Spark plug Recommandation and GAP for High Compression Motors..
Old 08-09-2003, 07:15 AM
crxsirvtec's Avatar
Default Spark plug Recommandation and GAP for High Compression Motors..
Hey...
I would like to know the best plug with low resistance wires, and MSD Coil and Multi Spark Box, along with the proper Gap...
thanks
Old 08-09-2003, 05:45 PM
a/k/a Jomo
Mr Hammond's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (crxsirvtec)
Well Rocket's plugs gapped to .035" seem to work out nicely. However something like NGK BKR6E-11 gapped to the standard 1.1mm or .043" will work as well.
Old 08-09-2003, 06:13 PM
98itR484's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (Mr Milano)
i use BOSCH 4227 dyno tested at IB and makes power, also made more power on my motor compared to stock.
Gap is .035
change them ever oil change cuz they are cheap $1.99 each.
Old 08-10-2003, 05:37 PM
fox297's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (PacMan ITR)
Would iridium plugs perform better in high compression engine?
Old 08-10-2003, 10:11 PM
JDMs1eeper's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (fox297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fox297 &raquo;</TD></TR><TR><TD CLASS="quote">Would iridium plugs perform better in high compression engine?</TD></TR></TABLE>
would they? I wanna know to
Old 08-11-2003, 02:50 PM
Rocket's Avatar
Way over-rated. Don't waste your money on exotic spark plug material.
Go NGK or Autolites in the proper heat range and you'll be cool.
Also don't gap more than 0.038 for NA and not more than 0.024 for FI.
Old 11-09-2003, 07:43 PM
ninja8oi's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (Rocket)
Is it better to regap plugs to a smaller gap. I think OEM is .044" and i forgot what the NX tech guy told me but I think it was .030 " gap. I am tring to confirm this. I have nitrous in my integra LS. The plugs i'm going with are ZFR7F-11 which are two steps colder than stock. What does making the gap smaller do anyways
Old 11-10-2003, 05:43 PM
Rocket's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (ninja8oi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninja8oi &raquo;</TD></TR><TR><TD CLASS="quote">Is it better to regap plugs to a smaller gap. I think OEM is .044" and i forgot what the NX tech guy told me but I think it was .030 " gap. I am tring to confirm this. I have nitrous in my integra LS. The plugs i'm going with are ZFR7F-11 which are two steps colder than stock. What does making the gap smaller do anyways</TD></TR></TABLE>
smaller is usually better especially for Nitrous or FI.
Old 11-10-2003, 08:34 PM
VtecDA9's Avatar
NGK BKR7
Old 11-10-2003, 08:39 PM
-KangaRod-'s Avatar
copper is the best material for spark plugs usally. All those fancy ones are just designed to last longer, but since we are not ricers we don't care about length before replacement. I'll be running coppers untill they make artifical spark plugs from some sort of electrocharged plastic.
Old 01-27-2004, 12:06 PM
myhatchrips's Avatar
arent you supposed to run the highest gap possible unless your misfiring up top, then you go ahead and lower the gap setting. correct?
Old 01-27-2004, 12:43 PM
TodaSi's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (myhatchrips)
I like to run NGK
BKR7EVX-11 smaller tip, better flame kernal
also like good old coppers BKR7E-11's
Old 01-27-2004, 12:46 PM
TodaSi's Avatar
Default Re: Spark plug Recommandation and GAP for High Compression Motors.. (TodaSi)
Oh and if you want Iridium then go with NGK BKR7EIX-11 which are only around $6.50 each at http://www.clubplug.net/index.html
89si-rex
33
10-09-2013 11:20 AM
janiscrulzz
12
01-10-2012 12:14 AM
vtec2nv
23
12-10-2006 08:23 PM
Power Rev Racing
07-20-2005 09:08 PM
AllMoToRB18c
64
11-25-2003 12:47 PM
Quick Reply: Spark plug Recommandation and GAP for High Compression Motors..
