Castrol vs. Mobile 1??????
Old 07-10-2003, 01:26 AM
jstyle's Avatar
Default Castrol vs. Mobile 1??????
I've been using Castrol since day one and has worked just fine for me. However, I do see and hear a lot about how Mobile 1 is good as well. Just curious on what you guys thought about this.......
Who has used both and noticed a difference if any?
Thanks.
Old 07-10-2003, 04:17 AM
VTechie's Avatar
Default Re: Castrol vs. Mobile 1?????? (jstyle)
Well, the ExxonMobil guy I talked to at a conference recently swears by Mobil1.
Go figure.
Old 07-10-2003, 04:46 AM
P1mpSlap's Avatar
I switched from Mobil 1 to Castrol (synthetics).
I think my engine started to burn the Mobil 1 very slowly. As of yet, no problems with the Castrol.
Old 07-10-2003, 04:59 AM
JohnnyWash1's Avatar
Check out this site. I think you will learn alot.
http://www.vtr.org/maintain/oil-overview.html
Old 07-10-2003, 10:00 AM
F00LI0's Avatar
i use Royal Purple synthetic motor oil, guaranteed 1-3% increase in hp, i've been using it for a while now and it doesnt seem to be breaking down.
http://www.royalpurple.com
Old 07-10-2003, 10:47 AM
JDMHN8's Avatar
Default Re: Castrol vs. Mobile 1?????? (F00LI0)
They could actually be the same.
Castrol (as well as Pennzoil, Quaker State, NAPA, etc.) does not make their own oil. They buy it from a larger refinery company and specify their own custom additive package. Exxon/Mobil, Shell and Valvoline are the biggest oil companies, so it comes from one of them.
Plus, all oil must meet SAE SL standards. Regardless which one you use, it has to meet at least the minimum requirements for protection. Synthetics usually go well beyond those.
Old 07-10-2003, 10:55 AM
2muchGT's Avatar
Default Re: Castrol vs. Mobile 1?????? (JDMDA9)
I use Mobil 1..and my dad also uses it for his '01 c5 Vette so IMO that says alot.
Old 07-10-2003, 11:25 AM
romeo619romeo's Avatar
Default Re: Castrol vs. Mobile 1?????? (2muchGT)
john force uses castrol on his 5/4 second drag car.. so works for me...now that beats the corvette statement
but then again.. pennzoil claims they went to the moon with theres.. dunno if any of that is true.. but they did do a comparason on oil... on TV.. technically.. you cant compare anything on TV " product wise" saying .. this is better then the other..unless its true, they said its better then castrol...but castroll full sythetic never went bad on me...i back that up with 2 turbo cars on it already
Old 07-10-2003, 11:45 AM
Default Re: (JohnnyWash1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyWash1 &raquo;</TD></TR><TR><TD CLASS="quote">Check out this site. I think you will learn alot.
http://www.vtr.org/maintain/oil-overview.html</TD></TR></TABLE>
why didnt they do a research on all the full sythetic oils also?
Old 07-10-2003, 12:41 PM
RayB's Avatar
Mobil 1 for me...I've used it for years and never had any problems...it's largely a matter of preference...the most important thing is changing oil on time every time...
Old 07-10-2003, 05:54 PM
NA gs-R 05 C
Guest
Posts: n/a
i like castrol. keep using it.
Old 07-10-2003, 08:54 PM
King_j's Avatar
Default Re: Castrol vs. Mobile 1?????? (NA gs-R 05 C)
no synthetics for me, only castrol gtx 5w-30. do my oil change every 2,500 miles, and when i drain it it still looks gold, cant beat that.
Old 07-10-2003, 09:49 PM
Loveless's Avatar
Default Re: Castrol vs. Mobile 1?????? (King_j)
what's the BAD thing about synthetic?
Old 07-10-2003, 09:54 PM
RedGSR's Avatar
Default Re: Castrol vs. Mobile 1?????? (Loveless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless &raquo;</TD></TR><TR><TD CLASS="quote">what's the BAD thing about synthetic?</TD></TR></TABLE>
Old 07-10-2003, 09:56 PM
StinkyTofu's Avatar
Default Re: Castrol vs. Mobile 1?????? (RedGSR)
I used to praise mobil 1. Switched to castrol syntec and i haven't burnt any oil yet. Mobil 1 would burn a tad after some "spiritied" driving.
Old 07-10-2003, 10:03 PM
hmongboyLS's Avatar
Default Re: Castrol vs. Mobile 1?????? (StinkyTofu)
my dad use castrol gtx in my car but now since i'm working i'm prolly going to be using red line oil
Old 07-10-2003, 10:16 PM
Al Bundy's Avatar
Don't you know anything? Type R guys use Mobil 1 synthetic while all other integra owners use Castrol.
Castrol is cheaper and hasn't burned for me yet. Castrol
Old 07-10-2003, 10:28 PM
Boost Ambassador's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F00LI0 &raquo;</TD></TR><TR><TD CLASS="quote">i use Royal Purple synthetic motor oil, guaranteed 1-3% increase in hp, i've been using it for a while now and it doesnt seem to be breaking down.
http://www.royalpurple.com </TD></TR></TABLE>
Royal Purple is a pretty expensive oil for my liking...... I guess just stick with what u have been using and that has not failed your expectations on motor oil!
Old 07-10-2003, 10:34 PM
B2FiNiTY's Avatar
Default Re: Castrol vs. Mobile 1?????? (LS60-1)
I used to use mobil 1. Stopped after 15k miles because it just got really expensive. Currently back to Castrol GTX. It is much much cheaper and I can change it more often.
Old 07-10-2003, 10:47 PM
K.F14's Avatar
Default Re: Castrol vs. Mobile 1?????? (B2FiNiTY)
Castrol has my
Old 07-10-2003, 11:36 PM
RedGSRBull's Avatar
Default Re: Castrol vs. Mobile 1?????? (Tenzo R)
I just changed my oil today and got Valvoline full synthetic AND WOOOOHOOO VALVOLINE RULES! I vote it the best oil IMO. Have had Mobile 1 in past with a V6 Honda Accord didnt see as much difference as i saw with Valvoline.....
Old 07-10-2003, 11:47 PM
In-N-Out Burger
NightRiderS2K's Avatar
An article I wrote awhile back concerning B18C motors losing oil while using sythetic (also applies to all honda motors):
B18Cs in general are known to lose some amount of oil when switching over to synthetic from dino oil. Or using synthetic oil for break-ins. In most cases, this is generally true with Mobil1. I am not degrading Mobil1 oils in any ways, infact, I highly recommend it.
Dino oils or Mineral oils leave deposits in your car that have an effect on your seals. Overtime, these deposits act as seals themselves with the (sludge deposits)helping your engine maintain its proper oil level.
Synthetics have cleaning detergents in them so when switching over to it...it cleans out the mess left behind by dino oil. If you notice a loss in oil level after a couple hundred miles of driving...it is usually an indication that your seals need replacement.
If not too worn or damaged, the seals inside your engine will cure overtime.
It is also good to replace the cam seal or "cheap" plastic honda cam plug (I replaced mine with the STR cam seal, about $25-30 at most aftermarket auto/Internet stores---wise investment) if you notice leaks near the distributor cap, its a good time to replace it or if your engine has been abused by constant racing and high revving.
Just remember folks, once you go synthetic, theres no going back to using DINO oil....unless....
I recommend:
MOBIL 1 synthetic
and for those who do not want to pay for synthetic oils like Mobil 1 but still want somethine better than the OE counterpart...try:
Castrol Syntec Blend...affordable.
cheers
NRG
Old 07-11-2003, 03:14 AM
non-VTEC's Avatar
castrol syntec 5W50 works great for me........i'll never use mobil 1 again...
Old 07-11-2003, 06:47 AM
ebelp's Avatar
Default Re: Castrol vs. Mobile 1?????? (non-VTEC)
Where's a good place to get an STR cam seal?
Old 07-11-2003, 07:19 AM
KiLL LaMB's Avatar
Default Re: Castrol vs. Mobile 1?????? (NightRider-gsR)
Yeah, i'll vouch for that. Mobil 1 is expensive but worth it. I've been using Mobil 1 in my 90 Integra and my car had 130,000 miles when I bought it. Now it's at 186,000 miles. I never had any problem with it. I did all the necessary test compression and leakage. All came out good. A guy that got a 01 Prelude offer me to buy my car off of me. I said no.
My friend been using Castrol in his car for years. He likes it because it's cheaper than buying Mobil 1.
Quick Reply: Castrol vs. Mobile 1??????
