engine swap for CRX 90
I just bought a 1990 CRX SI, I'd like to keep my tranny. What would be the best engine to put in there that workes good with turbo and nitrous
Re: engine swap for CRX 90 (knighthawkacc)
FIRST, do a search. then figure how much hp you want, last figure how much money you want to spend. the last one will tell you which motor to go with
Re: (mad2nr)
Which one the b16a1 or the B18? Remember I want to keep my tranny but if I have no choice in it, I'll change it. I just don't want to cut anything to fit in. What do you think about the h22a the prellude motor?
Re: (knighthawkacc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knighthawkacc »</TD></TR><TR><TD CLASS="quote">Which one the b16a1 or the B18? Remember I want to keep my tranny but if I have no choice in it, I'll change it. I just don't want to cut anything to fit in. What do you think about the h22a the prellude motor?</TD></TR></TABLE>
h22 motor wont fit your tranny...
your tranny will only fit D-series motors...
so you cant put in a b16 or a b18 because they're b-series nor a h22 because its an h-series..get it
your best bet is to do a mini-me swap or to get a complete d16z6 or d16y8 or d15b etc.
Re: (pennies_hatchie)
Mini-me or D15 that is going to make his 400HP? You might want to re-evaluate your goals. Obviously money does make a difference so decide how much you want to spend and a more realistic HP goal.
Re: (knighthawkacc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knighthawkacc »</TD></TR><TR><TD CLASS="quote">But can a h22a moter fit without cutting, If so I'll just change the tranny</TD></TR></TABLE>
Nope. I've seen a handfull of h22 swaps, they all had cuts and welded mounts. It can be made to blend in. If money really isn't an issue get the H22 with internals for boosting and a supercharger. Then see what you need from there to make 400HP.
Re: (knighthawkacc)
yo if you wanna go with the minime i got a head with a everything on it and a aem cam gear ill let ig go for $100+ shipping its a fast swap and it will give you alil somethin somethin till you get your swap let me know man
bigworm1126@aol.com
ps don fake on the single cams... they can be real quick
bigworm1126@aol.com
Re: (knighthawkacc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knighthawkacc »</TD></TR><TR><TD CLASS="quote">Ok I made my choice I'm going with the b16a. Can u give me a run down of everything i should swap.</TD></TR></TABLE>
Try starting a new post. That should help you with answers as more people will read it if they have any good input for you.
Re: (JDMVTEC)
I say you read on this website for a while and learn more about Hondas before you make any decisions. And if money isnt a problem than I dont see why you have a Honda, much less want to make it have 400 hp.
Re: (JDMVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMVTEC »</TD></TR><TR><TD CLASS="quote">DOHC ZC uses same tranny wiring and mounts and its a cheap little motor and pretty fast.</TD></TR></TABLE>
too bad nothing is made for the zc
Skoobie no more...
Re: (90CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90CRX »</TD></TR><TR><TD CLASS="quote">
Try starting a new post. That should help you with answers as more people will read it if they have any good input for you.</TD></TR></TABLE>
are you crazy....listing what you need for a b16 swap has been cover numerous time...try searching before you post
Re: (ind3ciso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ind3ciso »</TD></TR><TR><TD CLASS="quote">
are you crazy....listing what you need for a b16 swap has been cover numerous time...try searching before you post </TD></TR></TABLE>
true. or he could check out the hybrid section. there's a sticky for common swap info.
CarBoyEnthusiest
20
11-11-2005 08:32 AM
illogic65
08-29-2004 02:17 PM
