are b18c5 bottom end components compatible in a ls block?
i have a complete bottom end from a b18c5...all the parts..crank , rods, pistons, oil pan etc...i was wondering if it'll fit in a ls block, and if it would b good for ls/vtec...lmk ..any help is greatly appreciated..thanks
the reason for this is bcuz, i bought a block off ebay , and it came up hot....
i dont think its possible unless you sleeve the block and get the same size bore pistons, i know they are different tho, only by a little but they wont work, unless you might be able to swap out the sleeves, but i dont know if that works.
Re: are b18c5 bottom end components compatible in a ls block? (vtec 5 6 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec 5 6 2 »</TD></TR><TR><TD CLASS="quote">the reason for this is bcuz, i bought a block off ebay , and it came up hot.... </TD></TR></TABLE>
Why don't you tell the police about the block so that they can trace the block back to the thieves who stole it. One less band of thieves out there stealing people's ITR's.
Re: are b18c5 bottom end components compatible in a ls block? (b19coupe)
yes the crank, rods, pistons will all fit...oil pump main seal ect...but it will not be an ls v-tec you will have the R stroke not an ls it will be like having a R block with no oil squirters and no main girdle...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Why don't you tell the police about the block so that they can trace the block back to the thieves who stole it. One less band of thieves out there stealing people's ITR's. </TD></TR></TABLE>
He could also get in trouble for having the block...he has the stolen property in his possession....
Re: (lsintegra95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsintegra95 »</TD></TR><TR><TD CLASS="quote">i dont think its possible unless you sleeve the block and get the same size bore pistons, i know they are different tho, only by a little but they wont work, unless you might be able to swap out the sleeves, but i dont know if that works.</TD></TR></TABLE>
This is actually completley false. Just listen to the later comments.
Re: (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">
This is actually completley false. Just listen to the later comments.</TD></TR></TABLE>
Re: (1797ccs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1797ccs »</TD></TR><TR><TD CLASS="quote">no they wont fit...sell me the parts!!!</TD></TR></TABLE>
WTF? yeah they will fit for sure
