Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 07-23-2003, 03:17 PM   #1
mdpalmer
mdpalmer's Avatar
Default broken crankshaft pulley "key"....what to do?
Suddenly my power steering disappeared and I heard a flopping noise in the engine bay. PUlled over and noticed that several belts slipped off of their respective pulleys. I'm not too sure what they connected to (I don't know much about engines/mechanical goods), but I think it's the power steering pump and A/C unit.
Took the car to a mechanic and they took off the belts and crank pulley. It appears that there is a key (on the crank) that fits into the pulley in order to allow tight fitment between the pulley and crank. Well, the mechanic showed me that the key basically sheared off of the crankshaft end, and sat in the pulley's groove (the one that accepts the key) sliding all over the place. The inner ring of the pulley looks like it was sanded down due to the play between the crank and pulley.
They gave me two options: 1) weld the key back on and replace the crank pulley with a new one; 2) replace the crank (in other words, take the whole motor out of fvcking car.
What do you guys think I should do?
~MDP
Mike
1993 SSM FD Rx-7 (13.2 @ 107, stock turbos)
2001 Satin Silver DC4 Integra Hatch (FS)
1996 Milano Red DC4 Integra Hatch (sold)
mdpalmer is offline   Reply With Quote
Old 07-23-2003, 03:28 PM   #2
J2turbo21
J2turbo21's Avatar
Default Re: broken crankshaft pulley "key"....what to do? (mdpalmer)
I had the same problem and the pulley is fucked,key is smashed to hell and the end of the crank shaft is flared and fucked.What did I do you might ask?New crank,new key and new crank pulley.Its a good thing the motor was apart and being rebuilt.
[b][url="http://cgi2.ebay.com/aw-cgi/eBayISAPI.dll?ViewFeedback&userid=j2turbo21"]My EBAY Feedback[/url][/B]
[b][url="http://honda-tech.com/zerothread?id=536032"]My Vouch Thread[/url][/B]
[b][url="http://honda-tech.com/zerothread?id=566291"]I'm a HT Best Seller[/url][/B]
[B] [url="http://www.gbrtuning.com/"]GBR Tuning[/url] [/B]
"If There May Be Trouble Let It Be In My Day,That My Children May Have Peace" Thomas Paine
J2turbo21 is offline   Reply With Quote
Old 07-23-2003, 03:32 PM   #3
JV
Who?
JV's Avatar
Why would they weld the woodruff key on? Is the slot in the crank gone?
JV is offline   Reply With Quote
Old 07-23-2003, 07:46 PM   #4
NonovUrbizniz
NonovUrbizniz's Avatar
Default Re: broken crankshaft pulley "key"....what to do? (JV)
Look at me I know the specific name of a crank pulley key JFWY....
I would get a quote for the crank replacement...
It's probobly going to cost you as much as a swap would...
Get a number from them...
DO NOT let them weld it in... that's sooo far beyond ghetto I can't even believe a shop with a license would even suggest it as an option.
it will NOT hold... it will snap off just like it did when there was 15x's more holding power (in the stock WOODRUFF journal).
I'd say either get it done properly or get a swap and pay someone on hear a couple hundred to drop it in since you said you're not too mechanically inclined.
I'm DAMN sure you could get another motor for less then that job will cost you... granted probobly not anything better than an ls but still... that's WAY better than paying out the pooper just to have your old engine back to normal.
For Sale Thread - Turbo Parts - D16 Parts - Random Stuff
http://www.hondamarketplace.com/show...4#post40554064
NonovUrbizniz is offline   Reply With Quote
Old 07-24-2003, 10:44 AM   #5
mdpalmer
mdpalmer's Avatar
Default Re: broken crankshaft pulley "key"....what to do? (NonovUrbizniz)
hmm.....any suggestions on how to get a reputable swap?
Mike
Old 07-24-2003, 11:41 AM   #6
trbob16a
What do you mean that the inner ring looks like it was sanded down?
I would just get a new key and pulley, no need for a whole new crank. It sounds to me like he's trying to take you for a ride.
84.5mm RS Machines / DPR B16 with stage 3 .82 60-1
368whp / 260 ft-lbs tq, 16psi on pump gas
trbob16a is offline   Reply With Quote
Old 07-24-2003, 12:25 PM   #7
Sleeper
If the crank is damaged I would replace it. DO NOT let them weld the key on the crank. Also, you don't have to remove the engine to replace the crankshaft. It can easily be done from under the car. Your best bet would be to find a used ls block and swap the parts over, unless you can find the crank/pulley/key seperately.
Sleeper is offline   Reply With Quote
Old 07-24-2003, 03:10 PM   #8
owen_the_soyboy
owen_the_soyboy's Avatar
Default Re: broken crankshaft pulley "key"....what to do? (Sleeper)
2009 Civic LX-S sedan MT, back to basics!
my cardomain - crazy ls1 v8 rx7 - sold, sick ITR powered EG - sold, all beaters - sold yay!
owen_the_soyboy is offline   Reply With Quote
Old 07-27-2003, 03:10 PM   #9
mdpalmer
mdpalmer's Avatar
Default Re: broken crankshaft pulley "key"....what to do? (trbob16a)
Your solution was implemented by the mechanic. I think that the other person I spoke with was confused about the damage to the key and pulley. Thanks again for your advice.
Mike
93, broke, broken, civic, crank, crankshaft, honda, integra, key, ls, pulley, remove, removing, weld, woodruff
