B16 compression buildup
Old 11-09-2003, 09:30 PM
XxRoCkMaNxNEOxX's Avatar
Default B16 compression buildup
im going for the s2 s2 setup but i wanted to know what is the best way to build up my compression since the cams make the most power if there is high comp. pistons? rods? milled head? thinner head gasket? im trying to get into low 11 or mid 11.
Old 11-09-2003, 09:43 PM
michael O's Avatar
Default Re: B16 compression buildup (XxRoCkMaNxNEOxX)
Ctr Pistons. That should get you close to the minimum compression needed for these cams.
Old 11-10-2003, 12:31 AM
Beave0101's Avatar
as posted in your other thread on CSI if you ever checked it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">it can be done w/ a stock block, i did it w/ milled head, 2-layer headgasket. another way would be to weld the combustion chambers to the p-72/pent-roof design..
you shouldnt have clearance issues w/ that, I dont, but you could def. be screwing yourself if you wanted to do some bottom end work in the future( milling the head is irreversible)
if you wanted to stick w/ oe internals and raise the compression, you could go w/ ctr pistons and mill your stock rods.
however, the most ideal way of making power w/ raised compression is to go with aftermarket internals, because they are lighter, (lighter = more power)more power friendly design, etc. OE rods can support just about any amount of power NA & most boosted applications can make, but the downfall being small & weak rod bolts. Also, most aftermarket wrist/pin designs will not fit on oe rods, and are also much stronger. In terms of brand everyone has their fav. pics, for me it's a probe rod/wiseco piston... </TD></TR></TABLE>
speedracer209
08-17-2006 01:10 AM
SCIVIC94
12-19-2005 01:56 AM
Spyderman4g63
04-27-2005 01:23 PM
Can'tCatchMe
04-13-2004 10:14 AM
EFing8
10
12-14-2002 04:00 PM
Quick Reply: B16 compression buildup
