Go Back   Honda-Tech > Honda and Acura Technical Forums > Hybrid/Engine swaps
Old 07-28-2003, 12:06 PM   #1
Casey
Casey's Avatar
iTrader Rating: (4)
Send a message via AIM to Casey
Default How to tell if distributor is bad?
I am trying to figure out if my distributor needs to be replaced. The wires that are tucked behind the plastic cover behind the rotor have been melted/rubbed down, i took a pic to show what i mean. There was no plastic cover when i opened the dist up, and when i tried to put one it, it didnt fit right. Can i just replace the wires or do i need a whole new distributor? I tried a new rotor today, am getting a cap tomorrow, thanks for the help Click the image to open in full size. Click the image to open in full size.
Casey is offline   Reply With Quote
Old 07-28-2003, 01:20 PM   #2
Blaze45
Blaze45's Avatar
Default Re: How to tell if distributor is bad? (Casey)
If you still have your old ignitor and coil you can just swap em out and see if that does anything. As for the wires, can you solder some wires onto em?
Blaze45 is offline   Reply With Quote
Old 07-28-2003, 02:15 PM   #3
Casey
Casey's Avatar
iTrader Rating: (4)
Default Re: How to tell if distributor is bad? (Blaze45)
i decided to just solder the wires as best i could, and went back, the shop had a cap, so i installed that. seems to have work better than anything but still unsure
bad, cover, distrbutor, distributer, distributor, gettin, honda, hondatech, plastic, replaced, rotor, tech, working
