Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 08-29-2003, 10:33 PM   #1
JonGP4
2010 Honda Civic
JonGP4's Avatar
Default what does the map sensor do?
does it have anything to do with the fuel delivery? cuz i'm still geting gas miliage in the high 20s, so i figure some other sensor just be ******* up
1992 Accord EX Coupe - Sold
1988 CRX Si (DOHC ZC, Apexi Turbo kit) - Parted/Sold
1993 Del Sol Si (JDM H22A, 50shot) - Sold
1997 Prelude (Got T-Boned, rebuilt) - Sold
1996 Intgera SE - DD/Autox
JonGP4 is offline   Reply With Quote
Old 08-29-2003, 10:36 PM   #2
Chiovnidca
Chiovnidca's Avatar
Default Re: what does the map sensor do? (JonGP4)
The MAP sensor tells the ECU how much presure is in the intake manifold. (Vacuum) Click the image to open in full size.
http://www.honda-tech.com/zerothread?id=1010778
400+hp d16z6 11.0@137
Chiovnidca is offline   Reply With Quote
Old 08-29-2003, 11:07 PM   #3
EG8R
EG8R's Avatar
Default Re: what does the map sensor do? (Chiovnidca)
It takes a(meaning one) reading of atmospheric pressure when you first turn the key on and it uses that # to determine other settings.... Fuel mixture, blah blah blah....
95 Civic LX-C5 powered -- Ferio EG Squad #39 - SOLD
90 Civic SiR - Yes a REAL EF9! -- Sh!tbox EF9 Squad #1
06 Civic LX-right $h!tty
EG8R is offline   Reply With Quote
Old 08-29-2003, 11:10 PM   #4
JonGP4
2010 Honda Civic
JonGP4's Avatar
Default Re: what does the map sensor do? (skelly ed6)
cool thats what i wanted to know, so it is fuel related
thanks
Old 08-29-2003, 11:59 PM   #5
Chiovnidca
Chiovnidca's Avatar
What do you mean about it taking one reading? What other settings does it determine?
Old 08-30-2003, 02:21 AM   #6
EG8R
EG8R's Avatar
MAP sensor is the #1 most important sensor in the whole car. The entire fuel and timing map depends on a precise reading from the map sensor.
Better? I can't think right now. Its almost 4:30am....
Old 08-30-2003, 06:34 AM   #7
rioninja
rioninja's Avatar
Send a message via AIM to rioninja
For bad gas milage, i would check your o2 sensor if its fairly old. An old sluggish o2 can cause a decent decrese in gas milage.
Proud member of:
HB SQUAD
"We dont need no stinkin trunks!"
<FONT COLOR="red"><FONT SIZE="4">For Sale:</FONT></FONT>-&gt; 90 hf complete car harness.
PM me.
rioninja is offline   Reply With Quote
Old 08-30-2003, 08:35 AM   #8
JonGP4
2010 Honda Civic
JonGP4's Avatar
Default Re: what does the map sensor do? (rioninja)
already replaced it with a 4 wire it helpped alittle bit but not enough for me to be satified
Old 09-07-2003, 11:49 AM   #9
Superhatch
1991 Honda Civic
Superhatch's Avatar
Send a message via AIM to Superhatch
To back that up....my MAP sensor just died last night, and the result is that my ecu gives me no spark, or fuel. They car is totally dead. Basically if it doesnt get that reading, then it doesnt run.
The voltage reading across the yellow, and red (from memory...dont quote me) wires is supposed to be 5v. If you dont get a reading "across" them, then put them both on one lead, and put the other lead to a ground. If you still dont get a reading, then you have a faulty MAP sensor.
-Jake
thebrz.blogspot.com
Kimi passes -into- Eau Rouge!
Superhatch is offline   Reply With Quote
Old 09-08-2003, 08:33 PM   #10
Superhatch
1991 Honda Civic
Superhatch's Avatar
Default Re: what does the map sensor do? (Superhatch)
I lied. The map sensor wont ever shut off your car. Your timing belt shearing off some teeth, and then skipping on the otherhand...will. Back to the drawing board Click the image to open in full size.
-Jake
thebrz.blogspot.com
Old 09-08-2003, 08:37 PM   #11
EG8R
EG8R's Avatar
I unplugged my MAP sensor the other night while my car was running and it shut off....
Whats a good way to put my car into limp mode?
Old 09-08-2003, 09:43 PM   #12
B17CR-X
Before you go jumping all over your MAP sensor, when is the last time you did a full tune up? Is your air filter clean? it should be replaced every 12K (along with your pcv) or cleaned if you have a K&N style gauze filter. How bout the fuel filter? It needs replacing every 12k as well. Don't forget the cap, rotor, and correctly gapped spark plugs, I always check the gap on new plugs which are supposedly pre-gapped you never know if they were dropped, squished, etc.... Also don't neglect the O2 sensor it has considerable impact on fuel economy. Do the easy stuff first as it is likely needed, then if you still have problems grab a digital multi meter and a helms and look into the less likely culprits. HTH
-Joel
B17CR-X is offline   Reply With Quote
Old 09-09-2003, 06:59 AM   #13
DJ_SaNdOz
DJ_SaNdOz's Avatar
-Jake
Uuuuum, no. The MAP sensor will kill the car. Mine went out about 1 month ago while driving & the car kept stalling out & it gave me teh MAP code. I could not keep the car running no matter what I tried until I put in another MAP sensor.
'10 Ducati Monster 696 - modded, '05 Ruckus -187cc GY6 swap, '02 RSX Type S - mostly stock, '99 Prelude - mostly stock
DJ_SaNdOz is offline   Reply With Quote
1992, 2000, accord, bad, car, civic, do, element, faulty, h22a, honda, jdm, map, put, sensor
