Spark Plugs for d16z6?
Old 11-22-2003, 08:27 PM
trooper0641's Avatar
Default Spark Plugs for d16z6?
What are the best spark plugs avialable for the z6.
Old 11-22-2003, 09:32 PM
Default Re: Spark Plugs for d16z6? (trooper0641)
....i heard bocsh platinums = any comments?
Old 11-22-2003, 10:02 PM
HATCHingMN's Avatar
Factory denso or ngk...try getting the colder heat range plugs or the one they called high speed driving plugs!!
Old 11-22-2003, 10:04 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">....i heard bocsh platinums = any comments?</TD></TR></TABLE>
OMG Those are the biggest POS plugs period.. get NGK
Old 11-22-2003, 10:15 PM
SiFan's Avatar
Default Re: Spark Plugs for d16z6? (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">
OMG Those are the biggest POS plugs period.. get NGK</TD></TR></TABLE>What he said!!!STAY AWAY FROM THE BOCSH, BAD! VERY BAD!!
Old 11-22-2003, 10:17 PM
D Tranny Guru
Mista Bone's Avatar
what does it say on the timing belt cover??????
Got with them or my cheapo Champions.
The best spark plugs are like the best engine oil. They are best when changed often!!!!!
Old 11-22-2003, 10:57 PM
BMac86's Avatar
Default Re: Spark Plugs for d16z6? (Mista Bone)
NGK Iridium IX, I use em!
Old 11-22-2003, 11:16 PM
HATCHingMN's Avatar
Stock denso and NGK plugs are not boring!!!
Old 11-22-2003, 11:23 PM
biassj's Avatar
Default Re: Spark Plugs for d16z6? (HATCHingMN)
NGK V-power are fine, get the ones for an LS(ZFR5F-11), it's cheaper. The sohc vtec has special part number to it that cost more. I wouldn't waste my money on Iridium.
Old 11-23-2003, 01:14 AM
Jedi_Sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
NOOB question , how often should i replace my spark plugs? the owner didnt have the manual to the car when i bought it.
Old 11-23-2003, 02:52 AM
yakitori's Avatar
bosch super
Old 11-23-2003, 03:37 AM
sir2k's Avatar
Default Re: Spark Plugs for d16z6? (yakitori)
depends...all motor or boost?
Old 11-23-2003, 03:58 AM
ek_will's Avatar
Default Re: Spark Plugs for d16z6? (sir2k)
how about for a boosted d16y8 ( should be the same as z6 ) 5psi i heard a ngk with colder range but forgot the part number.
Old 11-23-2003, 04:07 AM
SLeePeR012's Avatar
Default Re: Spark Plugs for d16z6? (Jedi_Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jedi_Sol &raquo;</TD></TR><TR><TD CLASS="quote">
NOOB question , how often should i replace my spark plugs? the owner didnt have the manual to the car when i bought it.</TD></TR></TABLE>
I change mine every 5k miles, honestly.
Old 11-23-2003, 05:50 AM
E.G.6's Avatar
Default Re: Spark Plugs for d16z6? (SLeePeR012)
if it's a boosted application I believe the NGK part number is something like the BEFRS911...I know it begins with the BEF truncation...they're a colder range plug that most street boosted drivers use...
if it's a N/A application you can go either way pretty much...the Denso Iridium's are a nice plug (hard to come by if you're not in much of a performance shop area). I've used them a few times and was pretty happy with them...the other option is the NGK Iridium ones as well, these ones I had no issues at all with...they burned nicely, great spark and I pretty much stuck with them for quite some time. Again, it's all preference...if you REALLY need the big spark and higher heat operating range then dump the cash on the iridiums...otherwise, just drop in your standard set of NGK's!
Oh, and changing your plugs...again, depends on application...I religiously change my plugs every 3-5k km's and change the wires seasonally...if you're boosting hard I'd say maybe just keep an eye on them more often than not and go by your gut feeling.
Old 11-23-2003, 06:18 AM
93egsi's Avatar
Default Re: Spark Plugs for d16z6? (E.G.6)
if you got N/A with some simple bolt ons.......like myself.......stock denso or ngk's will do just fine
Old 11-23-2003, 06:29 AM
JRadd8's Avatar
i tried bosch platinum 4 and didnt like 'em on my 97 ex civic. stick with NGK!
Old 11-23-2003, 07:32 AM
D Tranny Guru
Mista Bone's Avatar
If just average driving, I usually change the plugs in the spring, part of the yearly tune-up and look over.
Change plugs every 10,000. The $6 you play for the plugs, you'll get 3x that back in saved gas mileage.
Old 11-23-2003, 07:41 AM
be professional
Targa250R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">What are the best spark plugs avialable for the z6.</TD></TR></TABLE>
I would highly recommend using only NGK or Denso plugs, and only OEM Honda plug wires. If you are NA, use the plug listed on the sticker in your engine bay.
These parts have actually been dyno tested to be the best for your Honda engine.
Honda ignition components can be very picky about plugs and wires sometimes. A lot of people can get away with running other plugs and wires just fine, but I've seen many cars with them come into the Honda dealership running like ****.
What Mista Bone said is correct though, just change your plugs often and you really won't see any plug-related problems. This is why I don't believe in buying fancy, expensive plugs - I just get regular copper plugs and change them often. And on a side note to his analogy, I also don't believe in buying fancy, expensive synthetic oil since I change it religiously every 3000 miles or less - synthetic would just be a waste of money since natural oil comes out just as clean with that mileage.
Old 11-23-2003, 08:30 AM
jdmeg693's Avatar
Default Re: Spark Plugs for d16z6? (Targa250R)
NGK no question
Old 11-23-2003, 11:56 PM
D Tranny Guru
Mista Bone's Avatar
thanks for the words, but I have to thank my grandfather.
Anyone can drive a car, but it takes SOMEONE to maintain it.
SOMEONE WHO CARES!
I change my engine oil at 5000 miles during off season, at 2500 miles during race season. I only use STP 2808 oil filters from Autozone. The only time I would use a GOOD synthetic oil would be for road course racing.
Old 11-24-2003, 01:25 AM
handa's Avatar
NGKs are
cvccr
06-15-2007 11:21 AM
RACEPAK
09-21-2005 04:07 AM
Phatch99
09-08-2005 12:39 PM
rice a roni
27
12-07-2003 01:08 PM
SLOAZZ95
38
08-05-2003 04:54 PM
Quick Reply: Spark Plugs for d16z6?
