Need help
Old 05-12-2003, 06:33 AM
thevtecnician's Avatar
Default Need help
ok, heres the deal. MY sisters 88 base model hacthback got gaffled, and they popped the ignition .of course, but now it wont start. Ive replaced the fuse box, wiring harness, ecu,and main relay. it has a bran new starter, alternator. Here is what isn't the problem, spark, fuel. the car won't crank, the starter doesnt even get a signal. i kow this because we push-started the car,and it ran fine, but when i turned the ignition to position III( would usually grind the starter's gears, nothing happened. any idea's? i dont want to have change the harness from ecu to headlights
Old 05-12-2003, 06:49 AM
DJ_SaNdOz's Avatar
Default Re: Need help (thevtecnician)
have you checked all of teh electrical stuff w/ a test light? is the ignitions switch fu__ed?
Old 05-13-2003, 09:35 AM
DJ_SaNdOz's Avatar
Default Re: Need help (dj_sandoz)
any updates on this?
Old 12-12-2003, 07:39 AM
Default Re: Need help (DJ_SaNdOz)
yes there is. it was the starter solenoid. and i had the positive cable connected to the starter, touching the tranny
Old 12-12-2003, 07:42 AM
Jet Black's Avatar
YIKES!
SDP190416
09-22-2008 12:39 AM
SDP190416
09-21-2008 10:45 AM
blueb16-em1
06-19-2008 05:12 PM
AP1Shocker
12-08-2006 01:27 PM
civicguy167
11-26-2005 09:30 AM
Quick Reply: Need help
