d16z6 specs
Old 12-11-2003, 04:45 PM
PooOnMyShoe942's Avatar
Default d16z6 specs
i need the info for the following feilds for my dyno program...
i have the d16z6 motor
the program is Dyno 2000
what does it mean when it says block
stock bore in inches
stock stroke in inches
cyl volume in cc
total volume in cubic inches
induction manifold type
induction flow in cfm
camshaft type
camshaft liters
cam specs, seat to seat timing
int lift@valve
exh lift@valve
ivo (btdc)
evo (bbdc)
ivc (abdc)
evc (atdc)
Old 12-11-2003, 05:07 PM
kingSfit's Avatar
iono
Old 12-11-2003, 05:19 PM
thrty8street's Avatar
bump. i want to know too
Old 12-20-2003, 06:07 PM
bump
Old 12-20-2003, 09:19 PM
D-Man's Avatar
Default Re: d16z6 specs (PooOnMyShoe942)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PooOnMyShoe942 &raquo;</TD></TR><TR><TD CLASS="quote">
stock bore in inches= 2.95"
stock stroke in inches= 3.54"
cyl volume in cc= 34.6cc
total volume in cubic inches=??
induction manifold type=single throttle body,multi port injection
induction flow in cfm=about 160cfm@28"
camshaft type=Sohc solid
camshaft liters=? is that lifters or liters?
cam specs, seat to seat timing=??
int lift@valve= .384
exh lift@valve= .370
ivo (btdc)=?
evo (bbdc)=?
ivc (abdc)=?
evc (atdc)=?
Old 12-20-2003, 10:29 PM
i know that the d16y8 was blessed with more midrange torque than the y6.
how was this accomplished?
hondapimpin420
10-23-2007 05:06 PM
vtec dub
07-09-2007 01:57 PM
tek_civic
05-09-2003 08:33 AM
KevronsEG
09-16-2002 08:30 AM
Quick Reply: d16z6 specs
