temperature gauge not working after overheating...
Old 12-29-2003, 07:14 PM
SPORT INJECTION's Avatar
Default temperature gauge not working after overheating...
Lost coolant the other day and forgot to top off.
SO..... my car overheated tonight. I let it cool and topped it off. It seems to be running just fine now but the temp gauge doesnt move from cool. It doesnt even go up to normal temp. Is there a possibilty I killed a sensor?
Thanks for any help for the dummie.....
Old 12-29-2003, 07:41 PM
crxgator's Avatar
Default Re: temperature gauge not working after overheating... (SPORT INJECTION)
did you bleed the system? if there is air trapped in there, it will mess the gauge reading up...
Old 12-30-2003, 05:18 AM
Home Skillet's Avatar
Check your radiator cap, that is one of the most overlooked items. That solved my overheating.
Old 12-30-2003, 06:31 AM
speed_racer012's Avatar
Default Re: temperature gauge not working after overheating... (Home Skillet)
or your coolant temp sensor and your thermostat. had that problem twice, once was the sensor the other was the thermostat.
it's two cheap and easy to fix things too.
Old 12-31-2003, 07:00 AM
Default Re: temperature gauge not working after overheating... (speed_racer012)
thermostat is only a few months old....
where is the sensor located?
..and is it called the thermosensor?
Old 12-31-2003, 04:13 PM
maybe the thermostat is broke and stuck open now?
Old 10-31-2004, 05:33 PM
asiansgoweeee's Avatar
Hey how did you end up fixing the problem because recently a heater hose busted and coolant leaked out and almost overheated. after replacing the radiator hose and topping the radiator off the temp gauge stopped working. thanks
Old 10-31-2004, 10:36 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPORT INJECTION &raquo;</TD></TR><TR><TD CLASS="quote">maybe the thermostat is broke and stuck open now?</TD></TR></TABLE>
I would replace it before you bother doing any other tests.
they're dirt cheap.
replace it and bleed the system and if you still don't get a temp reading then start looking into checking the sensor wires for continuity.
It's highly unlikely that overheating destroyed the sensor. They're made to work at high temps so that you know when it's overheating..
ARL97
06-03-2017 10:07 AM
wseg
11-07-2015 08:27 AM
obuhmyuh
03-07-2010 01:27 PM
stocker2shocker91
03-24-2008 01:19 PM
PearlWhiteAccord
12-20-2004 06:43 PM
Quick Reply: temperature gauge not working after overheating...
