How tight should Rocker arm be when adjusting valve???
Old 07-05-2003, 06:23 AM
hondaless's Avatar
Default How tight should Rocker arm be when adjusting valve???
Ok since i changed injectors and the timing couldn't be any better my valves have to be making the noise.... when i adjusted them the rocker arms or those things the lobes on the camshafts hit are a lil loose.... should they be loose or a lil tight???
Old 07-05-2003, 06:40 AM
ComposiMo's Avatar
Default Re: How tight should Rocker arm be when adjusting valve??? (evilcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilcrx &raquo;</TD></TR><TR><TD CLASS="quote"> those things the lobes on the camshafts hit are a lil loose...</TD></TR></TABLE>
Dude, maybe its time to take the car somewhere and let someone who knows what they are doing adjust the valves for you. You can hurt your engine badly if you make a mistake up there.
What did you adjust them to when you did it (what feeler thickness did you use)?
Old 07-05-2003, 06:50 AM
hondaless's Avatar
Default Re: How tight should Rocker arm be when adjusting valve??? (ComposiMo)
.15mm intake .17mm exhaust
Old 07-05-2003, 07:13 AM
jung4g's Avatar
Damn, all metric and shitt... I adjust both my intake and Exhaust to .009 inches... Per the Honda service manual you should adjust them to .17mm-.22mm intake and .22mm-.27mm exhaust. So you may have them a little tight, and they can go to smaller clearance when you're tightening the lock nut, so be careful, to tight can cause some weird stresses in there... Good luck...
Jung
Old 07-05-2003, 07:17 AM
hondaless's Avatar
Default Re: How tight should Rocker arm be when adjusting valve??? (jung4g)
thats what the honda manual recomends for a ZC and if it was to tight wouldn't it idle like crap? the car idles fine just a lil noisy.
Old 07-05-2003, 07:22 AM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jung4g &raquo;</TD></TR><TR><TD CLASS="quote">Damn, all metric and shitt... I adjust both my intake and Exhaust to .009 inches... Per the Honda service manual you should adjust them to .17mm-.22mm intake and .22mm-.27mm exhaust. So you may have them a little tight, and they can go to smaller clearance when you're tightening the lock nut, so be careful, to tight can cause some weird stresses in there... Good luck..</TD></TR></TABLE>
That doesnt make any sense?? You tell him that he may have them a little tight yet what he tightened them to is less than what you said the manual says??
doublejz
10-24-2005 02:10 PM
SRC91Nteg
01-20-2004 09:45 PM
david90
08-08-2003 06:25 AM
P1mpSlap
04-21-2003 12:36 AM
lonefuzzy79
11-23-2002 05:33 PM
Quick Reply: How tight should Rocker arm be when adjusting valve???
