> Tech/Misc
Old 10-10-2003, 08:47 PM   #1
Jeff C
Jeff C's Avatar
Send a message via AIM to Jeff C
Default Here's a little tranny how-to for j00!! (34 pix)
Well I had a mishap with my newly installed clutch. The splines on the clutch disc completely stripped out and took a little of the splines off the mainshaft in my tranny. Not cool. I did not want to install the new disc with the manishaft partially stripped so I bought a new mainshaft from Acura, $230. I figured that while I was in the tranny I would do a little how-to. A lot of people are afraid to go inside a tranny for fear all the parts inside, I guess. This is my attempt at show-and-tell. Btw, this is on a ‘92 GSR YS1 cable transmission.
First thing first, disconnect the battery and put Nikki in the house
Here are the tools that I used.
A shot of the patient and its new inard part
The first thing that I did was remove the clutch lever and release bearing by removing this bolt right herrr
then I removed the back up light switch
remove clutch cable bracket
then remove a few other misc bolts around the case
then this sealing bolt
which reveals the dreaded snap ring
lastly remove all the bolts that hold the transmission housing to the clutch housing
this is a good point for a drink of water
ok, now crack the two halfs apart
using the reverse snap ring tool (a must) spread the snap ring and the countershaft should clunk as it drops off the snap ring
closer look
and pull the trans housing up, you may have to wiggle it a little, and there you have it…the inards are exposed
then start removing the pieces around the counter and mainshafts,
first the reverse changer holder
then the reverse idler gear
then the shift piece/shift arm holder/select arm……stuff
now remove the countershaft w/ gears and synchros, mainshaft w/ gears and synchros and shifter forks all at once
and there sits the whole clump
another good point for a drink of water
here is the new and old mainshafts together. Also I have removed all the gears and synchros off the old shaft and have placed them upside down, in order, off to the side
here is the old mainshaft, you can see the shininess, that is where is has a little wear from the clutch disc strpping out
now, grease the new mainshaft up with assembly lube and start putting the gears and synchros on
here is the final assembled mainshaft
clean the hondabond off, wipe some old grease off, and lube up the sockets where the counter and mainshafts and shifter fork go into the tranny
now put in the countershaft w/ gears and synchros, mainshaft w/ gears and synchros and shifter forks all at once
here is the tranny with all the inards in and lubed up ready for the tranny case to go back on
now, if you get something out of order the helms manual, which I know you bought before you attempted this, has a nice exploded view with descriptions for everything inside and out of the tranny
Just put it back together in reverse order and don’t forget Hondabond and to torque all the bolts down correctly. If something is hard to put back together, then that probably means something is not right so double check. I hope now that you realize that working on the transmission is not all that bad. I may have forgot something so take your time.
Overall, it took me about an hour, and I was farting around. Level of difficulty would be about 2.5 on a scale of 10, at least I think so.
1998 Accord Sedan EX 5 spd, will always be stock
1981 Silverado bagged, shaved and 20s...maybe Duramax
Jeff C is offline Report Post   Reply With Quote
Old 10-10-2003, 09:29 PM   #2
Roger
Roger's Avatar
good job. I like the portion when you had a drink of water. we did one of these last week and it took us about an hour with afew drinks from the hostess.
Roger is offline Report Post   Reply With Quote
Old 10-10-2003, 09:33 PM   #3
PhatOptimo
PhatOptimo's Avatar
Default Re: Here's a little tranny how-to for j00!! (Jeff C)
Snap ring pliars are not needed. Needle nose pliars will get the job done.
That white grease is not needed, MTF is.
Screw the water wheres the
Trannys are childsplay .
Good pics except the H2O.
Whip list:
'08 S2000
'90 CRX
'94 240SX Coupe.
PhatOptimo is offline Report Post   Reply With Quote
Old 10-10-2003, 10:00 PM   #4
bartek_b
Send a message via ICQ to bartek_b
Default Re: (Roger)
very nice writeup
bartek_b is offline Report Post   Reply With Quote
Old 10-10-2003, 10:21 PM   #5
Chiovnidca
Chiovnidca's Avatar
Yea, five speeds are easy. Did you clean, inspect and check the clearances before you put it back together? Usually when I see a mainshaft torn up like that there are usually syncros getting on the loose side and/or bent shift forks.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline Report Post   Reply With Quote
Old 10-11-2003, 01:33 AM   #6
7PSI CRX
7PSI CRX's Avatar
Excellent job.
Good clear pics!
Ive got a question or two if you don't mind.
1 - Think you can point out for me the bearings that give the dreadful "whine" on my old '91 Si tranny?
(I want to attempt the rebuild, but don't want the tranny sitting apart while I wait on the bearings. I want the parts on hand so I can get it back together the same day so I don't forget how things go. Letting it sit on a bench for a few days can only lead to possible problems)
2 - And I assume those bearings on the shafts slip off, no press needed?
3 - And the bearings that remain in the case, are they easily replaceable, or a press is necessary?
7PSI CRX has driven one of two CRXs for over 269,000 miles
His ass was hurtin', so he got rid of the CRX,
and now drives an '05 Legacy GT LTD
7PSI CRX is offline Report Post   Reply With Quote
Old 10-11-2003, 02:29 AM   #7
DCStreetHtch
DCStreetHtch's Avatar
Send a message via AIM to DCStreetHtch
bump so this is in my topics!!
-Bryan-
Dunk SB "HUNTERS" Reese Forbes II's size 10.5, Serious HEATTTT here!!!
Liars and Thieves, all of you!
DCStreetHtch is offline Report Post   Reply With Quote
Old 10-11-2003, 06:24 AM   #8
tinkerbell
tinkerbell's Avatar
Send a message via AIM to tinkerbell
Default Re: Here's a little tranny how-to for j00!! (EGStreetHtch)
bloody excellent mate!
real good work,
i assume it would be that easy to change a syncro too?
www.jscc.asn.au
Japanese Sports Car Club
"ban low performance drivers - not high performance cars"
tinkerbell is offline Report Post   Reply With Quote
Old 10-11-2003, 06:49 AM   #9
vtec_r
vtec_r's Avatar
Default Re: Here's a little tranny how-to for j00!! (tinkerbell)
Very nice job
Everone should learn how to install there own sh*t
vtec_r is offline Report Post   Reply With Quote
Old 10-11-2003, 07:52 AM   #10
Hybridize
Hybridize's Avatar
Excellent post!
'90 CRX Si - B20B - S1/LS5th
Best MPG to date. 42.24, route driven.http://images.honda-tech.com/set1/smile/embeer.gif
My vouch thread.
Hybridize is offline Report Post   Reply With Quote
Old 10-11-2003, 10:48 AM   #11
Mista Bone
Mista Bone's Avatar
Send a message via AIM to Mista Bone
nice craftsman #45492 snap ring pliers..........
"D" Tranny Guru
Mista Bone is offline Report Post   Reply With Quote
Old 10-11-2003, 11:25 AM   #12
PHiZ
PHiZ's Avatar
Send a message via AIM to PHiZ
Thanks for the helpful post!
-PHiZ
I still ain't touching that scary bastard!
More go fast, less look fast.
Wideband tuning, ECUs, Conversion Harnesses, and ECU chipping available!!
PHiZ is offline Report Post   Reply With Quote
Old 10-11-2003, 12:55 PM   #13
Jeff C
Jeff C's Avatar
Default Re: Here's a little tranny how-to for j00!! (Chiovnidca)
PhatOptimo, you can use your pliers and drink your , but i wouldn't trade these snap ring pliers for anything.
Chiovnidca, about 75% of the gears and synchros in there were replace 25k mi ago. There is no play. The problem was the splines on the outside end got a little beat up. The inside are ok.
7PSI CRX, I personally am not familiar with the whining that you are talking about so I cant help you there. Correct, you do not need a press. However, there is a nut on the end of the countershaft, like the axle nut, that is a little PITA. The bearing in the case can easily be tapped out with a mallet.
tinkerbell, yes it easy to replace the synchros. you just need to make sure that you get them back in the correct place cause they are not all exactly the same.
Mista, I am glad you told me about those things awhile back. They are awesome!!
Thanks for the props. I hope that it helps somebody. Now I have to go install the tranny back into the car.
Old 10-11-2003, 01:35 PM   #14
baphomet
baphomet's Avatar
great work - I have a new found confidence
baphomet is offline Report Post   Reply With Quote
Old 10-11-2003, 01:55 PM   #15
Propulsion
Propulsion's Avatar
Default Re: Here's a little tranny how-to for j00!! (slashDEVslashNULL)
ok, not as hard as its cracked up to be...
is putting in a LS 5th gear just as easy?
<U>Vouches</U>:
I8ayellowcrayon, Lang, 137, pravo2, 94white-si, Aberkrombie,
HmgLauj69, gotGSR, 3Tdt, thermal, EBP-Si, SRCivic97, Navin,
terrible one, speed94, Ek-CoolGuy, dIveR$E[323], EF8 JUNKIE9,
ernald711, CIVICMIKE, siblue_gzer, pdiggitydogg, Pearl Crx, IntegraDA
ITR EG, Quick 99, JDM INSPIRED, fishnfst, EKHB, UCLAcivic, Acura_I-RS,
jetpilot, Riceball777, TEAM562racing, RyanR
Propulsion is offline Report Post   Reply With Quote
Old 10-11-2003, 05:43 PM   #16
Jeff C
Jeff C's Avatar
Default Re: Here's a little tranny how-to for j00!! (SilverCIVIC96)
I am not sure what all is involved in putting a different gear in, ie having to use a different synchro too, but replacing gears is yes, just as easy.
Old 10-11-2003, 06:28 PM   #17
Mista Bone
Mista Bone's Avatar
once you get the gear shafts out, swapping fifth gear only takes about 5-10 minutes. Getting to 30mm nut off is the hardest part.
"D" Tranny Guru
Old 10-11-2003, 06:40 PM   #18
baphomet
baphomet's Avatar
Default Re: Here's a little tranny how-to for j00!! (Mista Bone)
Now I need a Quaife how-to and I'm set
Old 10-11-2003, 08:21 PM   #19
PhatOptimo
PhatOptimo's Avatar
Thats got to be a TEG tranny. Bone told me abot thoes pliars a while back. I havent been to Sears to get them yet . Time to install .
Hers a few form my last encounter with my Y1.
All glued up and ready to install
Modified by PhatOptimo at 11:18 PM 10/11/2003
Whip list:
'08 S2000
'90 CRX
'94 240SX Coupe.
Old 10-11-2003, 08:36 PM   #20
Audi RS4
Lover
Audi RS4's Avatar
it looks scary
Glock 9X19..... http://images.honda-tech.com/set1/smile/emwink.gif
06' CBR600RR
03' Audi A4 1.8T Quattro (BEAST)
Jack "YACK" Harris & P1 Auto http://images.honda-tech.com/set1/smile/emthup.gif
PLEASE HELP ME!
Taking $1 to $5 donations. Paypal 03Audi@comcast.net Any help is appreciated.
Audi RS4 is offline Report Post   Reply With Quote
Old 10-12-2003, 11:16 AM   #21
Jeff C
Jeff C's Avatar
Mista, thanks for the input. I know how to replace a stock gear with a stock gear, but i was not for sure what would be involved in replacing a stock gear from one tranny with a stock gear from another.
slashDEVslashNULL, i have done a couple to those too. You would take the tranny apart the same way (obviously) and remove the gear sets the same way (obviously). The diff just pulls right out. The biggest PITA about a Quaiffe install is getting the correct shim. How I did it was put the put the Quaiffe in, reassemble the whole tranny and check for shim clearences just like the manual said. If it was good, then remove the case and apply the HOndabond. If it is not, keep trying different shims till you find the correct one with the proper clearences.
PhatOptimo, yes its a teg tranny, YS1. And yes the tool comes in very handy. Thanks for adding the pics too.
Old 10-12-2003, 11:25 AM   #22
advanracing62
advanracing62's Avatar
Send a message via ICQ to advanracing62 Send a message via AIM to advanracing62
good write up! I agree that Trannies aren't anything hard to work on.. just gotta remeber where shit goes!
It's so quiet this high up, the feeling you get is that you're one of those space monkeys. You do the little job you're trained to do. Pull a lever. Push a button. You don't understand any of it, and then you just die.
advanracing62 is offline Report Post   Reply With Quote
Old 10-12-2003, 11:28 AM   #23
Burke
Banned
Send a message via AIM to Burke
those winey gears could be on either side of the diff - mine were, but you will need a puller to get them off. the whine could also be the bearing on the shaft or the ones pressed into the casing. the ones in the casing you can just pop out too.
Burke is offline Report Post   Reply With Quote
Old 10-12-2003, 12:31 PM   #24
Wes V
Wes V's Avatar
Default Re: Here's a little tranny how-to for j00!! (Burke)
Jeff;
That's a great write-up!! I totally agree with the "water" aspect of it! (no preaching, just a little fun)
Maybe I'm in the wrong generation, but what's a "Nikki"?
About that snap ring;
Can the snap ring be removed / or installed through the access hole? The access hole doesn't look large enough to get it in and out.
You made a comment that you will hear a "clunk" when the countershaft falls free. Am I correct that this is due to already having the cases spread apart? If you just pulled the cases apart, I'm assuming that the gears would fall all over the place as they came off the counter shaft.
When putting it back together, do you have to worry about the countershaft being in the correct position to get the snap ring on? Does the snap ring just flop around free, after bolting the transmission halfs together and before it's snapped into place?
Thanks!!
Wes Vann
Wes V is offline Report Post   Reply With Quote
Old 10-12-2003, 01:29 PM   #25
MrTodd
MrTodd's Avatar
Default Re: Here's a little tranny how-to for j00!! (Wes V)
I also have the same question as listed above...
In addition to that, I'm also wondering about the 'whine' that my '90 Si (CRX) tranny makes. Someone said that it could be the bearings in the differential??? And you need a puller to get to those? What's a puller?
"It is better to destroy than to create what is meaningless, so the picture will not be finished."
MrTodd is offline Report Post   Reply With Quote
Bookmarks
countershaft, haves, honda, lsd, pics, s1, snapring, transmission
