#351 | ||||||
#352 |
So how do I fix my miss fires, Knock sensor, Idle speed control? ???? anyone???
For the Idle speed control Do I fix change my IAVC? |
#353 |
#354 |
How to change out your steering collum
ok i just did this in my car and ill let you know how it is done.. i swaped from a stock eg steering rack with no tilt to one with one so ya its was sweet.. its all pretty much just look for bolts and undo them.. 1.take steering wheel off 2. undo all wires 3. undo all bolt that apear to be holding in on 4. after this is done remove the black housing that goes around the end of the steering collum. 5. undo the 1 bolt that clamps it together 6. pull out the steering collum 7. this is the hard part.. you wil need to take the ignition off if you are going to use yours so you must grind down the studs that hold it on that then you are game.. i went to honda and bought a new bracket for like $2 it was cheap and then i replaced bolts with the studs. 8. after this is done reinstall everything and you are done.
2001 civic ex DD 1995 civic dx project http://images.honda-tech.com/set1/smile/emsmile.gif |
#355 |
#356 |
How To: Wire 99-00 OEM Fog Lights /w Parking Lights |
#357 |
good info
#358 |
#359 |
my how to:
http://clubhondaspirit.com/foro/topi...s-oem-del-sol/ http://clubhondaspirit.com/foro/topi...faros-casioem/ In spanish SORRY |
| Bookmarks |
| Tags |
| 16l, 2000, 92, 95, accord, axles, civic, cleaning, diagram, egr, fluid, lead, replace, rod, tie, transmission, vtec, wiring |
