Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 10-22-2003, 08:45 PM   #1
GT-KiLLa
GT-KiLLa's Avatar
Default installing cam gears
how hard is it to install cam gears on a b-series engine? will there be much gain from it. i got a few hundred to spend, and was either thinking of cam gears or a lighter flywheel...any suggestions would help thanks!
b18c block decked w/CTR o/s pistions
LS rods
polished crank
b18c head milled w/CTR internals
balanced and blueprinted
skunk2 manny
rc310 injectors
hondata s200 w/p28 current C/R is 12.9:1
170whp 126tq untuned
GT-KiLLa is offline   Reply With Quote
Old 10-22-2003, 09:25 PM   #2
vtecmike1
vtecmike1's Avatar
Default Re: installing cam gears (GT-KiLLa)
cam gears with your mods would probably add some nice whp but a exedy 9.8 pound flywheel is a great mod that can be done for cheap around 250 or so.. its up to you but i have no regrets on my flywheel
vtecmike1 is offline   Reply With Quote
Old 10-22-2003, 09:40 PM   #3
mmuller
Mad Scientist
mmuller's Avatar
Default Re: installing cam gears (vtecmike1)
you have your block decked and your head milled and no camgears?defenetely get cam gears and get them tunned...with your mods; more important than the flywheel.
-2290 DC2= e85 powered -DB2
EFI 101 -- PGMFI.ORG-- crome--
have a question about ducati's? ducati factory trained
mmuller is offline   Reply With Quote
Old 10-22-2003, 10:41 PM   #4
GT-KiLLa
GT-KiLLa's Avatar
how hard is it to install them? do i have to remove both of the cams?
LS rods
polished crank
skunk2 manny
rc310 injectors
Old 10-22-2003, 11:46 PM   #5
Mark's 1.8T
Mark's 1.8T's Avatar
Default Re: (GT-KiLLa)
http://www.c-speedracing.com has a nice how-to guide Click the image to open in full size.
2009 SMR Accord Coupe V6 6MT
Mark's 1.8T is offline   Reply With Quote
Old 10-23-2003, 05:47 PM   #6
GT-KiLLa
GT-KiLLa's Avatar
Default Re: (94BlackCivicEX)
thanks thats a great link. but just wanted to know do i have to remove the entire camshaft in order to change the cam gears? can i just remove the valve cover and un bolt the cam gears off??? have anyone changed their cam gears?
LS rods
polished crank
skunk2 manny
rc310 injectors
Old 10-24-2003, 04:45 PM   #7
GT-KiLLa
GT-KiLLa's Avatar
up
LS rods
polished crank
skunk2 manny
rc310 injectors
Old 10-24-2003, 11:06 PM   #8
Padawan
Darth ModerVader
Padawan's Avatar
No need to remove the cams, but you will need to loosen the timing belt. Also keep in mind that you'll need dyno tuning to see any gains from adjustable cam sprockets - they aren't just a "bolt-on" part.
-NEMO ME IMPUNE LACESSIT-
Padawan is offline   Reply With Quote
adjustable, b16, b18, b18c, cam, camshafts, gear, gears, gtkilla, head, install, installing, ls, removal, skunk2
