what cc are stock civic injectors
Re: what cc are stock civic injectors (Chris_Gee)
1988-'91 Civic Si/CRX Si Peak and Hold 240cc
1992-'95 Civic Si/EX Saturated 240cc
1996-'00 Civic Saturated 240cc
1990-'91 Integra RS/LS/GS Peak and Hold 240cc
1992-'00 Integra LS/GS Saturated 240cc
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
ah...behold the power of search.... (took less then 45 seconds to find and post)
Re: what cc are stock civic injectors (sohcvtec1995)
one isn't really better than the other, your car is designed to use one of the 2. Most civs are saturated.
Bigger injectors are not an upgrade unless your engine needs more fuel than the current injectors can supply. However I *thought* that for 96-00, that only the EX had 240cc injectors. I *thought* that lower model civs had 180cc. I hope that I'm wrong because I've got a set of 96DX injectors that I would like to have cleaned and balanced to put in my EX without any downtime.
Re: what cc are stock civic injectors (.JAYDEM.)
not to be an *** or anything but it says EK MEANING OBD2 CARS. lol they are 240cc just like the rest i found out i just wanted to make sure
ok so if u go to a injector size calculator and do the math u would find out that most SOHC came with 190cc injectors. now like i said thats using an injector calculator. i mean if u really wanna know just call ur local honda dealer and give em ur vin and they can tell u anything u wanna no about the stock engine if u have swapped in just give em the engine code and see what they can do for u. the internet is just a bunch of conflicting info. call the source lol n
ATS*Mark
02-02-2004 07:45 PM
