> Acura Integra Type-R
Old 10-14-2003, 07:38 PM   #1
TypeRuz
TypeRuz's Avatar
Default Proper OEM lug nut torque specs ?
Also, it as always important to use a torque wrench for putting wheels on car?
or can i just "feel" for the proper torque?
i've heard it's bad to torque way above specs....may warp rotors. of course, below specs can be bad for obvious reasons.
TypeRuz is offline   Reply With Quote
Old 10-14-2003, 07:40 PM   #2
BlueR
BlueR's Avatar
iTrader Rating: (10)
Default Re: Proper OEM lug nut torque specs ? (typeruz)
80 lbs and buy a torque wrench it has other uses too
My Vouch Thread
BlueR is offline   Reply With Quote
Old 10-14-2003, 07:45 PM   #3
D
Send a message via AIM to D
about 'yay' much.
D is offline   Reply With Quote
Old 10-15-2003, 04:06 PM   #4
People_Mover
People_Mover's Avatar
Location: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Send a message via AIM to People_Mover
Default Re: Proper OEM lug nut torque specs ? (D)
Originally Posted by D
about 'yay' much.
yeah, D always uses his vocal chords as a torque wrench. click clock. lol
'07 Dark Cherry Pearl Honda Ridgeline RTS, 2010 Pearl White Acura TSX
Poker Rakeback!! http://www.thisisthenuts.com Use Referrel - 4912
The life of a poker player: http://www.peoplemoverpoker.blogspot.com
People_Mover is offline   Reply With Quote
Old 10-16-2003, 06:41 AM   #5
sil
sil's Avatar
i've always wondered about this, but I would've thought that the warping of rotors comes from using different torque amount on all 4/5 lugs as opposed to using a number different 80ftlb.. in other words if you consistently use X ftlb on all lugs you'll be OK.. if that's the case, are torque specs given to save your threads?
sil is offline   Reply With Quote
Old 10-16-2003, 08:07 AM   #6
nsxtasy
H-T Order of Merit
Default Re: Proper OEM lug nut torque specs ? (sil)
You should always use a torque wrench.
Here is a nice one for only thirty bucks. It's money well spent.
nsxtasy is offline   Reply With Quote
Old 10-16-2003, 08:12 AM   #7
jonas
jonas's Avatar
Send a message via AIM to jonas
i like to use a torque wrench.. but when one is not around, just make sure they're on there pretty snug.. and of course in a star pattern.
jonas is offline   Reply With Quote
Old 10-16-2003, 08:37 AM   #8
D
Default Re: Proper OEM lug nut torque specs ? (nsxtasy)
you sir, are a retard. many things need an appropriate bolt stretch that should be measured... ie, rod caps, main caps, tranny components... others can be rednecke'd with no issues.
D
Old 10-16-2003, 08:52 AM   #9
Johnny Tran
Johnny Tran's Avatar
Send a message via AIM to Johnny Tran
D,
whats the battle torque spec for my license plate screws?
Black Label Society - NC chapter
Johnny Tran is offline   Reply With Quote
Old 10-16-2003, 09:11 AM   #10
AssPenny
AssPenny's Avatar
Default Re: Proper OEM lug nut torque specs ? (Johnny Tran)
Same as the oil drain plug
Craig - I spell like a 3 year old.
01 ITR
03 M3
Host it the we-todd way http://images.honda-tech.com/set1/smile/emthup.gif
AssPenny is offline   Reply With Quote
Old 10-16-2003, 09:19 AM   #11
Johnny Tran
Default Re: Proper OEM lug nut torque specs ? (AssPenny)
cool...so ill just put it on like the plug, with my air gun.
thanks craig
Old 10-16-2003, 09:20 AM   #12
nsxtasy
H-T Order of Merit
You, sir, are very quick to throw nasty insults around without any provocation. Perhaps you are having a bad day. (Cubs fan, perhaps?)
You also ignore the fact that the question was asked about lug nuts and it would be reasonable for anyone to assume that my response should be taken within this context. However, since you are clearly more interested in attacks than in having a reasonable discussion, I will rephrase my response:
You should always use a torque wrench when tightening wheel lug nuts.
Old 10-16-2003, 10:53 AM   #13
Alexander
Alexander's Avatar
I agree.
07 Nighthawk Black Pearl TSX w/Navi
06 Wicked White Evolution MR - RIP 01.15.07
99 Flamenco Black Pearl Integra LS - Sold 09.07.06
Alexander is offline   Reply With Quote
Old 10-16-2003, 01:13 PM   #14
Jason
Jason's Avatar
Send a message via AIM to Jason
...and license plate bolts
Jason is offline   Reply With Quote
Old 10-16-2003, 01:26 PM   #15
Padawan
Darth ModerVader
Padawan's Avatar
Default Re: Proper OEM lug nut torque specs ? (Jason)
But then sometimes they don't end up with the screw-heads vertically aligned.
-NEMO ME IMPUNE LACESSIT-
Padawan is offline   Reply With Quote
Old 08-21-2009, 04:04 PM   #16
R_ACE1
2007 Honda CR-V
My Garage
R_ACE1's Avatar
Send a message via MSN to R_ACE1 Send a message via Yahoo to R_ACE1
I agree.
I second that notion.
"Be Polite, Be Professional, Be Prepared to Kill"
Dr. John Nagl, Lieutenant Colonel (ret), United States Army
R_ACE1 is offline   Reply With Quote
Old 08-21-2009, 05:13 PM   #17
safedriver
iTrader Rating: (1)
Use the torque wrench, and avoid "breaking off" a bolt/stud. Replacing a broken bolt isn't as easy to replace on Acuras, as they are to replace on Fords, Dodges, and GM cars.
safedriver is offline   Reply With Quote
Old 08-21-2009, 10:37 PM   #18
srt4mike
2005 Dodge SRT-4
srt4mike's Avatar
srt4mike srt4mike
Of course you can just guess, but it is definitely a best practice to use a torque wrench whenever possible. Guessing works fine and dandy until you mess something up.
srt4mike is offline   Reply With Quote
acura, crx, honda, integra, lug, nut, nutts, rsx, spec, specs, tl, torc, torque, type, wheel
