Signs of bent valves??
Old 11-05-2003, 07:19 PM
  #26
fuck honda-tech's Avatar
Default Re: (94goldjungsr)
mine costed 1200 with labor and 8 bent valves!
Old 11-05-2003, 07:24 PM
  #27
Mr. Softee's Avatar
Default Re: (epsom salt)
ive had 16 bent valves like i said and i just threw 16 stock valves in the head and it only cost me $50 for the headgasket.
Old 11-05-2003, 07:34 PM
  #28
tuan...'s Avatar
so u put the valves in yourself?? hard or what? holy crap 1200?? that is really really high, for jus 8 valves isnt it?
Old 11-05-2003, 07:57 PM
  #29
Mr. Softee's Avatar
Default Re: (h22poweredgsr)
yea once you take the valve springs out the valves will fall right out, just slide the new (or used)ones in the head and reinstall your valve springs / retainers.
you will need a valve spring compressor... worst case if you dont feel comfortable take it to a machine shop they should be able to assemble the valvetrain for like $100.
do NOT have a shop take the head off... that is just retarded.
also $1200 is rediculous you could have bought a whole new head for that price.
Old 11-06-2003, 06:27 AM
  #30
JDMBB2's Avatar
the machine shop in our area said that they don't do that any more so what do you think he should do because i dont think he will want to put those in himself dont you have to torque those down or what?
Old 11-06-2003, 07:34 AM
  #31
tuan...'s Avatar
well hello there matt short.
Old 11-06-2003, 07:47 AM
  #32
JDMBB2's Avatar
whats up tuan pham
Old 11-06-2003, 10:36 AM
  #33
jabroni95gsr's Avatar
Default Re: (jdmh22lude)
I've done this before (not often) and nothing happened. I suppose I caught it in time, but seriously I think i've done this like 3 times in the last 105,xxx miles. Nothing happened each time and it revved higher than 8500rpm for sure.
Honda motors are much more robust than say, a BMW m3. Even the slightest overrev in a e36 m3 and you are done. $3000 to fix.
As long as the car runs fine (like normal) everything is fine.
Old 11-06-2003, 11:25 AM
  #34
Mr. Softee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22lude &raquo;</TD></TR><TR><TD CLASS="quote">the machine shop in our area said that they don't do that any more so what do you think he should do because i dont think he will want to put those in himself dont you have to torque those down or what?</TD></TR></TABLE>
there has to be a machine shop that will put valve springs in a head. i will go home and peep my helms and give you the exact step by step instructions for valve spring installation if you truly desire them.
Old 11-06-2003, 04:59 PM
  #35
tuan...'s Avatar
yes i truly desire them, where would i find a helms anyways? all i got is a haynes and its worthless.
Old 11-06-2003, 05:50 PM
  #36
Mr. Softee's Avatar
helms is the book acura uses. its about 2" thick.
sam
Old 11-06-2003, 06:29 PM
  #37
tuan...'s Avatar
is there any other little things i gotta do to install the valvetrains?/ is it hard or what? i noe i gotta replace the head gasket. any other littles things i gotta do?? if i remove the springs the valves jus fall out right?
rotascircuit
12-23-2009 05:37 PM
Boostage
09-17-2005 10:36 PM
Coletrain
04-07-2005 12:30 PM
Dammit_Dan_954
12-07-2003 08:44 AM
CheezeFrog
11-11-2003 02:20 PM
Quick Reply: Signs of bent valves??
