polishing valve cover
Old 09-21-2001, 07:52 PM
clean's Avatar
Default polishing valve cover
started polishing it but dont know how to get between the HONDA lettering w/ sandpaper. by the way i am starting with 150fine then 220 extra fine then 400 some one said i had to wet the paper? i dont know, but i cant get all the grime that dripped down from the plug holes. oh and i got some generic multy meytal polosh too, anything else work better? or any pics?
Old 09-22-2001, 12:55 PM
JimmieD's Avatar
Default Re: polishing valve cover (clean)
you should strip it, then sand it with a soap/ water mix with a really high grit paper. I believe you should end up using a 1500 or 2000 paper in the end. That is what i have found as far as polishing.
Old 09-22-2001, 01:15 PM
JG Luder's Avatar
Default Re: polishing valve cover (lsinteg)
I'm trying to think of the stuff we use...
wait....
Old 09-22-2001, 01:17 PM
JG Luder's Avatar
Default Re: polishing valve cover (JG Luder)
ah ha! I remember now! Aircraft remover, yes it actually says that, (WalMart)... garanteed to rid your yard of 747s and get the paint off your valve cover. Only use 800-1500, and even 2000 if you have patience. Lower grit than that and you'll scar the metal.
A polishing wheel with some good hard compound is a must. Sears can help you out in this area.
Old 09-23-2001, 10:25 AM
PROFILES2000's Avatar
i just used the aircraft remover today and wow i was impressed
94c1v1cex
Paint and Body
06-05-2007 06:56 AM
DOHC_VTEC
12-04-2003 07:31 PM
hatchback19
05-30-2003 11:13 AM
Turbo Powa
11-22-2002 11:50 AM
civicsport
07-17-2002 07:04 AM
Quick Reply: polishing valve cover
