WTB: 91 Acura Legend speed sensor
i'm looking for this part and i figured someone in here would know about where to get one and how much it is.
also, if anyone has any idea on how to replace it, please post
Re: WTB: 91 Acura Legend speed sensor (TurbothisLS)
if you are talking about a abs wheel speed sensor, i went to acura for a rear right wheel speed sensor. it would have cost $175! i went to a junk yard, it cost me $40. if you dont want to spend a fortune call up junk yards in your local area.
Wouldn't you know it. I had a speed sensor that layed in my toolbox for a year from a junk yard diff that i put in a legend. I threw the bitch away 2 days ago. Now i find someone that needs it. I would have given it to you, i had no use for it. Sorry bro...
What are your symptoms? Flashing d4 or d5 light, erratic speedo? It is located on the fromt of the diff. It has 2 power steering lines that go to it. The only thing you replace is inside that casing. It has 3 tamper proof torx bits that hold the cover on. Pull that little cover off, be sure to replace the rubber gasket that comes in the kit. After you get the cover off it is just a phillips screw that holds it in. I will post a pic of what it is.
Modified by acuratech at 11:27 PM 6/10/2003
Re: WTB: 91 Acura Legend speed sensor (acuratech)
the speedo bounces around erratically
the code in the ecu says speed sensor
that sucks to hear about that thrown away speed sensor
pm sent
pm sent
