Old 11-28-2003, 02:58 PM   #1
range
Guest
Posts: n/a
Default clutch question- clutch goes down to the floor, starts but can't put into any gear.
Was sup everyone- got into my car after driving my bros TT supra for a couple of days. Push the clutch in and it felt like it went down to the floor with out any force. At first I just thought it was getting used to the weak clutch on my civic. By the way has a B16AII with a stage one clutch from Exedy. 2 days into driving my car again I went to the car and the clutch petal went almost all the way down to the floorboard - the car started but won't get into any gears. What gives, I know I didn't burn the clutch out , no smell, I checked the reservior and it was empty. I filled it up but nothing. Still same issue, I think it's the clutch lines it might have a leak. But after filling the reservior it never went down. I'm about to check it out today. What do you think it might be. Any help would be great.
Old 11-28-2003, 03:12 PM   #2
vtekthis
vtekthis's Avatar
try to bleed the cluch slave cyl
vtekthis is offline   Reply With Quote
Old 11-28-2003, 03:29 PM   #3
nota944mechanic
nota944mechanic's Avatar
Send a message via AIM to nota944mechanic
check your clutch master cylinder look under dash on the back of the clutch pedal (near the top) make sure there isnt any fluid leaking under there. if so replace and bleed. also if the clutch slave is leaking it will most lilkely leak into the transmision housing.
nota944mechanic is offline   Reply With Quote
Old 11-28-2003, 03:34 PM   #4
range
Guest
Posts: n/a
Default Re: clutch question- clutch goes down to the floor, starts but can't put into any gear. (range)
I looked before I was getting my tools and I noticed a dark stain by the clutch petal on the carpet. I'mma look into tomorrow it's just started to rain at this moment.
Old 11-28-2003, 09:31 PM   #5
brooksto
brooksto's Avatar
I bought a used (I know Click the image to open in full size. ) master cylinder for my manual tranny swap and it never leaked fluid but had no pumping pressure whatsoever. I ended up having to replace it. Is the car in gear when you start it? And does the pedal come back up by itself?
brooksto is offline   Reply With Quote
Old 11-30-2003, 09:38 PM   #6
range
Guest
Posts: n/a
Man, it was raining all day- the car starts up, the petal has no pressure what's so ever. I recall my clutch going out on my teggy and it wouldn't even start. In this case the petal goes all the way down with just a little play at the bottom and starts up. When you try to put it in gear it grinds like a *****.
Old 11-30-2003, 09:44 PM   #7
Jonathan_ED3
Jonathan_ED3's Avatar
Send a message via AIM to Jonathan_ED3
like already said...check the clutch MC and the Slave Cylinder!
My Vouch Thread
'79 Civic w/d16z6, '83 Civic S w/d16z6, '85 RX7 w/LS1/T56, '78 Corolla w/LS1/T56, '06 TSX -stock.
Jonathan_ED3 is offline   Reply With Quote
Old 11-30-2003, 09:46 PM   #8
G-money
G-money's Avatar
its either the slave cyl. on the tranny or the master cyl. on the fire wall i had the same problem of the pedal going to the floor after like 10 shifts and i had to rebleed it all the time (was at the street races way back haha) anyways had to rebleed every time i wanted to race then i replaced the slave cyl. and it was the seals in there letting air in somehow.??? anywasy hope this helps...
G-money is offline   Reply With Quote
Old 12-01-2003, 01:06 AM   #9
CheEsEsTeAk168
CheEsEsTeAk168's Avatar
Default Re: clutch question- clutch goes down to the floor, starts but can't put into any gear. (All MTR TOD
if the resevoir is fulll, try pumping the clutch lyke a LOT. mine was lyke that, i filled up the resevoir and it still didn't have pressure, i'd kick in the clutch and it wouldn't even come up, so i just pumped it HELLA times and built the presure back up and it works now Click the image to open in full size.
vouches: SlowEJ8, D15B_Turbo, Krillin02, jeffchaisi (sold seats, 'n misc parts, MadR88It, trunks (bought d16 longblock), lshatch916 (sold leather seats), 2.0L EK (bought turbo), 07 (bought turbo timer 'n harness), FuNkDrSpOt (bought steelies). kraven9 (bought antenna block off plate), Outkast95LS (bought denji projectors). EGWhore (bought armrest and sidemarkers)
CheEsEsTeAk168 is offline   Reply With Quote
Old 12-01-2003, 02:01 AM   #10
ross1459
ross1459's Avatar
Send a message via AIM to ross1459
same thing happened on my car. your master cylinder is leaking. fill up the reservoir and bleed the clutch. you will be able to get by if you just keep topping it off. change out hte master sylinder ASAP
93 Del Sol TURBO
hit me up on AIM (ross1459) if you want to PM me. my popup blocker sometimes blocks the HT IMs.
[img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] sellers: Flamenco-T, D16z6turbs
ross1459 is offline   Reply With Quote
1992, black, change, civic, clutch, fix, floor, force, gear, gears, integra, pressure, put, smell, stain, starts
