Top speed of a 94 del sol si?
Re: Top speed of a 94 del sol si? (Deli_Time)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deli_Time »</TD></TR><TR><TD CLASS="quote">I was test drivin a 94 Sel Sol Si with the d16 z6 motor and it ony got up to 95mph....is that how fast it is stock?
I've been up to 115mph comfortably in my car, so you should be able to get there too. Be safe on the roads though.
I heard somewhere that the top of 5th on the Z6 motor goes to 125...I'm pretty sure you could get close to that speed if you wanted. I got to the top of 4th once and that was pretty high speed and if I did shift to fifth and not get scared, it wouldn't have dropped in RPM's that much...cuz 5th gear on that tranny is actually pretty short.
If you can manage to redline 4th (and that means putting it past the redline on the stock tach - it's inaccurate) then you will be at 125mph. 5th gear is not going to pull at those speeds. The speedometer is also inaccurate and it will say 130mph+.
Auto?
Auto?
Was it still accelerating when it got to 95 mph or did it just run out of motor? If it was a car that was already modded, now it's for sale, it might have some problems like a hurt motor. If your really serious about the car then take it and have a shop do a used car inspection and compression test on it.
Re: Top speed of a 94 del sol si? (nsxmatt)
i got my 94 si up to 120, and my friends 93 s hit 110. you engine must be F*CKED. if the s hit's 110, and you can't hit 95, that says something. talk to ya later
WESLEY
WESLEY
lxc420
05-27-2011 04:54 AM
Monarch
26
02-22-2002 02:39 AM
