> Acura Integra
Old 01-14-2004, 11:58 PM   #1
Dan GSR
Dan GSR's Avatar
Send a message via AIM to Dan GSR
Default How to: 11 inch brakes on 3rd gen
I started this thread, because I've seen a lot of wrong information, and been getting way too many PM's about this, I will edit this thread as I add/correct stuff.
This will work for all non ITR 3rd generation integras, and 99-00 Civic Si
and other civics with integra or Si front knuckles
First you will need a caliper from
Accord V6
or
ITR
pads for an ITR, I reccomend you call http://www.cobaltfriction.com , andie will reccomend a great pad for you
Then you will need some 11" rotors
I chose to buy them from brian at fastbrakes
or you can buy prelude vtec rotors and have them redrilled to 4x100
the center bore is perfect for our integras
( I have not confirmed fitment, but I know Corrado G60 rotors are 11" and 4x100)
also keep in mind this will require a minimum of a 15" rim
so your spare will not fit in the front anymore
Now the problem,
the calipers are not a direct bolt on
the bolt spacing for the caliper bracket is the same, but offset is incorrect
if you were to try to bolt it on directly, the rotor would hit the inside of the caliper bracket, and the wheel would not spin
Solution:
grind about 2~3mm off the entire inside face of the caliper bracket
this will give you the clearence you need
keep in mind I'm using prelude rotors, if you use thicker rotors like legend rotors you will have to remove more material
(another solution that i have thought about but have not been able to confirm, putting a spacer between the hub and the rotor (back of the rotor), this would center the rotor in the caliper better, and not weaken the caliper bracket by thinning it)
You will need some basic hand tools, brake fluid, vise, 7" angle grinder, impact screwdriver to take off old rotors, new crush washers for brake lines (4x)
Get all of your parts together
jack up the car onto stands
take front wheels off
take off brake line
unbolt stock caliper
use impact screw driver to take off old rotors
test fit new 11" rotor
test fit new ITR or equilvalent caliper
you will then see what the problem is
take caliper off the slide pins
and put caliper bracket in a vise and grind down about 2mm of material off the inside of the caliper bracket, see diagram, side with the red arrow
it is not important that you take off exactly 2mm throught the whole caliper bracket
what is important is that you take off enough material so that the rotor will not make contact with the caliper bracket
also, some people on honda-tech have said to grind the outside of the caliper bracket, and this has worked for some people, let me explain why I think this is wrong,
1st the outside of the bracket is the mating surface to the knuckle, if this is is ground down it must be 100% even, which is very hard to do with a angle grinder when it is skipping all over the place, if the cut is not even to a high tolerance the brake pad will not hit parallel with the rotor's surface
2nd if you grind the outside you are effectively bringing the piston away from the rotor, this means the piston will have to travel out farther to come into contact with the rotor, this could cause a problem as the pads wear and the piston is extending out more than it is designed to
now back to grinding
this is a trial and error job
you take off some material, test fit, see where more material has to be removed, and then grind more.....repeat
once the clearance cut is made,
bolt up the caliper,
put in the new pads from cobalt friction
reinstall the brake line with the new crush washers (very important)
flush the brake system ( might as well order this from cobalt too)
go brake in your pads ( beat the shit out of them)
BEFORE
AFTER
Modified by Dan GSR at 7:10 PM 3/8/2005
Frost White 95 LS... SOLD
2006 VW GTI
R-Speed
Dan GSR is offline Report Post   Reply With Quote
Old 01-15-2004, 12:11 AM   #2
Boges
Boges's Avatar
Send a message via AIM to Boges
Default Re: How to: 11 inch brakes on 3rd gen (Dan GSR)
Nice write up dan.
Boges is offline Report Post   Reply With Quote
Old 01-15-2004, 12:18 AM   #3
riceball777
riceball777's Avatar
nice write up
you can also use nsx and legend calipers. they are 2 piston calipers. The legend calipers are the the best ones though
91 LS integra 400+whp 300+tq boosted lsvtec, 91octane. 500+whp race gas
03 evo 400whp (91 octane)
2002 GPW s2000 bone stock
riceball777 is offline Report Post   Reply With Quote
Old 01-15-2004, 12:20 AM   #4
Dan GSR
Dan GSR's Avatar
Default Re: How to: 11 inch brakes on 3rd gen (riceball777)
i wish i had buttloads of money so i could test out the spoon calipers....i bet i can make them fit
2006 VW GTI
R-Speed
Old 01-15-2004, 02:51 AM   #5
NA gs-R 05 C
Guest
Posts: n/a
great write up, this will help quite a few ppl out.
Old 01-15-2004, 07:38 AM   #6
TheGSRGuy
TheGSRGuy's Avatar
Send a message via ICQ to TheGSRGuy
Spoon calipers are pure JDM-bling. They're made by Nissin, BTW, who makes our OEM brake components. You're paying for the name and the bright color.
TheGSRGuy is offline Report Post   Reply With Quote
Old 01-15-2004, 07:43 AM   #7
mEr
mEr's Avatar
Default Re: How to: 11 inch brakes on 3rd gen (TheGSRGuy)
but in all reality thats why people buy spoon to begin with, the name!!LOL
mEr is offline Report Post   Reply With Quote
Old 01-15-2004, 07:44 AM   #8
Dan GSR
Dan GSR's Avatar
no i'm paying for the 4 piston monoblock caliper that utilizes cheaper stock rotors
i'd get a stoptech setup but i don't have that kind of budget, for rotors, pads, wheels, tires, all of which are more expensive with that kind of system
2006 VW GTI
R-Speed
Old 01-15-2004, 08:23 AM   #9
AnotherGSR
great write up.. I've wanted to do the same thing but have gotten alot of wrong info in it too.
AnotherGSR is offline Report Post   Reply With Quote
Old 01-15-2004, 08:57 AM   #10
Project SSAP1
Project SSAP1's Avatar
Send a message via AIM to Project SSAP1
dont mean to hi-jack the thread...but u should add on some legend 2 pisont calipers...like the ones i have for sale...holla at me mang!!
'01 BMW E46 M3 Jet Black <---Sex on wheels http://images.honda-tech.com/set1/smile/emcocktl.gif
'01 S2000 Silverstone <--- My Track Hoe
'97 Integra GSR http://images.honda-tech.com/set1/smile/emwink.gif Black sold
'95 Integra RS Thunder Grey sold
'96 Accord Coupe Heather Mist sold <--The car that made it happen http://images.honda-tech.com/set1/smile/emsmilep.gif
Project SSAP1 is offline Report Post   Reply With Quote
Old 01-15-2004, 09:00 AM   #11
Vu
Vu's Avatar
Send a message via AIM to Vu
So we don't need any custom caliper relocation bracket? All we do is modify the bracket from the caliper we choose, correct?
"There are five possible operations for any army. If you can fight, fight; if you cannot fight, defend; if you cannot defend, flee; if you cannot flee, surrender; if you cannot surrender, die. " - Sima Yi "Romance of the 3 Kingdoms"
Vu is offline Report Post   Reply With Quote
Old 01-15-2004, 09:04 AM   #12
Big Teggie
Big Teggie's Avatar
Send a message via AIM to Big Teggie
Very very good write up
Here is a pic of my conversion, Since then I have painted the top hats of the rotor so I dont get that rust look.
Big Teggie is offline Report Post   Reply With Quote
Old 01-15-2004, 09:28 AM   #13
Dan GSR
Dan GSR's Avatar
Default Re: How to: 11 inch brakes on 3rd gen (Vu)
thats right
no custom brackets
2006 VW GTI
R-Speed
Old 01-15-2004, 09:42 AM   #14
(JON)
(JON)'s Avatar
good write up dan. i just did the conversion on my buddies eg, but we used the legend rotors and calipers.
(JON) is offline Report Post   Reply With Quote
Old 01-15-2004, 10:29 AM   #15
PatrickGSR94
PnP Hater Moderator
1994 Acura Integra
PatrickGSR94's Avatar
Send a message via AIM to PatrickGSR94
Just a few things...
I'm pretty sure my spare tire uses a 15" wheel, I think all G3 Integras come w/ 15" spares.
A spacer behind the rotor is probably only a good idea if you have extended lugs.
Also correct me if I'm wrong but isn't there the caliper by itself, which bolts to a mounting bracket, which bolts to the spindle? So are you grinding material off that mounting bracket, or off the actual caliper itself?
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline Report Post   Reply With Quote
Old 01-15-2004, 10:34 AM   #16
96AllMotorDC2
96AllMotorDC2's Avatar
nice write up. about how much do you think its gonna cost me to do this if i buy the new rotors, rather then re-drilling the prelude rotors.
96AllMotorDC2 is offline Report Post   Reply With Quote
Old 01-15-2004, 12:24 PM   #17
Dan GSR
Dan GSR's Avatar
Default Re: How to: 11 inch brakes on 3rd gen (PatrickGSR94)
I am grinding the mounting bracket...
2006 VW GTI
R-Speed
Old 01-15-2004, 12:26 PM   #18
Dan GSR
Dan GSR's Avatar
Default Re: (96AllMotorDC2)
I don't understand your question
yes you have to buy new rotors
and there is not a honda/acura rotor that is 11" and 4x100
so you must modify another 11" rotor to 4x100 to fit
or you can buy the rotors from brian at fastbrakes, i belive they are around $60 a piece
2006 VW GTI
R-Speed
Old 01-15-2004, 12:41 PM   #19
BassBoy19
calipers from 97-00 crv will fit.... got that on my older G2 teg...sleeper type-R brakes
If it doesn't make you faster don t buy it...
BassBoy19 is offline Report Post   Reply With Quote
Old 01-15-2004, 12:47 PM   #20
Jasper_db1
Jasper_db1's Avatar
Send a message via AIM to Jasper_db1
Good writeup, this will also work on 90-93 DA Integras.
Everything I touch turns to shit. I have the anti-Midas touch.
1995 Yamaha YZF600R / 2002 Honda RC51 / 1995 Kawasaki KLR650
Jasper_db1 is offline Report Post   Reply With Quote
Old 01-15-2004, 01:25 PM   #21
Seedc2
Seedc2's Avatar
Default Re: (Dan GSR)
thanks dan
Vouches
A fool and his money are soon parted
Seedc2 is offline Report Post   Reply With Quote
Old 01-15-2004, 01:54 PM   #22
rtype11
rtype11's Avatar
wow how timely, i am selling the rotors
http://www.honda-tech.com/zerothread?id=734622
I used the method of bench milling for acuracy the back of the bracket, this ensures that the rotor is spaced evenly between the pads and that pressure is distributed and applied evenly. I can imagine pulsating on light application of the brakes with your method, can you tell me if you experience this as I thought that may work in 98.
P.S. atleast in Canada I can get ITR calipers from the dealer with a fake ITR core exchange, someone might want to try it out, get your very dirty or similar looking calipers and exchange em for ITR ask for '97 they're cheaper. works out to 80USD a side if I remember, I have had this mod since 98. Also Prelude and legend just based on part number are more expensive than ITR atleast the dealer I have tried this out on. NSX was cheaper than legend.
Your car is so slow, who built it Gippetto?
96 LS T60-2 powered nightmare
02 SUZUKI GSXR 600 - RIP Aug 22/03
rtype11 is offline Report Post   Reply With Quote
Old 01-15-2004, 02:30 PM   #23
Your Epitaph.
Your Epitaph.'s Avatar
Default Re: How to: 11 inch brakes on 3rd gen (rtype11)
nice write up man.
<FONT SIZE="1/4"><FONT COLOR="grey">'98 A4 1.8</FONT><FONT COLOR="red">T</FONT></FONT>
<FONT SIZE="1/44"><FONT COLOR="grey">'01 F4i</FONT></FONT>
Your Epitaph. is offline Report Post   Reply With Quote
Old 01-15-2004, 02:32 PM   #24
Honda Hick
Honda Hick's Avatar
Send a message via AIM to Honda Hick
Do the '95 Legend GS calipers fit too with the same modifications? Why would you choose an Accord or ITR single piston caliper over a Legend 2 piston caliper?
Honda Hick is offline Report Post   Reply With Quote
Old 01-15-2004, 02:40 PM   #25
Jasper_db1
Jasper_db1's Avatar
Default Re: How to: 11 inch brakes on 3rd gen (Honda Hick)
Weight would be one reason.
Bookmarks
11, 11inch, 2006, bolt, caliper, corrado, gti, honda, inch, mounting, rear, rotor, rotors, size, vw, wheel
