[FAQ] how to install sohc camshaft
Old 01-29-2004, 07:16 PM
matt j's Avatar
Default [FAQ] how to install sohc camshaft
Alright here is my little writeup for the sticky up top on how to install a camshaft, i used the exospeed race A6 cam. Please make sure that the car is set at TDC (top dead center) before any removal of camshaft. and also i am not responsible if you **** your car up because you didnt know what you were doing. so please be careful and if you have no mechanical knowledge. DO NOT PERFORM THIS BY YOURSELF!
This is how the head should look after removal of the rocker arm assembly and old camshaft.
insert the cam into the proper key marks on the distributor, make sure while in this process to replace the cam seal ($3.99-$4.99 at napa), and put the cam into the key marks on the cam gear and put on timing belt.
Re-install the rocker arm assembly and follow torque specs from manual
NOTE: make sure that you do a valve adjustment before the motor is started to avoid any valve clearance issues.
Re install valve cover and spark plug wires ( remember the silver nuts to bolt down the valve cover are only 7lb-ft of torque do not over tighten or they will strip)
Hope this helps some people when they do a cam in their single cam motor.
Thanks goes out to Wil at exospeed, and to wells fargo for letting me have the money for the cam in my bank account!
Old 01-29-2004, 07:37 PM
tilt's Avatar
Default Re: [FAQ] how to install sohc camshaft (matt j)
Dont forget it is a good idea to use assembly lube on the cam.
Also from what I've gathered, when you first start it up you should not let it idle. When you break it in try to keep it at about 2krpm for about 15 mins.
Old 01-29-2004, 07:39 PM
X-Static's Avatar
Default Re: [FAQ] how to install sohc camshaft (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">Dont forget it is a good idea to use assembly lube on the cam.
Also from what I've gathered, when you first start it up you should not let it idle. When you break it in try to keep it at about 2krpm for about 15 mins. </TD></TR></TABLE>
man that seems tedious (sp?)
good write up matt i just wish there was more of the inbetween steps..i guess thats what they Haynes/Chiltons/ect are for...
Old 01-29-2004, 07:44 PM
MLogan's Avatar
Default Re: [FAQ] how to install sohc camshaft (X-Static)
It really isn't hard at all. I should know after breaking the damn timing gear bolt off in the camshaft
Old 01-29-2004, 07:46 PM
matt j's Avatar
well its pretty self explainitory once the valvecover is off, i just snapped a few shots before i stuck the cam in. I just used some of the motor oil from the head and put it on the cam. If there is any questions i will be more than happy to help.
Old 09-02-2004, 05:51 PM
markdman's Avatar
put each cylinder at TDC before your dial in the valve clearances.
Old 09-02-2004, 05:55 PM
Pirate General...YARRRR
Ass$nyper's Avatar
Default Re: [FAQ] how to install sohc camshaft (markdman)
my dumb *** was able to pull it off so its not too hard lol.
Good FAQ man! sounds like you enjoy your new bumpstick
Old 09-02-2004, 06:05 PM
NFM_Dm's Avatar
Default Re: [FAQ] how to install sohc camshaft (Ace$nyper)
what does the red hose in this pic connect to ? could u get a better pic ?
the king.
06-21-2008 01:39 PM
NathanMorris
03-20-2007 08:58 PM
Red_Si
04-12-2004 09:28 PM
Tad
10-26-2003 01:43 AM
J-Spec EG Sleeper
01-09-2003 09:23 PM
Quick Reply: [FAQ] how to install sohc camshaft
