Old 11-30-2003, 02:14 PM   #1
94JadeAccord
94JadeAccord's Avatar
Default Is my fuel pump going bad? Here's the symptoms.
My fuel pump just starting making some strange buzzing whining muffled sound when i turn the key to the on position. A couple of times it didn't make any noise at all and the engine was just turning over. Click the image to open in full size.
Any input would be nice. Click the image to open in full size.
Thanks...
94JadeAccord is offline   Reply With Quote
Old 11-30-2003, 02:15 PM   #2
WuWarrior
2005 Honda S2000
My Garage
WuWarrior's Avatar
Default Re: Is my fuel pump going bad? Here's the symptoms. (94JadeAccord)
a little noise when you turn the key to ON is normal. It's just priming up.
For sale: 2005 S2000 Suzuka Blue/Blue interior
2006 Honda Accord V6 Hybrid Navi with over 150,000 miles
WuWarrior is offline   Reply With Quote
Old 11-30-2003, 02:23 PM   #3
94JadeAccord
Default Re: Is my fuel pump going bad? Here's the symptoms. (WuWarrior)
It used to make a little noise when priming but now it makes aLot of noise.
Doesn't sound right. Sometimes no noise at all. Click the image to open in full size.
Old 12-01-2003, 07:07 AM   #4
Elvis1977
Elvis1977's Avatar
Maybe its your main relay!
Elvis1977 is offline   Reply With Quote
Old 12-01-2003, 07:33 AM   #5
JimBlake
JimBlake's Avatar
Default Re: Is my fuel pump going bad? Here's the symptoms. (Elvis1977)
I vote for a bad pump. A bad main relay wouldn't cause the pump to get MORE noisy.
How about a fuel filter that's gotten plugged up? Then even a good pump has to work extra hard against a blocked filter. But that doesn't explain why sometimes it just doesn't run at all.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
03, 1990, 1994, 2003, 94, accord, bad, fuel, honda, lots, lx, makes, noises, pump, symptoms
