what do you guys use to cut off the 2 lca bolts?
Old 08-15-2001, 12:44 PM
New User
b18bvudoo's Avatar
Default what do you guys use to cut off the 2 lca bolts?
saw, dremel (dont have this one), somehow drill it out?
the damn bolts are seized to the lca bushings and wont budge, even w/ hammering. thx.
Old 08-15-2001, 01:20 PM
ALF
ALF's Avatar
Default Re: what do you guys use to cut off the 2 lca bolts? (vudoo666)
What I did was unbolt the shocks and LCAs completely. Then I unbolted the ABS lines from rotor/hub and the places on the LCA where it bolts on. After that, I dropped both the shock and LCA as one whole piece. I did it the hard way and used a hacksaw.
sgT
sgT's Avatar
Default Re: what do you guys use to cut off the 2 lca bolts? (Dozed)
sawzall
or die cutter, but sawzall is more fun
Old 08-15-2001, 01:34 PM
New User
92sleepR's Avatar
Default Re: what do you guys use to cut off the 2 lca bolts? (Teken)
I used a sawzall but "fun" it was not.
Mike
Old 08-15-2001, 01:38 PM
KL
New User
KL's Avatar
Default Re: what do you guys use to cut off the 2 lca bolts? (92sleepR)
Sawzall is the shop used on my car, the poor guy who had to do the job must have all his fillings shaken out after cutting 3 bolts that were seized.
Old 08-15-2001, 07:19 PM
keithv's Avatar
I used an angle cutter on a 150 psi compressor. 10 minutes and 4 cuts later, the LCA dropped right out.
Old 08-15-2001, 07:55 PM
ctenche's Avatar
Default Re: what do you guys use to cut off the 2 lca bolts? (breaka_1_9)
Try a torch. Melt the rubber pushing and then press out the metal sleeve. It's a pain in the but.
Take it to any garage and they can do it for you really quickly. It's a pretty common thing on Integras.
Old 08-15-2001, 08:46 PM
New User
b18bvudoo's Avatar
Default Re: what do you guys use to cut off the 2 lca bolts? (ctenche)
well, i went w/ the trusty hacksaw, and after 1 bolt my arms and lower back were about to give out. didn't realize that we had an electric hacksaw in the house so got smart and used that.
didnt want to use a blow torch (got a microtorch) 'cause of all the wd40 and liquid wrench i had sprayed earlier.
now i gotta go get new lca bolts and a new lca from the dealer. anyone know how much an lca is??
cehcivic15
14
06-18-2012 12:50 PM
josh green
Suspension & Brakes
09-27-2008 06:01 PM
SWC
Suspension & Brakes
05-09-2006 08:35 PM
oMek
05-06-2004 01:06 PM
ebelp
03-01-2002 05:16 AM
Quick Reply: what do you guys use to cut off the 2 lca bolts?
