> Honda CRX / EF Civic (1988-1991)
Old 05-21-2003, 09:18 AM   #1
GroundZer0
GroundZer0's Avatar
Send a message via AIM to GroundZer0
Default Hood release cable broken? Help me out!!!
Well, today i went to go put some oil in my car and i noticed that on the inside of the car, the hood release cable is all limp? Im not sure how this happend, considering the other day it was fine? How can i fix this/find where the problme happened? Is there a way to tighten the cable? How much will a new one cost? Thank you, hopefully i can get this fixed soon, i need to put oil in my car? Is there another way to pop the hood? Thanks a ton!
GroundZer0 is offline   Reply With Quote
Old 05-21-2003, 02:19 PM   #2
Jared
Jared's Avatar
Default Re: Hood release cable broken? Help me out!!! (GroundZer0)
If its broken, take the front bumper off and then you can access everything without ******* anything up in the process.
ASE Master Technician - L1
Nissan Master Technician
GTR Certified
AEM Factory Trained
Jared is offline   Reply With Quote
Old 05-21-2003, 02:22 PM   #3
matt j
matt j's Avatar
Send a message via Yahoo to matt j
Default Re: Hood release cable broken? Help me out!!! (Jared)
i agree you can also take the plastic fender cover off and yank on the cable from there but more than likely its right by the hood latch so take off the front bumper and scope it out
2001 suzuki gsxr 600
Do not argue with an idiot. He will drag you down to his level and beat you with experience.
matt j is offline   Reply With Quote
Old 05-21-2003, 02:37 PM   #4
raene
raene's Avatar
I used a junkyard piece and replaced my cable, which had broken. This problem manifested itself as a hood release latch that was unwilling to release the hood, and also unwilling to hold the hood shut when I closed it. I only noticed the problem after removing the latch mechanism and seeing that the part of the cable cover that clips onto the latch had broken off. I actually removed the cable and installed the new one without removing anything other than a) unbolting the top 4 bolts on the rad support, b) removing the inner fenderliner on the driver's side. Everything else I was able to get to by contortion.
Ghetto Garage Racing
'88 CRX 504hp
raene is offline   Reply With Quote
Old 05-21-2003, 05:05 PM   #5
91civicEX
91civicEX's Avatar
Send a message via AIM to 91civicEX
Default Re: Hood release cable broken? Help me out!!! (raene)
you cant take off the bumper without popping the hood. climb under the car and look for a cable to yank with some pliers. it runs right beneath under the left front fender.
Vlad
1991 Civic EX- DAILY DRIVER A/C P/S P/W P/L
1991 CRX DX- bought 10-16-05 pics comin soon
"D series- beating you with your old parts" http://images.honda-tech.com/set1/smile/emthup.gif
Formerely known as "91civicLX"
91civicEX is offline   Reply With Quote
Old 05-21-2003, 09:52 PM   #6
guttedEF
Send a message via AIM to guttedEF
Just kneel underneath the car or however you can, so that you can see where the cable goes. It's just a little level, you'll see where the cable is attached by a ball. Just oush/pull it the same way as the cable would do it and it'll pop.
I had the same problem, I ended up just removing all of it and I have a CF hood with hood locks/pins now.
[B]'90 STD hatch[/B] [B]SOLD[/B]
[B]14.37 @ 95.98mph[/B]
[B]'05 Scion xB[/B]
[B]TOTALED by idiot driver![/B]
[B]'92 Civic VX[/B]
[B]Back to the dark side..[/B]
guttedEF is offline   Reply With Quote
Old 05-22-2003, 02:47 AM   #7
customx_
customx_'s Avatar
Send a message via AIM to customx_
you should reroute your release cable while youre there, for security reasons.
customx_ is offline   Reply With Quote
Old 05-22-2003, 02:41 PM   #8
LunatiK
LunatiK's Avatar
Here's what joo do:
1. Vaccum and clean your car real nice, you know.. so it looks okay.
2. Take it back to the honda factory and tell them to stop making peices of **** on 4 wheels... oh you might want to add that when they manufactured your lawn mower, they forgot to put the blades on.
LunatiK is offline   Reply With Quote
Old 05-22-2003, 03:43 PM   #9
GroundZer0
GroundZer0's Avatar
Default Re: Hood release cable broken? Help me out!!! (LunatiK)
How about, dont post here, its a honda forum, your a moron.
update - got the cable to pull from the inside, so i guess its not broken, but how can i tighten it up so that i can pull it using the lever?
95, accord, broken, cable, civic, close, cost, crv, find, honda, hood, release, repair, scion, xb
