> Honda CRX / EF Civic (1988-1991)
Old 08-24-2003, 01:56 PM   #1
ProjectGreenLS
ProjectGreenLS's Avatar
Send a message via ICQ to ProjectGreenLS
Default 91 civic hatch fuel pump location?
my friend just called me for advise on where the fuel pump on his 91 civic fuel pump is located. i have no idea, do you? if anyone has a skematic, or pic, that would help too!
[url="http://www.imagestation.com/album/?id=4289454781"]The Teg Gets a Boo-Boo.[/url] [img]http://images.honda-tech.com/set1/smile/emsad.gif[/img]
ProjectGreenLS is offline   Reply With Quote
Old 08-24-2003, 02:18 PM   #2
Maxbore.com
Maxbore.com's Avatar
Default Re: 91 civic hatch fuel pump location? (ProjectGreenLS)
It's inside the fuel tank.
You have to drop the tank if you want to get to it.
Honda kindly enough, changed the design on the 92+ civics so that you can get to the pump from inside the car without having to drop the tank.
Still boring throttle bodies.
Maxbore.com is offline   Reply With Quote
Old 08-24-2003, 02:24 PM   #3
fourthgenhatchB17
fourthgenhatchB17's Avatar
Default Re: 91 civic hatch fuel pump location? (Spaceballs the lunch box)
Yep. A friend told me that he managed to change the pump by only dropping one side of the tank to get access to the pump. He said dropping the entire tank was not necessary. Can anyone confirm this?
B.A.R. certified
Cleaning out my garage!
http://www.hondamarketplace.co...20972
fourthgenhatchB17 is offline   Reply With Quote
Old 08-24-2003, 02:47 PM   #4
RenoRacing
RenoRacing's Avatar
Default Re: 91 civic hatch fuel pump location? (fourthgenhatchB17)
you just have to undo two 12mm in the rear of the tank that are attached to straps that hold the tank up, if you loosen them about 1" down then you can push up on the straps and they'll come out of their grooves and the tank will angle plenty enough to pull the pump. I've had to do it like 3 times, once in the dark, i can do it in about 10 minutes now.
RIP Ryan Image
RIP Andre Murillo
RIP Abby Macdonald
RIP Beau Shaver
RenoRacing is offline   Reply With Quote
Old 08-27-2003, 07:52 AM   #5
gtcali
gtcali's Avatar
Send a message via AIM to gtcali
Default Re: 91 civic hatch fuel pump location? (HavokRacing)
Walbro in-tank part number for EF?
gtcali is offline   Reply With Quote
Old 09-01-2003, 07:41 PM   #6
SOHC Gord
SOHC Gord's Avatar
Send a message via AIM to SOHC Gord
its in the tank and i think i would be alot easyer to drop both sides of the tank rather than just one i had no clue on what i was in for when i did mine so i took it slow and made sure i did it right and it took me about 2 hours from start to finish. its not that bad. i did have a problem getting the pump out itself it was a bitch you have to anle it and it was a very tight squeeze! other than that no problems no as bad as u think.
I LOVE YOU HONDA
SOHC Gord is offline   Reply With Quote
91, civic, drop, droping, ef, feul, fuel, hatch, honda, installation, locate, location, pump, tank, tech
