rd to 2nd and the motor hit probably 12,000 rpm. I bent all 8 exhaust valves, got towed home
So i ripped the head off rebuilt it. I did notice that oil presure was down 3 or 4 PSI at idle, but everything sounded good and I ran it for another 2 years until I started hearing a slight rapping in the bottom end.
In hind sight probably what happened is when i over reved the motor 3 years ago the rod bolts stretched lossening up clearences, eventually the lower oil preusre took its toll.
With the car still running i decided the noise was too much and tore the motor down. All mains were spun and the rod bearings were in tough shape,
The block, crank, and rods were all junk. Pretty good for a 150$ junkyard block! Never broke a ring landing and put more miles on it than I can count
As of right now, I have another F22/H22 in the car, and redoing the turbo setup,
Old 01-18-2015, 08:28 AM
  #2023
Supaflies's Avatar
Will this fit in any civic? LOL
Old 02-22-2017, 04:31 PM
  #2024
Seamus Savage's Avatar
Hi so I have a 96 Honda Accord f22b2 and I've been thinking about hooking it up mechanically for better performance and was wondering if this would be a good way to approach this future build
Old 02-22-2017, 08:31 PM
  #2025
TimiK's Avatar
full engine swap would be better
Quick Reply: F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
