Motul Engine Oil
Old 02-13-2004, 08:00 AM
  #51
Footwork's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Were you sending the oil off for analysis?</TD></TR></TABLE>
No, I just check the oil every evening and noted it stays clean much longer (pure gold color - no particles), and the mobil1 gets little black particles in it much much sooner.
Old 02-13-2004, 08:01 AM
  #52
.RJ
.RJ's Avatar
Default Re: (Primo.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">No, I just check the oil every evening and noted it stays clean much longer (pure gold color - no particles), and the mobil1 gets little black particles in it much much sooner.</TD></TR></TABLE>
So the Motul just lets the particulates gum up the engine?
Thats good.....
Old 02-13-2004, 08:09 AM
  #53
Footwork's Avatar
Default Re: (.RJ)
Thats good..... </TD></TR></TABLE>
HAHA... No silly goose. I mean the Motul does not break down as quickly as the mobil1.
Old 02-13-2004, 08:10 AM
  #54
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">I mean the Motul does not break down as quickly as the mobil1.</TD></TR></TABLE>
But you didnt send either off for analysis....
Old 02-13-2004, 08:15 AM
  #55
Footwork's Avatar
Default Re: (.RJ)
But you didnt send either off for analysis.... </TD></TR></TABLE>
HT @ it's finest...
Old 02-13-2004, 08:17 AM
  #56
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. &raquo;</TD></TR><TR><TD CLASS="quote">HT @ it's finest... </TD></TR></TABLE>
I'm not saying one oil is better than another.
But if you want to know which one is breaking down sooner, you cant tell by looks, smell or taste. I reckon tasting it would be just as effective as looking at it.
Old 02-13-2004, 08:18 AM
  #57
J_Edwards's Avatar
Default Re: (.RJ)
I think that what RJ is saying, is that the color of the oil has nothing to do with it's breakdown. The color is dictated by the oils pickup of small particles inside the engine.
Old 02-13-2004, 09:24 AM
  #58
MattD@Stoptech's Avatar
Default Re: (.RJ)
My st00l has little black particles in it from time to time...should I switch to motul?
Comparing oil color samples is usless...
Old 02-13-2004, 09:27 AM
  #59
.RJ
.RJ's Avatar
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">My st00l has little black particles in it from time to time...should I switch to motul?</TD></TR></TABLE>
How does it taste?
  #60
Default Re: (.RJ)
Like chit?
Old 02-13-2004, 09:57 AM
  #61
Mugen Type R's Avatar
wouldnt 0-40 ester based motul oil be a little to clear to run in 90 degree weather?
Old 02-13-2004, 10:52 AM
  #62
bcrl's Avatar
Default Re:
Which one should pick for street use? (ITR NA engine)
1) Motul 8100 5w30 (PAO)
2) Motul 8100 0w30 (ester)
3) Motul 8100 0w40 (ester)
4) Motul 8100 5w40 (PAO)
5) Motul 300v 5w30 (ester)
6) Motul 300v 5w40 (ester)
Old 02-13-2004, 10:53 AM
  #63
.RJ
.RJ's Avatar
Default Re: Re: (bcrl)
PAO &gt; Ester if you want extended drain intervals.
Old 02-13-2004, 11:05 AM
  #64
bcrl's Avatar
Default Re: Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">PAO &gt; Ester if you want extended drain intervals.</TD></TR></TABLE>
That's mean PAO should last longer than Ester for street use?
Old 02-13-2004, 11:07 AM
  #65
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bcrl &raquo;</TD></TR><TR><TD CLASS="quote">That's mean PAO should last longer than Ester for street use?</TD></TR></TABLE>
Correct
Old 02-13-2004, 11:15 AM
  #66
00MRSi's Avatar
As .RJ said, $50 oil changes =
Old 02-13-2004, 11:16 AM
  #67
.RJ
.RJ's Avatar
Default Re: Re: (00MRSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi &raquo;</TD></TR><TR><TD CLASS="quote">As .RJ said, $50 oil changes = </TD></TR></TABLE>
I didnt do my math correctly the first time around.... keep reading for a more accurate figure
Old 02-13-2004, 11:21 AM
  #68
00MRSi's Avatar
I didnt do my math correctly the first time around.... keep reading for a more accurate figure </TD></TR></TABLE>
lol.. reading is fundamental..
Old 02-13-2004, 11:33 AM
  #69
01CWITR's Avatar
Default Re: Motul engine oil ?? (RaVAGE00)
i used 8100 it's good enough for street.. if u track ur car so often use 300v..
Old 02-13-2004, 03:11 PM
  #70
bcrl's Avatar
Default Re: Motul engine oil ?? (01CW-ITR)
Which grade of Motul 8100 is good for ITR (NA engine) ?
5w30?
5w40?
0w30?
ow40?
Old 02-13-2004, 04:14 PM
  #71
.RJ
.RJ's Avatar
Default Re: Motul engine oil ?? (bcrl)
5W-30 (unless there is some discrepancy in the rated viscocity because it does not have an API star)
Old 02-13-2004, 04:47 PM
  #72
Dr Pooface's Avatar
Default Re: (.RJ)
Ya you're right, Motul 300v is a crappy oil and bad for your engine.
Or maybe the ester base is less prone to breaking down and turning to sludge at high temps. Or maybe it prevents wear a little better and keeps particulates from forming. Or maybe the folks at Motul know nothing about making motor oil for high performance engines.
Old 02-13-2004, 05:18 PM
  #73
ejprimo's Avatar
Default Re: (Dr Pooface)
ester base stocks are known for their great cleaning ability. the only reason i think that the guys motor oil still looks golden is b/c all the crap was already cleaned out with the mobil1.
if you have two equally dirty motors, the ester based motor oil will turn darker quicker than any other base motor oil. also, if you have a faulty PCV valve it will leave a dirty filmy residue all over the inside of the head. my UOA showed a increase in insolubles and this was confirmed when i pulled the valve cover to do a valve adjustment. my next UOA sample pulled after i did the valve adjustment should show a even higher # of insolubles.
Old 02-13-2004, 06:42 PM
  #74
ejprimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bcrl &raquo;</TD></TR><TR><TD CLASS="quote">Which grade of Motul 8100 is good for ITR (NA engine) ?
5w30?
5w40?
0w30?
ow40?</TD></TR></TABLE>
i would choose the motul 8100 0w-40 b/c its close to being a 30wt. oil, 13.3cst@100F (anything below 12.5cst@100F is a 30wt.) and it has a higher high temperature high shear number than the 5w-40.
5w-40 HTHS=3.57
0w-40 HTHS=3.66
-the HTHS number is an indication of an oils ability to resist shearing at high temperatures. the higher the number the better.
generally the higher viscosity an oil has the higher the HTHS number will be. so looking at these number there doesnt seem to be much of a difference until you factor in that the 5w-40 has a higher viscosity than the 0w-40 (14.0&lt;13.3) but the 0w-40 has a higher HTHS number than the 5w-40.
Old 02-13-2004, 07:20 PM
  #75
.RJ
.RJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Ya you're right, Motul 300v is a crappy oil and bad for your engine. </TD></TR></TABLE>
I made no claims over which oil was "better" in any regard.
However you cant make blanket statements about one oil being better without some tech and numbers to back it up with.
Quick Reply: Motul Engine Oil
