Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 10-14-2003, 04:04 PM   #1
FD3S
FD3S's Avatar
Default is fix-a-flat permanent?
taking a road trip tomorrow and my g/f's car recently had fix-a-flat used in one of the tires. we will be traveling over 200 miles each way. is the stuff permanent? will we be ok to make this trip? i think i am going to shucks to read the warning label, but in the mean time can u guys tell me?
FD3S is offline   Reply With Quote
Old 10-14-2003, 04:10 PM   #2
Dramier
Dramier's Avatar
Send a message via ICQ to Dramier Send a message via AIM to Dramier Send a message via MSN to Dramier Send a message via Yahoo to Dramier
Default Re: is fix-a-flat permanent? (FD3S)
Dude, don't use that ****. It eats away the tire and the rim.
You can get a patching kit for less than $10 and fix it with an insert patch which will work a whole lot better.
My Music: http://soundcloud.com/dramier/tracks
My Photography: http://dramier.deviantart.org
Dramier is offline   Reply With Quote
Old 10-14-2003, 04:20 PM   #3
FD3S
FD3S's Avatar
Default Re: is fix-a-flat permanent? (Dramier)
it was the g/f...it's already done...what i am asking is if it is safe for the trip...
Old 10-14-2003, 04:21 PM   #4
mantic6t9
mantic6t9's Avatar
Send a message via AIM to mantic6t9
I think it's only ment for temp use untill you can get a new tire. I have no idea how long it's suposed to last.
Parts FS: [url="http://www.honda-tech.com/zerothread?id=733263"]http://www.honda-tech.com/zerothread?id=733263[/url]
BMW Parts
[b]For Sale[/B]
OEM m3 Exhaust
OEM m3 Rear Shocks and Springs
mantic6t9 is offline   Reply With Quote
Old 10-14-2003, 04:22 PM   #5
Dramier
Dramier's Avatar
No it's not. You need to go and get a patch kit and do it right.
Trust me, I have been through this until somebody finally clued me in and told me not to use that spray can crap. Patching a tire is easy and cheapier than the fix-a-flat by quite a bit. Only takes about 45 seconds, and you're done.
Old 10-14-2003, 04:33 PM   #6
OnePointFive
overrated.
OnePointFive's Avatar
Send a message via AIM to OnePointFive
Fix a flat is only a temporary solution. it is NOT safe for going on a trip. As far as it eating away at your tire, that isn't true. What DOES eat away at your tire, is when you put fix a flat in it and it gets low and you start to drive on it with low air pressure the rim eats up the inner sidewall of the tire and it could cause a blowout. As far as those plug kits you buy at gas stations, those leak all the time. Once again, only temporary solutions. Your best bet is to just go to a tire place and get it patched from the inside.
good luck, and have a good trip Click the image to open in full size.
///M
PROfunction | iLL Garage | AMS Performance | ChaseBays | WMHM.ORG
OnePointFive is offline   Reply With Quote
Old 10-14-2003, 04:49 PM   #7
Xumarius
2004 Nissan 350Z
Xumarius's Avatar
Send a message via AIM to Xumarius
I *WAS* GDD's Image King
-----Originally posted by 93hatchin: "if J-Lo wanted to start something with you like a marriage would you do it!? think about it,the fame,the money,the butt...-----
Xumarius is offline   Reply With Quote
Old 10-14-2003, 04:50 PM   #8
brinks
brinks's Avatar
Send a message via AIM to brinks
I wil chime in with my agreement. I would never use that fix a flat. If its a small hole it can be patched permanently for about the same price as a can of that stuff. I would get a new tire or patchthe hole the right way.
brinks is offline   Reply With Quote
Old 10-14-2003, 05:34 PM   #9
Dramier
Dramier's Avatar
Default Re: is fix-a-flat permanent? (OnePointFive)
Sorry, I have to say you're wrong. I've seen it first hand learning the hardway. It will eat your rims and your tires. Pontiac Firebird Formula steel rims eaten away by fix-a-flat, and the rubber all in the inside of the tire looked like it had a low-grade acid on it for a few days. I'm telling you the stuff WILL eat your tires and rims. Maybe not all types or brands, but the one I used DID.
Have fun on the trip bro, and get a new tire! Click the image to open in full size.
Old 10-14-2003, 05:45 PM   #10
BeerMoon
BeerMoon's Avatar
Send a message via AIM to BeerMoon
Ate away the tires and rim on a old friends car, he ended up dying because he refused to spend the money for a new tire.
Ian
"You're a dambass" http://images.honda-tech.com/set1/smile/embeer.gif
BeerMoon is offline   Reply With Quote
Old 10-14-2003, 05:49 PM   #11
Rain_man
Rain_man's Avatar
Just like everybody else said, fix a flat is temp only. Lets you limp home.
I read a few years ago (from a reputable source) that some fix a flat stuff was flammable and when sometimes while the garage was patching the tire, a small explosion was set off. Chk the side of the can to see if it has any corresponding warnings.
Rain_man is offline   Reply With Quote
Old 10-14-2003, 05:54 PM   #12
OnePointFive
overrated.
Default Re: is fix-a-flat permanent? (Rain_man)
I work at Just Tires and i've never seen any corrosion on rims as a result of fix a flat.
But that's straying from the point, the point is, get your ish fixed!!
///M
Old 10-14-2003, 06:03 PM   #13
FD3S
FD3S's Avatar
looks like an early morning trip to les schwab...
Old 10-14-2003, 06:05 PM   #14
blkbeast
blkbeast's Avatar
i had fix-a-flat in one of my beater's tires for over a year without a problem....but i would still suggest getting the tires patched.
blkbeast is offline   Reply With Quote
Old 10-14-2003, 06:37 PM   #15
PhatboyNYC
PhatboyNYC's Avatar
Send a message via AIM to PhatboyNYC
I used Fix-A-Flat on one of my tires and although I didn't get any corrosion like some of the others have experienced, it caused my wheel to go out of balance. Click the image to open in full size.
PhatboyNYC is offline   Reply With Quote
Old 10-14-2003, 06:50 PM   #16
Stripped Honda
RIP Old HT
Stripped Honda's Avatar
Default Re: is fix-a-flat permanent? (PhAtBoY Si)
dont chance driving on a long trip like that fix tie tire the right way
it doesent nessarly eat away the tire but it is liquid and that mixed in a tire that has a metal rim will tend to rust and i have seen this first hand
at our shop we charge more to dismount a tire with fix a flat or slime in it because it just makes a mess of our shop
Current Toys 2007 Civic GX 1993 Toyota Truggy 07 Robalo R200 07 TRX450
Past Toys 07 Tundra (SOLD) 08 Tundra 4X4 (SOLD)99 White Civic EX (SOLD) 99 Black Civic (Stolen) 00 Black Civic (Stolen) 98 CW ITR (SOLD)
Stripped Honda is offline   Reply With Quote
Old 10-14-2003, 07:42 PM   #17
OnePointFive
overrated.
Default Re: is fix-a-flat permanent? (Stripped Honda)
same here, $5 extra for "fix a flat cleanout".
///M
Old 10-14-2003, 07:46 PM   #18
crujones
crujones's Avatar
Send a message via AIM to crujones
i dont have a spare, just a can of fix a flat. Click the image to open in full size.
So when i had some 17's i got a flat and it saved me. The fix a flat is still in the tire today and it works fine just rides a little off balance. So i traded the wheels anyway, so the fix a flat is no longer my problem. But it is great fix it you got no spare or a motorcycle. Worth the $5, but a regular fix or new tire is obviously better. Click the image to open in full size.
99 EBP JRSC'd SI SOLD
01 LEXUS IS300 SOLD
05 CADDY SRX
aim - pacopolosoprano
http://www.myspace.com/prettyboypaul
crujones is offline   Reply With Quote
Old 10-14-2003, 08:04 PM   #19
fluxion
amin n'rangwa edanea
fluxion's Avatar
just put it this way:
gf driving + tire blowout = you dead
96 Accord LX Coupe - F22B2 - I/H/C/E/Pulleys - Sold =*(
09 Civic EX Coupe with Navi
Ai, like gold fall the leaves in the wind... long years numberless as the wings of trees. The days have passed like swift draughts of sweet mead in lofty halls beyond the West, beneath the blue vaults of Varda, wherein, the stars tremble in the song of her voice, wholly and queenly. Who now shall refill the cup for me? - The Lament of Galadriel
fluxion is offline   Reply With Quote
Old 10-14-2003, 08:22 PM   #20
Starrman85
Starrman85's Avatar
Send a message via AIM to Starrman85
Default Re: is fix-a-flat permanent? (fluxion)
just get a new tire. i got rims and new tires last month, and then last week, somehow i got a screw in my driver side rear tire. brought it to americas tire company where i got the rims and tires, cost $27 to get a brand new tire mounted, balanced, and a new warrenty on that tire. best deal out there.
i have yokohama avs es100's, and each tire is 120 a piece. i would highly recommend getting tires where you can get a roadside warrenty, such as americas tire company.
06 Subaru Legacy Limited
92 Accord EX Coupe - SOLD
Starrman85 is offline   Reply With Quote
Old 10-14-2003, 08:26 PM   #21
turboman
turboman's Avatar
Default Re: is fix-a-flat permanent? (STARRMAN85)
Keep that **** ghetto. Fix a flat all the way
gone for now
turboman is offline   Reply With Quote
Old 10-14-2003, 08:29 PM   #22
Ricey McRicerton
Former Moderator
Ricey McRicerton's Avatar
Default Re: is fix-a-flat permanent? (turboman)
I busted a can of that **** in my car...worst stink ever. My buddys dad invented the ****...and he even said it's a temporary thing (had to call him real quick Click the image to open in full size. )
13 STi
04 4Runner
93 VFR750F
06 VFR800
Ricey McRicerton is offline   Reply With Quote
Old 10-14-2003, 08:33 PM   #23
KOALA YUMMIES
KOALA YUMMIES's Avatar
Default Re: is fix-a-flat permanent? (crujones)
Not worth risking your life over choosing to NOT carry a spare wheel + tire. Not worth the minimal benefit of weight reduction either. Rally cars are fully stripped and frequently get flat tires, they ALWAYS carry spares. Never seen them use a "fix-a-flat".
KOALA YUMMIES is offline   Reply With Quote
Old 10-14-2003, 08:40 PM   #24
mycivicstoo(s)low
mycivicstoo(s)low's Avatar
Send a message via AIM to mycivicstoo(s)low
Default Re: is fix-a-flat permanent? (KOALA YUMMIES)
Don't rally cars carry more than one spare sometimes? About the fix a flat, I used it for a long time on my old car, but I wouldn't do it again. The can says it's for temp use only, so....
mycivicstoo(s)low is offline   Reply With Quote
Old 10-14-2003, 08:42 PM   #25
KOALA YUMMIES
Default Re: is fix-a-flat permanent? (mycivicstoo(s)low)
O.T. Yeah I think they sometimes do carry more than one spare with them. I should too since mine are all unidirectional.
busted, car, fix, fixaflat, fixed, flat, liquid, long, messy, permanent, permantent, seattle, shucks, stays
