#1 | |||||
#2 |
2003 Ford ExpeditionJoin Date: Aug 2001
If I were to do it, I would "repair" with Brembo OEM replacements and slightly aggressive pads.
The brakes are large enough as is.
Small Stream Salmon Fishing - Portland, Or |
#3 |
Maybe you dont understand the problem???
THERE NEVER WAS A TYPE R IN THE US IN 1996, so there are no 4-lug (4x114.3) rotors available from dealerships or companies here... |
#4 |
have you considered getting a set of USDM ITR rotors and having them redrilled to 4x114.3?
Intentionally left blank... |
#5 |
I'm sure if you contact Brembo, they would have them.
#6 |
I have considered getting Integra rotors and having a machine shop re-drill them. I will be contacting Brembo for them, but most likey they will be a super rare special order, and will cost a shitlaod, I dont know that they'd be available to the US market.
I know there are a bunch of other guys with the swap on here, and eventually they will have to replace their rotors. |
#7 |
i too thought of this that is what deterred me from doing the 4 lug type r brake conversion and i just went ahead with the gsr front and rear conversion. i knew that the rotors would eventually give out and i wouldnt be able to find replacements as easily or as cheap as the gsr. the BLING factor wasnt worth it to me. i asked this question b4 knowing and have seen a as load of people do the 4 lug type r swap and no one wanted to answer its liek they want to keep it to themselves or they dont know either.
#8 |
Ok... I was under the impression that the Honda accord front brake caliper/rotor set was the same as what was on the ITR. Weren't some of the older model accords 4x114.3? I'm just going on tidbits that I remember from random posts. It may be time to measure the dimensions on one of your rotors and go to an autoparts store and find an oem rotor that fits. Honda tends to reuse things, so there has gotta be another honda/acura that uses the same rotors.
#9 |
Talk to SpooN Man (Holding a Group Buy on Fast Brakes).
I PM'ed about this very topic, here is the conversation: (8:07 PM 5/18/2003) VX: I was wondering if Fast Brakes, makes any rotors that are for the 96 Spec. JDM ITR 4-lug wheels??? They are 4X114.3 (5:52 AM 5/19/2003) SpooN Man: yes they are the same as lude rotors. I'll e-mail brian about it. (12:55 PM 5/19/2003) VX: are these rotors the same diameter, width as Fastbrakes' GSR rotors, just with a different spindle pattern??? (1:22 PM 5/19/2003) SpooN Man: yes, I think that they are the exact same but drilled for your 4 x 114 app. Lude 4 lug rotors are the same size also. Modified by VX at 2:12 PM 5/23/2003
[b]<FONT COLOR="darkgreen">How-To:</FONT> <FONT COLOR="crimson">Lose 114 Pounds!</FONT> |
#10 |
Here's a pic of a replacement rotor for the 4x114.3 lug pattern. I'm almost positive that i got this pic from a member here on H-T. I don't remember who the member is or what kind of rotor this is.
#11 |
PM "KJEG94" here on h-t. he went through hell and back with his 96 spec ITR 4x114.3 lug conversion.. he knows about this part too.
#12 | |
(1:47 PM 5/23/2003) KJEG94: thanks man. i ended up using 96 USDM gsr rear rotors. Redrilled by a machine shop to 4x114.3 and bored out in the center to fit the hub. Its only a slight amount to bore but if u have a stock jdm rotor they can match it (2:09 PM 5/23/2003) VX: ahh i see, thanks man!
#13 |
I don't understand the point of getting the 4x114.3 conversion, is there something I'm missing? Aren't the brakes teh same as gsrs? What would make you choose to do this, aside from being "different"?
#14 | |
Gearing Owns Me
I think 800 bucks for a nice 4 disc setup plus mint wheels is a very good buy
Independent Honda and Acura.... (360)574-8880 95 Civic Si J32A2 91 Civic ITA/H4 MFactoryOEM Honda |
#15 |
OMG!!! NO! The Prelude/Accord ROTORS DO NOT ****ING WORK!!!
I PERSONALLY TRIED THEM, so the guy at "FASTBRAKES" is LYING HIS ASS OFF. That pic is ****ing off by a mile too, thats a huge caliper, thats either prelude VTEC or an accord caliper because that is way bigger than this. Still waiting to hear from Brembo (had my shop contact them and contacted Brembo North America). Looks like Im going to have to re-drill the shit. |
#16 |
ok guys, use 92-96 Prelude VTEC Rotors (11'') I haven't actually done any 96 ITR swaps yet but that would be my assumption. If the 96 discs are actually smaller then I would say you should try the the two different types of Accord/Prelude discs.
Honda Accords at one point came with a ****ing weird disc, it may be that one. I'll give you both part numbers (Brembo) 094 2927 094 2924 one of those is a two piece ...... hope that helps you guys out The above brake set looks like it uses 92-96 Prelude NON-VTEC Modified by SamB16 at 4:31 PM 5/24/2003 |
#17 | |
replacement rotor, but can somebody confirm from experience if the Prelude VTEC rotors will bolt up and fit as a replacement rotor??????
#18 | |
BUMP. |
#19 |
Ok based on what Koala Yummies is saying... Prelude VTEC, and Non-VTEC, and Accord rotors will not work as replacement rotors... Instead of re-drilling GSR rotors... DOES ANYBODY KNOW WHAT AFTER MARKET BRAKES (ROTORS & CALIPERS) WILL WORK???
#20 |
Member KIWI who races an imported 1996 Honda Integra Type R said that before he switched to Prelude calipers he used a 1/8" shim and extended caliper bracket bolts in order to run Prelude NON-VTEC rotors as replacements. He said to talk to http://www.fastbrakes.com because they know everything. I will be contacting them.
Maybe this will sway everyone from buying this conversion, rare factor goes up
#21 | |
OG triple OG.
Do you know what that means? It means a OEM Honda big brake upgrade. Yes kiddos you can bolt on 93+up caliper bracket and caliper in the front Woowooo!!!! You have to shave a little on the caliper to where it mounts.
FOR SALE: NOR CAL 94 DOHC DEL SOL BNIB MOMO Monte Carlo + NRG quick release v.2 & short hub |
#22 |
Any threads, detailed info, or pics, of fitting the prelude rotors and calipers on the ITR hubs??? (Shims, Shaving Calipers... etc.)
#23 |
Sure Prelude calipers are nice and all, but for people who just bought the 96 ITR calipers for a hatch, that is more than enough.
Im still going to find out about using a shim and longer caliper bolts to use Prelude NON-VTEC rotors with the 96 ITR caliper. |
#24 |
Koala, post any info you receive from Fast Brakes when you talk to them regarding their replacement rotors for these hubs.
#25 |
2005 Subaru ForesterMy Garage |
Yeah, I know I've talked to VX and Koala Yummies about this, and I'm having my doubts about the Prelude Rotors. Maybe the 3rd gen ones might work? Or maybe my rotors are just odd-ball as hell and I'll have to redrill eventually. Though remember guys that it's really not a big deal because you can 'turn' the stock rotors at least once at the machine shop, then you have to worry about replacement. Sorry I can't provide more info, but you just don't really know. Good luck to you guys, and I'd like to hear any info on any usdm replacement rotors. Here's my rear 4 x 114.3
Importsports Performance & Dyno '05 Forester XT::'94 EJ1 K20A2 Importsports SFWD Civic: 9.45@159mph |
| Bookmarks |
| Tags |
| 1995, 94, 96, accord, bore, diameter, gsr, honda, hub, itr, lug, mod, rotor, rotors, size |
