Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 07-22-2003, 08:06 PM   #1
ImpulseITR
ImpulseITR's Avatar
Default New Clutch/gear grind
I was really happy two weeks ago to drive home in a 2000 PY Integra type R. But as luck would have it, I managed to break within a few days when the clutch went out on me. I ended up dropping in an ACT 6-puck disc and heavy duty pressure plate. I know this is a little harsh but it's kind of a long story why I ended up with it. Anyways, now that I've put a few miles to break it in and seat the disc, when I shift into third gear from second at high RPM's the tranny grinds! It never did this before the new clutch. Do you guys think that adjusting the clutch will take care of this? Or is it possible that when the old clutch went, somehow it could have damaged a synchro, which seems rather odd to me. When the clutch went, I was shifting out of third gear and into fourth. When I went into fourth, the clutch pedal went soft to the floor and it wouldn't go into gear. When we took the factory disc out, the pads were broken apart. What do you guys think? It only grinds at high RPM's and it seems to do it every time. Thanks
ImpulseITR is offline   Reply With Quote
Old 07-22-2003, 08:24 PM   #2
jaa1311
jaa1311's Avatar
Send a message via AIM to jaa1311
Default Re: New Clutch/gear grind (ImpulseITR)
mine also seems to do this, sumtimes shifting down from 3rd to 2nd. i hope its not a syncro Click the image to open in full size.
ITR 00-534 ECHC #113 H2
ITR 00-684
jaa1311 is offline   Reply With Quote
Old 07-22-2003, 08:46 PM   #3
tilt
tilt's Avatar
Did you install it yourself or did you take it to a shop?
my guess would be the tranny fluid is different (possibly cheap stuff?) and it is just making the problem that already exists evident. I'd try to figure out what was in there before and after, or get some quality stuff.
tilt is offline   Reply With Quote
Old 07-22-2003, 10:28 PM   #4
98itR484
98itR484's Avatar
Send a message via AIM to 98itR484
Default Re: New Clutch/gear grind (tilt)
probably signs of a synchro going bad.
what i would do is drain the fluid, and get some GM synchromesh tranny fluid, your problems should be gone, unless its a really bad grind
WTB: 99-00 Stock Civic Suspension
98itR484 is offline   Reply With Quote
Old 07-22-2003, 11:14 PM   #5
ImpulseITR
ImpulseITR's Avatar
Default Re: New Clutch/gear grind (PacMan ITR)
I put the GM synchromesh in the car when the clutch was changed. My friend, who is a mechanic at the honda dealership did the install. It grinds the gear every time you shift above 5-6k RPM. Shifting lower, it feels real solid. I also noticed after the clutch that all gears take slightly more effort to get into. It never did this before the new clutch.
Old 07-23-2003, 04:27 AM   #6
Downey
Downey's Avatar
your supposed to adjust ur clutch pedal after you install a clutch.
look down underneath your dash.. find ur clutch pedal.. on the back of the rod that goes into the the clutch master cylnder.. theres a 12 or 14mm nut. loosen it. now turn the rid with ur fingers to the left. turn it about 1 or 2 turns. then tighten the bolt back up.
start the car, push clutch, put into 1st gear and start to let clutch out. see if it grabs differently. now go drive. if it still grinds adjust some more.
my buddies GSR did the same thing after we changed the clutch/flywheel.. simple adjustment made a major difference.
Redstone Motorsport - Morgan Hill, CA
3 Time Honda Challenge H1 National Champion
Downey is offline   Reply With Quote
Old 07-23-2003, 10:20 AM   #7
bbqman
bbqman's Avatar
May be either your clutch master or slave cylinder that is developping a leak. We replace many clutches on high mileage b18's and when the hydraulics worked fine on the old unit, they started to fail with a new clutch.
This is even more apparent when you upgrade the clamping force. your foot doesn't feel it, but trust me the slave does.
My ITR has 80,000km of auto-x and trials and when the clutch let go, the slave followed the same evening.
A bad day at the races always beats a good day at work! http://images.zeroforum.com/smile/emwink.gif
bbqman is offline   Reply With Quote
Old 07-23-2003, 10:41 AM   #8
ACTman
ACTman's Avatar
It's really hard to diagnose problems over the internet but as long as the pilot bearing is good and the release point is high enough at the pedal, then it has to be trans. or clutch.
The only thing I can think of in regards to the 6 puck clutch is if the disc doesn't like to slide freely on the input shaft. Our instructions that whould have come with the parts explain to lubricate the splines and check that they slide freely. If they don't slide freely then the disc will drag on the flywheel no matter if the pressure plate has released or not. I assume you are running the stock flywheel. If not, there could be issues with the flywheel as well.
Dirk Starksen
President & CTO
Advanced Clutch Technology Inc.
ACTman is offline   Reply With Quote
Old 07-23-2003, 01:54 PM   #9
ImpulseITR
ImpulseITR's Avatar
Default Re: New Clutch/gear grind (ACTman)
It does have the stock flywheel on it. I'll ask my mechanic if he lubed the splines well and if he checked it before he put it in. Wouldn't it be strange if the Synchro went at the exact time as the clutch? That just doesnt make since, I figure it has to be something with the clutch. I am definately going to throw in a street disc, though. I am just worried that if I just go ahead and do that and if the problem is still there, then I will have to buy an all new OEM setup just so I can get the tranny warranteed. The supplied pilot bearing of course was installed with the clutch.
Old 07-23-2003, 09:22 PM   #10
RICE POLICE SIP
1997 Honda Del Sol
RICE POLICE SIP's Avatar
iTrader Rating: (2)
Default Re: New Clutch/gear grind (Downey)
sounds good Click the image to open in full size.
Accidents in the back seat cause kids;Kids in the back seats cause accidents
Bought from: ICeDoUt; big-cat Sold to: pane93civhb
RICE POLICE's Garage
RICE POLICE SIP is offline   Reply With Quote
Old 07-23-2003, 09:38 PM   #11
t
Why dont you ask your friend?? Seeing that he is a Honda mechanic and he did do the install. It is better than getting guesses from the internet.
But my guess, Sounds like the clutch is not releasing all the way at high rpm. Could be low clutch fluid or as simple as clutch pedal adjustment (but after doing multiple clutch installs I have never have to adjust the clutch pedal).
3rd, adjust, back, clutch, gear, grabs, grind, honda, instal, plate, prelude, pressure, push, released, supposed
