my gsr timing belt is loose wtf?
Old 11-13-2003, 01:32 PM
92B20GSR's Avatar
Default my gsr timing belt is loose wtf?
im trying to figure out what the problem is the belt is really loose and the tensenior seems to be maxed out is it possible to stretch a timing belt? or could the tensenior be froze?
Old 11-13-2003, 02:10 PM
LSTEG96's Avatar
Default Re: my gsr timing belt is loose wtf? (92B20GSR)
id sure hope u arent driving the car...
Old 11-13-2003, 02:18 PM
92B20GSR's Avatar
Default Re: my gsr timing belt is loose wtf? (LSTEG96)
no i am not but i was driving it when it back fired and died so we took it to my shop and i found this.
Old 11-13-2003, 02:48 PM
LoudLude's Avatar
when was it last changed? ARE YOU SURE? that is usually a good sign they are about to snap!
Old 11-13-2003, 02:58 PM
King_j's Avatar
Default Re: my gsr timing belt is loose wtf? (LoudLude)
the tensioner has a spring attached to it, is the spring still there?
Old 11-14-2003, 12:18 AM
92B20GSR's Avatar
Default Re: my gsr timing belt is loose wtf? (King_j)
yes the spring is still there
Old 11-14-2003, 03:55 AM
JimBlake's Avatar
Take off the covers & go thru the process just like you're going to replace the timing belt. Probably you'll find something that's not right. Like maybe the tensioner bearing or maybe the tensioner bolt simply worked loose.
Old 11-14-2003, 05:32 AM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92B20GSR &raquo;</TD></TR><TR><TD CLASS="quote">no i am not but i was driving it when it back fired and died so we took it to my shop and i found this.</TD></TR></TABLE>
that's not good, sounds like you could of messed something up, like jumping some cogs on the cams.....i'd do the 90k maintenece NOW...
Old 11-14-2003, 06:37 AM
ebelp's Avatar
Default Re: my gsr timing belt is loose wtf? (NeoGSR)
The belt may be flexed or streched somewhere...put a brand new belt on (OEM) and see what happens.
Old 11-15-2003, 12:01 PM
CR-V-tech's Avatar
what is your set up b20 w gsr head? if so you will need to use the b20 belt or a ls belt! not the gsr OK
Old 11-15-2003, 01:48 PM
DSayavan's Avatar
I just finished tightening my belt today. I spent about 3 hours doing it!!! I barely released the tension pulley. In the helms manual it says to loosen it a max of 1/2 turn. Well, I kept on doing that and my belt was loose as hell. Then my buddy who's a Nissan tech said to loosen it more, so he loosen a whole turn, then we turned the crank pulley. Then we tightened the tension pulley and it was good to go.
Old 11-16-2003, 10:59 AM
AzG35's Avatar
Default Re: my gsr timing belt is loose wtf? (DSayavan)
You can manually manipulate the tensioner as well with a coat hanger or a long prybar to pull up on the spring side of the tensioner for more tension on the belt.
Old 11-16-2003, 11:37 AM
ARACER25's Avatar
Default Re: my gsr timing belt is loose wtf? (AzSi22)
Just snapped my timing belt yesterday on the interstate 4 hours from home. Not fun to change on the side of the road. That's what I get for not changing it when I rebuilt the motor
Old 11-17-2003, 01:55 AM
92B20GSR's Avatar
thx for the replys. we went ahead and pulled the head on my 1.8 gsr motor (CR-V-tech- that was my plans gsr is what i got) valves were fine and piston was look great. we went ahead a polished a little on the exhaust ports now were putting things back together we had a problem and had to move to a diffrent shop in the middle of things it went smooth for moving the car 60 miles in the middle of things. question though can i resure the head gasket or the head bolt. motor has 110,000 on it. i called a couple diffrent acura dealerships and got diffrent answers so im wondering.
Old 11-17-2003, 02:04 AM
JDM_Honda_Fiend's Avatar
Default Re: (92B20GSR)
If you raced your car alot especially with a 6-puck clutch, most likely you've stretched your belt. The best bet is to replace it with another one before you accidently snap it and bend all your valves along with the possibility of damaging your pistons. Better to be safe then sorry bro. Replace it and be assured your belt won't break on you. As far as tensioning, usually when you tension your belt it should have a 1in deflection when you press on the front long side of the belt loop
Good luck
Cheers
Jeffrego
Honda Civic (2001 - 2005)
10-31-2018 05:02 AM
Ge-money
03-24-2010 06:35 AM
92integraVTECgsr
04-19-2006 02:41 PM
grngsr01
03-14-2005 05:19 AM
ElectronSi
12-29-2004 07:06 PM
Quick Reply: my gsr timing belt is loose wtf?
