Old 01-09-2004, 01:30 PM   #1
Campee
Campee's Avatar
Send a message via AIM to Campee
Default What can you use to remove a stuck spark plug?
Can you use penetrating fluid, WD40, etc to remove a spark plug that the previous owner jammed in too hard and now won't come out? Or does anyone have any other suggestion for what to use?
Campee is offline   Reply With Quote
Old 01-09-2004, 02:05 PM   #2
chads
1997 Honda Civic
chads's Avatar
Default Re: What can you use to remove a stuck spark plug? (Campee)
it sounds like it was cross threaded. if so i don't know how to fix it but im sure its very expensive. Click the image to open in full size.
out for a while
chads is offline   Reply With Quote
Old 01-09-2004, 02:06 PM   #3
Evs-One
Solbros Owns Me
Evs-One's Avatar
Send a message via ICQ to Evs-One Send a message via AIM to Evs-One
Default Re: What can you use to remove a stuck spark plug? (FlamencoEsi)
just use a breaker bar...
worst case scenerio you have to pull the head and drill it out
Evs-One is offline   Reply With Quote
Old 01-09-2004, 03:56 PM   #4
Campee
Campee's Avatar
Default Re: What can you use to remove a stuck spark plug? (Emerika)
Well, it's not frozen... it's just really hard to remove and I wanted to knock it loose w/ something first.. thought I could have used one of the liquids i mentioned earlier. Are those cool to use or no?
Old 01-09-2004, 03:58 PM   #5
Evs-One
Solbros Owns Me
Evs-One's Avatar
it's fine if you use those those liquids...sure Click the image to open in full size.
Old 01-09-2004, 05:30 PM   #6
BrockGrimes
BrockGrimes's Avatar
I've used a couple drops of 10w/30 to help out a tuff plug.
On a side note if you get one thats stuck, stick a piece of dry ice on the plug, it shrinks the metal in the plug and helps loosen it up.
[img]http://images.honda-tech.com/set1/smile/h-emblem4.gif[/img] [B]If it isn't broke, MOD IT!!![/B] [img]http://images.honda-tech.com/set1/smile/h-emblem4.gif[/img]
BrockGrimes is offline   Reply With Quote
Old 01-09-2004, 06:07 PM   #7
lohatch
lohatch's Avatar
they make anti-seize stuff to put on your plugs so they dont stick for future reference. hopefully your threads arent screwed up....
RDR 12.009@113, 11.53@121 ....all motor streetcars
Modern Automotive Performance
(763)545-3800
lohatch is offline   Reply With Quote
2002, 2003, 96, civic, frozen, honda, plug, remove, removing, seized, spark, sparkplug, stubborn, stuck, trick, unscrew
