Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 07-27-2003, 07:53 AM   #1
92TEGsrSC
Send a message via AIM to 92TEGsrSC
Default Greddy boost gauge???
I was recommended by some friends to get a greddy or apexi boost gauge instead of autometer if I wasn't pinching pennies, so I went ahead and ordered the greddy boost gauge... on the website it's really hard to get a close look at the boost gauge... is my gauge the one everyone receives?... the gauge only goes up to 2.0 and is in kg/cm2 (squared) units... I was expecting lbs/in2. Are all greddy gauges like this??? do any of the greddy boost gauges come in psi units? Also, what is the conversion. how many psi of boost is 0.5 kg/cm2.... 1.0 kg/cm2.... 1.5 or 2.0 kg/cm2? Should I keep this gauge, or send it back? I guess this is probably a newbee question, but I would appreciate any help you guys can give me...
Thanks in Advance,
Zack
92TEGsrSC is offline   Reply With Quote
Old 07-27-2003, 07:59 AM   #2
Aiyoko Turbo
Send a message via AIM to Aiyoko Turbo
Default Re: Greddy boost gauge??? (92TEGsrSC)
Yes. I believe none of them are in psi. It's cool you know, but when it comes to tuning and looking for advice, it just takes another step to convert it.
I have the AutoMeter Boost gauge and it works really well, showing up to 20 psi of boost and 30 thingies of vaccum.
Aiyoko Turbo is offline   Reply With Quote
Old 07-27-2003, 08:03 AM   #3
2lowintegra
2lowintegra's Avatar
Default Re: Greddy boost gauge??? (Aiyoko Turbo)
1bar is 14.5psi....
[img]http://images.honda-tech.com/set1/smile/emthdown.gif[/img]
2lowintegra is offline   Reply With Quote
Old 07-27-2003, 08:04 AM   #4
AcuraFreak
AcuraFreak's Avatar
Send a message via AIM to AcuraFreak
Here ya go pretty simple enough:
.4Bar (5.8psi), .6Bar (8.7psi), .7Bar (10.2psi), .8Bar (11.6psi) .9Bar (13.1psi), 1.0Bar (14.5psi), 1.1Bar (16.0psi)
[B]DFW Area Fab, Mod, Turbo & Tune Mastas = Velocity Performance [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
(972) 389-9877[/B]
[url="http://matchless-performance.com/index.html"]http://matchless-performance.com/index.html[/url]
Arturbo [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] DIRep972 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] Stoney [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] Flamenco-T [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] 92SleepyHB [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] B20TDC2 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] Jarret [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
[B]Boost Control for 1,320 ft.[/B]
AcuraFreak is offline   Reply With Quote
Old 07-27-2003, 08:10 AM   #5
92TEGsrSC
Thanks a lot guys... I just looked on Apexi's website and it says you can get their Mechanical boost meters are available in PSI and KPA... which are better, mechanical or electronic? Also, does Greddy also offer in PSI and KPA for mechanical? what is your guys opinion on this?
Old 07-27-2003, 08:34 AM   #6
Aiyoko Turbo
Default Re: (92TEGsrSC)
i use a mechanical, because i heard it was easier to install, but i don't know anything about the electrical, so i guess im lost there.
Old 07-27-2003, 09:46 AM   #7
bluebullet
bluebullet's Avatar
Send a message via AIM to bluebullet
Default Re: Greddy boost gauge??? (2lowintegra)
Actually to get technical 1 bar = atmospheric pressure = 14.7 psi
[B]I <3 My Honda Decals & Shirts[/B]
[url="http://honda-tech.com/zerothread?id=997362"]For Sale Thread[/url]
[B]Vertex Designs[/B]
[url="http://www.ilovemydecals.com"]www.vertexdesigns.com[/url]
Vinyl Decals, Custom Decals, Full Color Banners
[B]Welding and Fabrication Forum[/B]
[url="http://www.fab-forum.com"]www.fab-forum.com[/url]
bluebullet is offline   Reply With Quote
Old 07-27-2003, 11:25 AM   #8
ek9vboi
Guest
Posts: n/a
is there a BIG difference in what kind gauge company it is? in my opinion, they are all the same, work the same....just different looks. i got carbon fiber autometer gauges and they lookin tyte in tha nite.
Old 07-27-2003, 11:35 AM   #9
vtec.dc2
vtec.dc2's Avatar
.1bar = 1.422334331psi
its not that bad once you use it.. pressure won't jump all over the place.. readings in bar matches standart wasteage spring setting anyway..
vtec.dc2 is offline   Reply With Quote
Old 07-27-2003, 11:53 AM   #10
maddog20
maddog20's Avatar
Greddy boost gauge is not in BAR it is Kg/cm2 1=14.22
maddog20 is offline   Reply With Quote
Old 07-27-2003, 01:26 PM   #11
Elite Hatch
Elite Hatch's Avatar
Send a message via AIM to Elite Hatch
Default Re: Greddy boost gauge??? (maddog20)
Same thing bro
93 CX Hatch - GONE
11.76@120 at 16lbs
96 CX Hatch - PRESENT
Elite Hatch is offline   Reply With Quote
Old 07-27-2003, 03:09 PM   #12
maddog20
maddog20's Avatar
Nope, not that it is big deal but a BAR is 14.7 psi while kg/cm2 is 14.22psi
Old 07-27-2003, 06:16 PM   #13
Elite Hatch
Default Re: (maddog20)
you make a good point. nearly exactly the same tho I am very suprised that they are indeed not the same
93 CX Hatch - GONE
11.76@120 at 16lbs
Old 07-27-2003, 06:21 PM   #14
maddog20
maddog20's Avatar
LOL! sorry not trying to be ****! But every tenth counts especially on stock bottom end KABOOOOM!
Old 07-27-2003, 06:30 PM   #15
vtec.dc2
vtec.dc2's Avatar
thats a good point.. although i used kg/cm2 which i though was the same as bar..
so its .1 kg/cm2 = 1.422334331 psi
Old 07-27-2003, 06:41 PM   #16
maddog20
maddog20's Avatar
try this to help you with conversions
goto http://xtronics.com/reference/convert.htm
05, 15, 87, apexi, bar, boost, buy, convert, europe, gauge, greddy, kg, mechanical, psi, read
