Old 02-18-2004, 10:09 AM   #1
hondaeg95
hondaeg95's Avatar
Default My front end shakes when I hit the brakes.
I have a question do you think my rotors need cut in the front if my brakes pulse when i step on the brake. It use to do this a lot worse before i had rear drums but, i recently changed to rear disc but it still does it, but not as bad. Or could this mean my lines need to be blead again? If anyone has any input I would appriciate it.
hondaeg95 is offline   Reply With Quote
Old 02-18-2004, 10:10 AM   #2
RTE117
RTE117's Avatar
Default Re: My front end shakes when I hit the brakes. (hondaeg95)
sounds like warped rotors, or bad hub bearings.. But that's most def. a sign ya need to check the rotors out.
RTE117 is offline   Reply With Quote
Old 02-18-2004, 10:17 AM   #3
jolt-tsp
jolt-tsp's Avatar
Send a message via ICQ to jolt-tsp Send a message via AIM to jolt-tsp
Default Re: My front end shakes when I hit the brakes. (IDriveAHonda)
Could also be an alignment issue. Does it shake at high speeds at all when you're not braking? If not, then it's probably just the rotors
1988 CRX Si
2002 RSX Type-S - yay for tranny and clutch problems and for burning oil!!
2002 Odyssey EX - sexiest vehicle ever made
jolt-tsp is offline   Reply With Quote
Old 02-18-2004, 10:18 AM   #4
mattssi
mattssi's Avatar
Send a message via ICQ to mattssi Send a message via AIM to mattssi
I used to have this problem in my old 4g hatch! It could be a combination of warped or woren rotors, and a need of a alignment job!
"Don't draw fire; it irritates the people around you." - Your Buddies
mattssi is offline   Reply With Quote
Old 02-18-2004, 11:02 AM   #5
dwnthehatch
dwnthehatch's Avatar
iTrader Rating: (1)
Send a message via AIM to dwnthehatch
Default Re: My front end shakes when I hit the brakes. (mattssi)
Get your rotors turned or buy a new set. Replace the brake pads while you are at it. Did you change the proportion valve when you swapped to rear discs?
dwnthehatch is offline   Reply With Quote
Old 02-18-2004, 11:48 AM   #6
greebler
greebler's Avatar
Send a message via AIM to greebler
Originally Posted by IDriveAHonda
sounds like warped rotors.
NO NO NO
Take the rotors off and re-surface them, as long as they are in spec. If not Brembo Blanks are the best for the $$.
Look at my sig
[PROJECT] 94 Integra GSR w/ 98' B18C5
greebler is offline   Reply With Quote
Old 02-18-2004, 12:04 PM   #7
Millenion LTD.
California,The only state
Millenion LTD.'s Avatar
Default Re: My front end shakes when I hit the brakes. (greebler)
umm, yes there is such thing as a warped rotor, where do you think the damn term "warped rotor" came from??? ...maybe because its WARPED?
yes you CAN resurface them but what is it before its resurfaced???.....WARPED! tah dah !!
i want a cookie now
Millenion LTD. is offline   Reply With Quote
Old 02-18-2004, 12:15 PM   #8
Jimmy
Global Moderator
1994 Acura Integra
Jimmy's Avatar
iTrader Rating: (2)
dangjimmy
Default Re: My front end shakes when I hit the brakes. (EH2_LS_TURBO)
i want a cookie now
FYI..there is a such thing
2004 Acura TL - Daily
1994 Integra RS - Track car
instagram: jimmydudley
my build: 94 Integra RS sloow build-up
Originally Posted by Danza
The Man can't hold you down when you're flossing the bright green belts dawg
Jimmy is offline   Reply With Quote
Old 02-18-2004, 04:07 PM   #9
dampachi
dampachi's Avatar
Default Re: My front end shakes when I hit the brakes. (USDMDC2)
mine also is currently shaking when i brake. that's why imma slap on some brembo blanks asap.
D16 powered hatch [img]http://images.honda-tech.com/set1/smile/mad.gif[/img]
dampachi is offline   Reply With Quote
Old 02-18-2004, 04:14 PM   #10
darkjedi022
darkjedi022's Avatar
Default Re: My front end shakes when I hit the brakes. (dampachi)
mine studder when i brake hard...but also would be that i haev slotted rotors ??
darkjedi022 is offline   Reply With Quote
Old 02-18-2004, 04:57 PM   #11
jolt-tsp
jolt-tsp's Avatar
Default Re: My front end shakes when I hit the brakes. (darkjedi022)
Do you have ABS?
1988 CRX Si
Old 02-18-2004, 04:59 PM   #12
TwoSaints
TwoSaints's Avatar
Send a message via AIM to TwoSaints
Default Re: My front end shakes when I hit the brakes. (jolt-tsp)
if he is just noticing it, I doubt its ABS, maybe im wrong.... I would definatley say its a warped rotor or two.
TwoSaints is offline   Reply With Quote
Old 02-19-2004, 06:12 AM   #13
darkjedi022
Default Re: My front end shakes when I hit the brakes. (EGCoupe)
si dont have abs
Old 02-19-2004, 06:19 AM   #14
Noe Kozz
Noe Kozz's Avatar
Send a message via AIM to Noe Kozz
si dont have abs
yes they do, depends what year
this space for rent
Noe Kozz is offline   Reply With Quote
Old 02-19-2004, 06:34 AM   #15
shauniewalnuts
shauniewalnuts's Avatar
***and make sure you torque your wheels to 85 ft.lb next time***
.:Shaunie Walnuts:.
UPS F'in Sucks
1997 Civic Ex missed
2000 Silverstone S2k
1991 Ef HatchSOHC Monster
1993 Teal Eg Hatch - passed down
1995 DX d15 turd coupe - gone, out running 17s somewhere
1987 Civic Si - sold
My Vouch Thread!!!
Im on the Good Sellers List http://images.honda-tech.com/set1/smile/emthup.gif
shauniewalnuts is offline   Reply With Quote
Old 02-19-2004, 07:43 AM   #16
samdawgsol
samdawgsol's Avatar
Send a message via AIM to samdawgsol
Default Re: My front end shakes when I hit the brakes. (shaun311)
Their warped, mine did the same thing. Got new regular ones for 35 bux a piece and problem fixed.
Whats the difference between resurfacing a rotor or turning it?
"Sir, Custard was a Pussy."
93 del sol Si
samdawgsol is offline   Reply With Quote
Old 02-19-2004, 07:47 AM   #17
kommon_sense
kommon_sense's Avatar
Send a message via AIM to kommon_sense
i want a cookie now
not quite rotors seldom warp. The "warping" is usually due to an uneven distribution of brake pad material on the surface of the rotor. Resurfacing the rotor cleans up the faces so you are back down to fresh metal and have cleaned off the uneven deposits.
With that said, rotors are cheap enough, that it may be easier to just get a set of brembo blanks and install them yourself than to get the current rotors turned.
Intentionally left blank...
kommon_sense is offline   Reply With Quote
Old 02-19-2004, 07:47 AM   #18
kommon_sense
Default Re: My front end shakes when I hit the brakes. (samdawgsol)
same thing.
Old 02-19-2004, 07:53 AM   #19
dthrone
dthrone's Avatar
Try this put you car in the Air..... Grab the Tire with you left hand and your right hand on the other Side Shake it Left to right...If there is any play in the Left to right you got a bad tie rod.....then put your left hand on top of the tire and right hand on bottom of the tire.....if it has any play in it it could be your wheel beering or upper or lower ball joint..... witch to tell if its the ball joints just look at them while some one shakes them(do all of this on both sides of the car!).....If you have no loose front end parts its more than lickley the rotors are warped in that case they have to be replaced.......you can not cut warped rotors sorry dude.... but you own a honda and breaks are cheep so you in luck! hoped i helped
2000 Si (Stock)
92 CX "The Hatch" (SOLD) 369whp 266ft-lbs of tq - 11.223@125.99mph
dthrone is offline   Reply With Quote
Old 02-19-2004, 08:01 AM   #20
5thGenCivicKid
5thGenCivicKid's Avatar
Default Re: My front end shakes when I hit the brakes. (ANOTHER_JDM_EG6)
its deff the rotors i had this problem also but what it is, is the rotor it self its looose and everytime u break it going back and forth becuase who every put it on before that didnt put it on right
5thGenCivicKid is offline   Reply With Quote
Old 02-19-2004, 08:11 AM   #21
Nextelbuddy
Nextelbuddy's Avatar
check these thigns they are true and cn help you out a lot
Nextelbuddy is offline   Reply With Quote
Old 02-19-2004, 11:00 AM   #22
Millenion LTD.
Default Re: My front end shakes when I hit the brakes. (kommon_sense)
same thing, you just explained the technical part of it
i get rotors turned for FREE all day everyday
Old 02-20-2004, 08:56 PM   #23
darkjedi022
99-00us si dont have abs..they have 4 disc brrake only......i did the air tirck but its fine ....so now what ??
Old 02-23-2004, 09:46 AM   #24
staticrex
Do I really have to disconnect the SRS before doing any work on my front brakes? Not trying to steal the post.
Thanks
Mike
06 VW GTI
1992 Prelude Si (sold)
H22a swap
[B]BB Sqaud Member #23 [/B] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
"he who lends money to a friend stands to lose both"
staticrex is offline   Reply With Quote
Old 02-24-2004, 03:19 AM   #25
JimmyAtlantis
JimmyAtlantis's Avatar
Send a message via AIM to JimmyAtlantis
Default Re: My front end shakes when I hit the brakes. (staticrex)
You guys are talking about warped rotors, but I found this on http://www.overboost.com
Originally Posted by [url="http://www.overboost.com/story.asp?id=1215"
http://www.overboost.com/story.asp?id=1215[/url]]Now we've all discussed brake shimmy and most people thing that's due to brake rotor warpage. Well, warpage is only about 20% of the equation. Most of the time, brake shimmy is due to rust or dirt between the wheel and hub or rotor and hub because even a small spec of dirt will cause the wheel to be mounted at an angle. You pop the wheels on my car and you'll see a very dirty car with very clean hubs—60,000 miles and dead smooth brakes.
Goodbye 94 EJ2
Hello 94 EJ1
Exedy Stage 1 organic clutch - 11.75 lb. Prostreet GenII forged one piece flywheel
WTB (if the price is right) - passenger side window motor
MY VOUCH THREAD: http://www.honda-tech.com/zerothread?id=810047
TEAM DADDY member #2
JimmyAtlantis is offline   Reply With Quote
applied, brake, brakes, breakes, breaks, car, cars, civic, end, front, hit, honda, shake, shakes, shaking, wobbles
