Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 10-13-2003, 05:33 PM   #1
udm_motorsport
udm_motorsport's Avatar
Send a message via ICQ to udm_motorsport
Default Removing check engine light/bulb from dash
Hi
I recently did a ZC swap to my Civic Si 1990.
By doing this, the check engine light is always on, and i cannot pass emissions with it on.
I was told to remove the bulb, but i dunno where to start. Any ideas as to how i can get rid of the light?
Thanks
Franklin
udm_motorsport is offline   Reply With Quote
Old 10-13-2003, 07:29 PM   #2
Rossifumi
Default Re: Removing check engine light/bulb from dash (to_carpediem)
reset ecu disconnect neg side wait 10-15 seconds reconnect should go out.
Rossifumi is offline   Reply With Quote
Old 10-13-2003, 07:31 PM   #3
jeff652
iTrader Rating: (1)
The smog station checks the CEL for proper functionality. Notice it turns on for 5-8 seconds when you start the car . . .
It does that for a reson ;-)
Nothing to see here . . .
jeff652 is offline   Reply With Quote
Old 10-13-2003, 08:26 PM   #4
0MrHeeltoe
Send a message via AIM to MrHeeltoe
Ever try to figure out what was wrong with it and, oh, say, fix it?
MrHeeltoe is offline   Reply With Quote
Old 10-14-2003, 04:39 AM   #5
udm_motorsport
Default Re: Removing check engine light/bulb from dash (MrHeeltoe)
Actually, reading alot of the ZC swaps, since we have to splice a couple of wires and rewire the distributor, they said the check engine light will be on all the time.
I reset the ecu, but that didnt work either. So i figured i'd just remove the bulb so i can get the car inspected.
Thanks
Franklin
Old 10-14-2003, 07:08 AM   #6
0MrHeeltoe
That is BS. I had two ZCs in Two different cars and never had a light or a problem.
Sounds like you need to fix some wiring or something.
Old 10-14-2003, 07:26 AM   #7
PhatOptimo
PhatOptimo's Avatar
What CODE is it flashing?
Whip list:
'08 S2000
'90 CRX
'94 240SX Coupe.
PhatOptimo is offline   Reply With Quote
Old 10-14-2003, 08:04 AM   #8
sleepyEK
sleepyEK's Avatar
Joshua Stein
Send a message via AIM to sleepyEK
Default Re: Removing check engine light/bulb from dash (PhatOptimo)
yeah, i have never seen a cel on a zc swap. you wired some **** wrong. go through your wiring harness.
sleepyEK is offline   Reply With Quote
Old 10-14-2003, 08:21 AM   #9
wickedEFguy
wickedEFguy's Avatar
Send a message via AIM to wickedEFguy
BUMP, Again check your codes man Click the image to open in full size.
90 Red CRX Si with a turbo B16 Jackstand garage conversion. http://images.honda-tech.com/set1/smile/emthup.gif
If you ***** us, do we not bleed? if you tickle us, do we not laugh? if you poison us, do we not die? and if you wrong us, shall we not revenge?".
-William Shakespeare
wickedEFguy is offline   Reply With Quote
Old 10-14-2003, 11:22 AM   #10
Katman
1992 Honda Civic
Katman's Avatar
http://www.facebook.com/pages/F-F-SQUAD/289856877081
Send a message via AIM to Katman
Originally Posted by to_carpediem
Hi
Thanks
Franklin
*shakes head*
why the hell would you wanna do that?!?
That's not gonna solve your problems in passing emissions at all.
Even though you'd remove the check light, your car is still going to be running in limp mode.
Find out what code is being thrown; report back so we can help.
Katman is offline   Reply With Quote
Old 10-14-2003, 11:57 AM   #11
1bad-eg
1bad-eg's Avatar
angryspicprfmns
FIX YOUR CEL Click the image to open in full size.
1999 Honda 900rr (Dr. Jekyll)
2006 Suzuki GSXR 1000 (Mr. Hyde)
R.I.P SuperSic
1bad-eg is offline   Reply With Quote
Old 10-14-2003, 12:01 PM   #12
udm_motorsport
Default Re: Removing check engine light/bulb from dash (1bad-eg)
OK, so how do i check the codes?
I'm very new to the civic and know not much.
I do have the integra ecu too.
Thanks
Franklin
Old 10-14-2003, 01:21 PM   #13
PhatOptimo
PhatOptimo's Avatar
http://www.c-speedracing.com/faq/06.php
You don't need a paper clip like it says. Skip that part. Out cars don't have that blue connector.Turn the key to the on position and count the ECU light flashes. The ECU is under the passenger footwell carpet.
The code list is here
http://tech.hybridgarage.com/tech/codes.html
Whip list:
'08 S2000
'90 CRX
'94 240SX Coupe.
1991, 1999, accord, bulb, cel, check, civic, disable, disconnect, engine, honda, light, remove, removing, si, smog
